HOW TO: Check Compression, Valves, SYNC Throttle Bodies & Tune-up - Page 5 - Yamaha R1 Forum: YZF-R1 Forums
 2Likes
post #81 of 108 (permalink) Old 03-01-2011, 02:53 PM
para bellum
Kangaroo's Avatar
saves me from making a new how-to...
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is offline
post #82 of 108 (permalink) Old 03-01-2011, 03:02 PM Thread Starter
Derka Derka Doit For The R1!
Curby's Avatar
It was a lot of work, but well worth it!
BTW, when you doing a how-to for tearing down a 04-06 motor? I can't wait for that.
"I'd rather be sweating, instead of bleeding. Wear your gear!"
Curby is offline
post #83 of 108 (permalink) Old 03-01-2011, 03:04 PM
para bellum
Kangaroo's Avatar
Funny you mention that, I have one in the garage right now that needs a rebuild...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is offline
post #84 of 108 (permalink) Old 03-16-2011, 12:40 AM
how much does a valve job cost if you take it to a shop?
FUR-BURGER is offline
post #85 of 108 (permalink) Old 03-16-2011, 09:48 AM
para bellum
Kangaroo's Avatar
depends on the shop. local economy, dealer vs private, trustable or not...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is offline
post #86 of 108 (permalink) Old 05-15-2011, 01:29 PM
STFU and ride!!
2WEELFERRUM04's Avatar
good stuff
thank you for all the work
lots to read here and learn
2WEELFERRUM04 is offline
post #87 of 108 (permalink) Old 05-16-2011, 06:02 PM Thread Starter
Curby's Avatar
I agree, but the most favorable one is the trustable. Find a good mechanic that does the right job and isn't a hack is most important, well to me anyways.
Originally Posted by 2WEELFERRUM04 View Post
good stuff
Glad I can help.
Curby is offline
post #88 of 108 (permalink) Old 07-06-2011, 04:21 AM
My R1 is wrecked :(
Help the link to the manual doesnt work anymore. Does anyone have another link?
speed_junke is offline
post #89 of 108 (permalink) Old 04-24-2012, 05:27 AM
dmaxr1's Avatar
Thanks for the post, 2 questions
1. I've started the teardown so if I do a compression test now, it will be with a cold engine, how important is it that the engine is warm?
2. Why does the manual say to remove the throttle body but you say it isn't necessary? What is the issue with the throttle body? Will it be difficult/impossible to reach the intakes? with the throttle bodies still there? That is where I got stuck last night because I couldn't find an allen wrench to fit the intake manifold clamps...stopped at Princess A on my way to work to buy more
I know, that was more than two questions, sorry.
dmaxr1 is offline
post #90 of 108 (permalink) Old 05-13-2012, 12:33 PM Thread Starter
Curby's Avatar
Sorry about the delay, i see this was posted a couple weeks ago. But I'll try to help out anyways.
1. If you already started the tear down, you can do a compression test regardless. I recommend doing a compression test on a warm engine to ensure everything internally is well lubricated with oil, and to get the most accurate results while performing the test.
2. Sometimes service manuals give you the most difficult routes to take while working on a piece of equipment. Removing and reinstalling the throttle bodies can be a PITA. But removing the side fairing, and lowering the radiator offers ample room to work with, and a clear line of sight of all the valves.
Hope that helps.
Curby is offline
post #91 of 108 (permalink) Old 06-15-2012, 11:26 AM
dmaxr1's Avatar
So I did encounter 1 problem...mine is an 03 and the procedure is pretty much the same. However on the 03, the motor is much more "in" the frame than on the 04. Getting the valve cover back on with the gasket in place took a lot of wiggling, patience and swearing . I thought that removing the throttle bodies would help, but it didn't. The key was carefully removing the wire ties that are mounted inside the frame. Remove them with care and they can be reused. With those out of the way, the valve cover will fit back into place.
dmaxr1 is offline
post #92 of 108 (permalink) Old 06-19-2012, 01:13 PM
HouseForsaken's Avatar
Thanks for all the write-ups!
Mods: PCIII USB, Boz Brothers Exhaust, Custom LED integrated tail, DDM 6000K 55 Watt HID's, Speedo DRD healer, Factory Pro Velocity Stacks, Gutted Cat, Custom tune by Robs Dyno Service! Watsen Flushies, Joe Florida LED kit, ASV C5's, D3 Grips.
HouseForsaken is offline
post #93 of 108 (permalink) Old 07-22-2012, 12:47 PM
What's a motorcycle?
Silas's Avatar
I recognize that this is a fairly old thread, but I just want to offer my thanks as I'll be executing a valve clearance adjustment and throttle body sync shortly. Your guide is going to be invaluable to me in that endeavor.
Thank you!!!
I have some bikes. I like to ride them.
Silas is offline
post #94 of 108 (permalink) Old 07-22-2012, 08:28 PM
Silas's Avatar
Quick question: I'm about to tackle this job, but it's fairly obvious to me that if one needs to replace shims to adjust valve clearances, the cam shaft(s) will need to be removed. Do you have any EDU steps on this process, mostly to ensure that I do not reinstall incorrectly (out of timing)?
With ~40,000 miles and counting, I'm guessing my valves will, in fact, be out of spec. Also, while I'm in there, should I replace the timing chain? I guess it makes sense if I'm that far into the motor, but I'd rather not have to deal with it if it's not critical at this mileage. The Service Manual is nonspecific about this, so I'm guessing it's fine to not replace it?
Silas is offline
post #95 of 108 (permalink) Old 07-23-2012, 12:44 PM Thread Starter
Curby's Avatar
Yeah, sometimes patience and dropping f-bombs will help conquer a task. lol.
Glad I could help.
Thank you!!!
Glad I could help.
Unfortunately I cannot personally offer any experience on shimming the valves. But I would say regardless of mileage, if you were to discover a valve(s) out of spec, then consult the service manual for which size shim to purchase and install.
The best advice I can offer is taking your time when taking on this task. Especially using the feeler gauges to get an accurate reading to determine what size shim to use.
Hope that helps.
Curby is offline
post #96 of 108 (permalink) Old 07-23-2012, 07:24 PM
Silas's Avatar
Thanks for the response. One other question; is there any reason you can think of why regular old motor oil wouldn't work in the homemade manometer? I built one this afternoon, but the only thing I have handy is some 10w50 motor oil. Sure, I can go buy a bottle of ATF, but it seems like a waste when I have this stuff sitting here. And I can't imagine why it'd make any difference.
Silas is offline
post #97 of 108 (permalink) Old 07-23-2012, 08:20 PM
burnin' up the streets
BSR-1's Avatar
The cams have timing marks on them that line up with arrows on the cam caps (when at TDC). The lower sprocket on the timing chain (under the side case cover) also has a mark that lines up with the split line in the cases.
If you line up all of those items it should be "timed" correctly.
Check it by turning the motor forward slowly by hand a few times and re checking the alignment.
I hope that addresses the question you were asking.
It wouldn't hurt a thing to replace the timing chain but I've not heard of a great deal of them failing either.
I just want to stroke it all the time. (For you BSR
BSR-1 is offline
post #98 of 108 (permalink) Old 07-23-2012, 08:33 PM
My R1 Ra Run Run My R1 Run Run
Rhynocerus's Avatar
Send a message via MSN to Rhynocerus
Holy frakkkkkk thats a write up! Didnt notice it years ago. Amazing job bro!
'08 ReBuild In Progress
Rhynocerus is offline
post #99 of 108 (permalink) Old 07-25-2012, 01:48 PM Thread Starter
Curby's Avatar
I wouldn't use motor oil for a number of reasons. The main ones being oil, which has a higher viscosity than water or mercury. Which will cause it to "stick" easier, thus giving an inaccurate result. And oil will absorb air bubbles much easier, and retain them.
Water with some form of dye in it would be best for a homemade manometer. Mercury is toxic, and a real pain to get air bubbles out of the manometer.
Last bit of information regarding a manometer. DO NOT rev the engine excessively. If you grab a handful of throttle, you risk sucking the manometer fluid into the engine.
Hope that helps.
Thanks buddy.
Curby is offline
post #100 of 108 (permalink) Old 11-17-2012, 06:07 PM
blue blurrrr go zoom
subscribed
r1Totzauer is offline
Throttle Cables to Throttle Bodies dc original 04-06 R1 Mechanical Help 13 01-05-2009 04:43 PM
Throttle Cables to Throttle Bodies dc original Mechanical / Help 4 10-17-2006 03:29 PM
02/03 How to sync. throttle bodies?? DogBoneR1 Mechanical / Help 2 09-19-2005 07:04 PM
2004 sync throttle bodies with tank on? r1nmegofast Mechanical / Help 5 03-18-2005 01:20 PM
Sync the throttle bodies - When to do it -O-P-U-S- General Motorcycle Discussions 19 10-28-2004 11:18 PM
