Tyre pressures for M7RR - Yamaha R1 Forum: YZF-R1 Forums
Yamaha R1 - R1M Suspension Setup, Tires, and Wheels Discuss the Yamaha R1M suspension setups you like most, what tires you are running and other related components.
  • 1 Post By Doppler
post #1 of 12 (permalink) Old 12-20-2016, 12:27 AM Thread Starter
60th Anniversary
I ride mainly twisty roads with 100km+ speeds, Im in Australia and regularly ride in 30 degree+ weather "86F" I have just changed to Metzeler Racetec K3 tyres , The rear got a flat today with less than 1000kms on it which sucks but anyway had to replace it with what my local dealer had in stock which was a Metzeler M7RR, so now have mismatched patterns which I usually don't do but I will see how it goes, anyway what tyre pressures do you recommend I know the RS10's like high pressures, Do you recommend the same with what I have on now. Mainly just aggressive twisty roads no track riding at this stage, Thanks
Glockster is offline
post #2 of 12 (permalink) Old 12-20-2016, 01:46 AM
"What"
Dai.'s Avatar
I run 38psi in each tyre regardless whether it's a touring or sticky tyre.
Sig By Petrol Spice.
Dai. is offline
post #3 of 12 (permalink) Old 12-20-2016, 01:49 AM Thread Starter
60th Anniversary
That would be the rear only yeah? What do you put in the front
post #4 of 12 (permalink) Old 12-20-2016, 01:55 AM
"What"
Dai.'s Avatar
I run the same in the front,never had an issue.
Dai. is offline
post #5 of 12 (permalink) Old 12-20-2016, 02:08 AM Thread Starter
60th Anniversary
thanks man, yeah the rear feels a bit too hard at the moment so will try 38 in it tomorrow
post #6 of 12 (permalink) Old 12-20-2016, 03:56 AM
Doppler's Avatar
That tyre is several steps down from the K3 you have on the front. That's quite mismatched in my opinion.
iamzombie likes this.
Doppler is offline
post #7 of 12 (permalink) Old 12-20-2016, 05:09 AM
The M7RR rear felt slightly soft after running Q3's. As your ambient temps are quite high, maybe 32 to start with.
I'd be careful on that combination. The M7RR will have less grip.
Sent from somewhere using Tapatalk
NZ_R1 is offline
post #8 of 12 (permalink) Old 12-20-2016, 03:51 PM
Kiwi R1's Avatar
Have run them on my M for the past 12 months. 31-32F & 33-35R. They are a very good tyre and underestimated.
Kiwi R1 is offline
post #9 of 12 (permalink) Old 12-20-2016, 03:52 PM
Kiwi R1's Avatar
And that was 16,000 k's getting 2,500ks for a rear and around 4,00 for a front.
Kiwi R1 is offline
post #10 of 12 (permalink) Old 12-20-2016, 05:28 PM
Agreed, I thought the Q3 was a good street tyre until I tried the M7RR. More grip, quicker steering, better wear. About the only negative for me is less feel from the front than the Q3.
One big plus is that the rear grip has stayed consistent as the tyre wore. I've found that most tyres slip a little when down to the last 2-3 mm, but the M7RR still grips like it did when new.
NZ_R1 is offline
post #11 of 12 (permalink) Old 12-29-2016, 06:08 AM
Scots and Proud
I run 36r 36f not as hot a climate as you though, try 34/34 , great tyre by the way, love it
jacobiter1 is offline
post #12 of 12 (permalink) Old 04-27-2017, 10:03 AM
The recommendations confuse me, I'm from Asia and my temp is even hotter than OP's homeland. I assume the higher temp will match higher Psi as the tires need less contact path to heat up? Lower temp will require flatter patch hence less Psi to heat up properly?
r6vn is offline
