Which exhaust did you choose? (Pics please) - Page 5 - Yamaha R1 Forum: YZF-R1 Forums
 71Likes
post #81 of 82 (permalink) Old 01-10-2017, 01:18 PM
it is what it is...
P.K.1000r's Avatar
Originally Posted by bbsteinnewyork View Post
Not going to speak out of line here, but seems that the Kawasaki Cat Eliminator is a lot less work and material to build. Check out the pictures of the 2 products on the Graves Website. I'm sure that's the reason for the difference in price.
Sent from my SM-G930V using Tapatalk
I see where you're coming from, BUT the ZX10r and the R1 seem to use almost identical carbon end cans, with the exception being the R1 requiring a "SMALL" 2 into 1 Ti mid pipe that the ZX10 does not. Am I to believe this SMALL Ti mid pipe is the reason for an almost $800.00 price increase over the ZX10r system? Especially when comparing the amount of material & design complexity of the 09-14 R1 Ti cat eliminator mid pipe selling for $475.00. Not to mention the dual carbon cans which cost about $100.00 more than the 2015 system...
P.K.1000r is online now
post #82 of 82 (permalink) Old 01-11-2017, 08:45 AM
tHE GODFATHER
SpidermanSS's Avatar
Send a message via AIM to SpidermanSS
Originally Posted by P.K.1000r View Post
Since we are on the subject of build quality, and customer appreciation... Would you care to explain the current pricing strategies Graves is employing in regards to the 2015 R1 +, and 2016 ZX10r + for example?
2015 R1 + cat elim exhaust - 1365.50
2016 ZX10r + cat elim exhaust - 569.00, A difference of $796.00...
I'm guessing the cost difference cannot be attributed to material cost as I could purchase 2 complete units for the ZX10r and still be under the cost of 1 R1 unit.
Thanks for your feedback it's not even in the same ball part for the two you are comparing.
Yeah about two inches of single bend aerospace grade titanium compared to one of our craftsmen joining multiple bends (roughly 4 - 12 inch tubes for the construction) into a flawless flowing aerospace grade ti Y pipe / silencer.
This bracket and combined nut laser crafted out of Ti has more time in it when looking at the build sheet than the whole setup of the ZX10 exhaust
You also have an entire bend built into the R1's silencer that is longer than the ZX10 piece and has a cnc ti spiggot for flawless
Anyways we price based of a spreadsheet that timelines each units costings completely. There is not voodoo pricing magic and you will not find cheap materials and junk pipes at our company EVER! If you need a discount code please let me know.
LINK for your convenience Graves Motorsports 2015-2016 Yamaha R1 Cat Eliminator Exhaust System
Graves Motorsports 2015-2017 Yamaha R1 Cat Eliminator Titanium Exhaust System with carbon fiber silencer. GMS Exhaust systems are designed for the elite rider seeking top of the line performance, fit, finish and value. This R1 exhaust system was developed using the same technology that has powered Monster Energy Graves Yamaha riders to 7 straight consecutive Moto America / AMA Superbike championships along with numerous 600cc titles. This product is intended for closed course competition use only. Use of this product for any other purpose is strictly prohibited.
This Graves Motorsports Cat Eliminator exhaust is designed for the racer on a budget seeking the closest performance exhaust to our full race system. We did not allow compromises in the development of this system. Material diameters, lengths, the silencer core size and length are optimized for maximum power output throughout the throttle and RPM range. Combined with Graves’ exclusive flash tune map this system produces a solid 15+ HP in the midrange and 11+ on the top of the horsepower charts. This tune also removes any computer error codes the bike will have when installing performance exhausts.
We use the same 1.00 MM thick wall high heat grade Titanium tubing used on our Superbikes. This material is designed special for maximum durability and oxidation resistance up to 800*Celsius / 1472*Fahrenheit. It is designed to live at almost twice the temperature of normal Grade2 Titanium. The tubes are precision bent and cut with the latest equipment available. The tubing is then welded in fixtures designed so that repeatability is second to none. It comes with a single Lambda receiver bung for on track data logging or Dyno tuning. The spring tabs are made from 4MM thick Titanium wire for long life.
The silencer is one piece with the tail pipe welded to the deep draw tapered Titanium entrance cap and attaches to the collector with a 60.5 MM machined Titanium joint for a perfect fit every time. The Collector attaches to the stock mount under the frame with a Titanium tab that has an 8MM machine Titanium nut welded to the tab. The silencer is hung with a strapless an Aluminum bracket / anodized black and built into the silencer. The silencer sleeve is made of Carbon fiber that attaches to the titanium end caps with stainless aircraft grade rivets and Titanium silencer bands. The inter core tube is made of stainless that slips over the entrance and into the exit cap that is a stamped from Titanium and welded to a 60* slash cut Titanium tube covered with a Carbon Fiber beauty cover.
This system performs like our superbike pipe and shows like jewelry.
- Chuck Graves
Features:
New Diamond Shaped Silencer Design (Carbon Fiber Cans with Carbon End Cap) designed to match the R1's body line.
Silencer mounts directly to OEM rearset bracket using a stealth strapless mount built into the setup.
Constructed from Aerospace grade hi heat Titanium alloys
1 Auto Tuner Style Lambda sensors comes standard (OEM dual sensor mounts up front are eliminated for a smoother flowing exhaust. When using any Graves performance system on the 15-16 R1 Flash Tune products are recommended to enhance the bikes performance everywhere. The most effective tune on this setup does not utilize the stock lambdas at all.
Advanced welding process showcases laser perfection welds
14.4lbs lighter than stock
Performs like a full system, looks like a full system at 50% the cost.
Stock Can + Cat System Weight = 18.8lbs. : Cat Eliminator System Weight = 4.4lbs. (14.4lb. savings)
DB at Idle 90 / DB at 5000rpm 106.5
Fitment: Yamaha R1 2015-2017
gsa013, Yautja and bfrank like this.
www.gravesport.com / www.r1-forum.com / www.r6-forum.com/ Graves Racing Services
Twitter: @SpidermanSS / @Gravesport
Instagram: @SpidermanSS / @Gravesport
KILO 3483 : fastblueR1 : K_FleXXX : GLENN "ELVIS" : Gawarrior : Vman1300 : Bandrews
SpidermanSS is offline
