I've got the same error on my 15 R1...any chance you could give me the part numbers to the 2 sensors? My dealer was completely baffled when I asked for them and on the parts breakdown it's not entirely clear.
If they are the ones I'm thinking, they aren't cheap either...$130 each?
It's great when you have your bike taken apart completely by the dealer for a recall and then start getting these type problems.
He posted the diagnostic code.
Those are the selections in the diagnostic function you access through the display. Its like a scan tool built into the ecu.
diagnostic codes are not the same codes as the trouble codes when the check engine light comes on.
The one you posted is the correct codes.
if the kickstand circuit is open it can start but will die when you put it in gear.
If the one you posted is dor the 2015 then it looks like it doesnt have anything to do with a kickstand.
There should be another chart of the troble codes saying wether or not the engine will start or if you can ride it. Im not on my comp at home so i cant look it up for you.
