HOW TO: Homemade Race Baffles - Page 16 - Yamaha R1 Forum: YZF-R1 Forums
 2Likes
post #301 of 351 (permalink) Old 04-21-2012, 06:27 AM
Fix it till it's broke!
chadthaman's Avatar
Also for whats its worth, I am no longer using the expanded metal. I liked the sound but not totally satisied. so I bought generic exhaust pipe. It was 1 7/8 diameter. then used a transition to 2 1/4 at the end that was cut on an angle to fit against the end cap.
One pipe was left straight. the other has several 1/2 inch holes in it midway down the pipe.
The straight pipe is louder with a higher frequency. the other pipe is deeper but quiter.
I have moded these time and time again, trying to get the best sound. Also even though they are piped the way they are, they both have 4stroke race baffeling material in them. It helps keep the outside of the can cooler. If not, it gets super hot.
chadthaman is offline
post #302 of 351 (permalink) Old 04-27-2012, 09:50 AM
alex84's Avatar
well thanks to Chadthaman i got my home made baffles done and they sound great
Sent from my SCH-M828C using Motorcycle.com Free App
alex84 is offline
post #303 of 351 (permalink) Old 04-27-2012, 06:34 PM
chadthaman's Avatar
Talking
Glad to hear that ALEX84. Enjoy the sound!!!
post #304 of 351 (permalink) Old 05-09-2012, 01:27 PM
chadthaman's Avatar
Talking 2009-2012 models pics
post #305 of 351 (permalink) Old 11-02-2012, 06:47 AM
@chadthaman, can u post the sound for the result yours 2012 race buffle?, how long the buffle and the diameter of yours 2012 racing buffle bro?
thanks, can't wait to watch your vid.
wely is offline
post #306 of 351 (permalink) Old 11-04-2012, 07:55 PM
chadthaman's Avatar
It's the original size of the factory cans. I didn't cut them down and the cat is still in place.
I have to figure out how to post a video so be patient.
Also the trick is to design each can to the sound or tone you want by trying different inner pipe designs.
I learned that if u want loud pipes u will lean more towards a straight pipe design, but with a few holes in the pipe for some sound absorbsion.
I noticed that a straight pipe is loud but has a higher pitch. The more u allow to baffle the sound from the holes, the quiter but deeper tones.
So I have 2 pipes that are not the same for the best sound that I liked. I used large screws to hold the end cap on the pipes so I could disassemble and redesign the inner pipe and baffle with ease until I was happy.
Sent from my Inspire 4G using Motorcycle.com Free App
post #307 of 351 (permalink) Old 11-04-2012, 07:57 PM
chadthaman's Avatar
Also, I just realized that since the last pic I have changed the inner pipes to exhaust pipe with half inch holes drilled in it towards the end.
The pipe in the picture was not loud enough.
post #308 of 351 (permalink) Old 11-06-2012, 01:35 PM
chadthaman's Avatar
Recording
Quick clip. My phone is an old android. It really pics up the high pitches.
post #309 of 351 (permalink) Old 11-23-2012, 06:17 PM
Originally Posted by chadthaman View Post
Hey I'm having trouble piling the internals out.can I get some guidance? Haha
914rr is offline
post #310 of 351 (permalink) Old 11-24-2012, 03:01 PM
chadthaman's Avatar
It is an extremely tight fit. Making sure you have the spot welds cut, use a slide hammer, and IT WILL COME OUT IN MINUTES.
I stress the slide hammer because I spent an entire day trying everything else and still didn't get it.
That slide hammer will screw into a pilot hole that u drill and will pull it straight out.
It also won't damage the can like trying to pry it out will.
Good luck and keep at it, It's worth it.
post #311 of 351 (permalink) Old 11-24-2012, 05:03 PM
You don't impress me.
Saphexus's Avatar
I gotta give this a try...
Nobody said life was easy. Dig your claws into the bedrock, turn against the hurricane and STAND.
Saphexus is offline
post #312 of 351 (permalink) Old 12-23-2012, 08:41 PM
If someone needs stock slip ons for a 09+ I have a set for sale cheap there already gutted out just needs baffles.
914rr is offline
post #313 of 351 (permalink) Old 11-04-2013, 12:20 AM
Awesome post! Thanks. Just got this done, the stock baffles comes out alot easier if you drip some WD40 into the gap and let it settle. Mine practically slipped right out after a few taps with the vice grip method.
lonertic is offline
post #314 of 351 (permalink) Old 11-08-2013, 09:05 PM
nfantbabyjesus's Avatar
how long would you guys guess it takes to complete on a 05?
nfantbabyjesus is offline
post #315 of 351 (permalink) Old 11-12-2013, 02:35 AM
Took me around 5 hours all up...but that's because I didn't have all the tools and I cut/measured/re-cut my perforated steel tube from a 1 meter tube. Ended up costing me around the same as if I just bought the race baffle kits on eBay 'cept those are already cut to size and angle. If you get the precut kits, removing stock exhausts should take about 10mins (seriously easy!!!) and u'd probably spend an hour or two drilling out the rivets and spot welds, then it's smooth sailing from there.
Apparently the 05's uses a 2" perforated tube, and the 07's use a 2.5"... That's the only difference between the year models.
Oh another advice, get some washers with 5mm internal hole diameter. The factory baffles are what the stock rivets rivet to, you'll be removing those and the holes on the titanium skin are way too big to rivet again, that's when you'll need the washers, glue it to the inside of the titanium shell and rivet against the washers instead. The black cone also has a 5mm diameter hole so the washers will be a perfect fit. That's what took me a while because I can't find the right washers so I had to use 3/16" washers and drill it out with a 5mm drill bit. Warped around 20 washers before I finally got my 8 good ones.
lonertic is offline
post #316 of 351 (permalink) Old 01-06-2014, 04:57 AM
Hi from the uk, looking at doing this on my 2004, would both these items be suitable?
http://www.ebay.co.uk/itm/4005289350...042%26_rdc%3D1
http://www.ebay.co.uk/itm/2905820675...596%26_rdc%3D1
Gti-me is offline
post #317 of 351 (permalink) Old 01-11-2014, 04:29 AM
chadthaman's Avatar
Those parts look fine to me.
post #318 of 351 (permalink) Old 01-25-2014, 04:32 PM
NSDQ
Armypeveto's Avatar
Send a message via Yahoo to Armypeveto
Does anyone have a 1' section of 2" perforated tubing left over they would like to get rid of?
Mods: Not enough
R1-015 Ghostrider
My '01 R6 hybrid build
Armypeveto is offline
post #319 of 351 (permalink) Old 01-26-2014, 04:57 AM
chadthaman's Avatar
After all the designs I tried, I ended up with exhaust pipe from the parts store, that I drilled into.
post #320 of 351 (permalink) Old 02-14-2014, 03:48 PM
Nick_Avis's Avatar
I finished my conversion today, used 50mm pope with 3mm holes. Right now it seems unbelievably loud. Maybe things will settle down? This mod is nice and stealthily though so thanks to all the contributions in this thread
Nick_Avis is offline
Re: Baffles/Race Baffles? Jiggaman General Motorcycle Discussions 7 05-09-2008 09:51 PM
Race baffles....homemade! tjstallion General Motorcycle Discussions 2 12-29-2007 02:32 PM
woo homemade race baffles on the 08! XStuNTeR6X General Motorcycle Discussions 0 10-07-2007 02:30 PM
My 07 Race baffles look different... Vigi375 Appearance & Mods 16 03-18-2007 07:14 AM
V&H race baffles.... chief3 Appearance & Mods 2 09-16-2006 11:49 PM
