HOW TO: Install a Translogic Dash - Page 6 - Yamaha R1 Forum: YZF-R1 Forums
post #101 of 381 (permalink) Old 08-25-2012, 07:07 AM
1290!
ebags's Avatar
Originally Posted by markosaspiotis View Post
something new!!! have anyone connect the translogic temperarute sensor wires to the OEM temperature sensor??? is this possible to be done?? and if yes... it will shows the right temperature or not??
Where does it get a temp from now?
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
Colin Chapman
PETROLSPICE ORIGINALS®
ebags is offline
post #102 of 381 (permalink) Old 08-25-2012, 07:35 AM
I'm an Englishman in WI.
Redgecko's Avatar
Both mine and Ben's are here.
Redgecko is online now
post #103 of 381 (permalink) Old 08-25-2012, 08:34 AM
Ride It Like You Stole It!
markosaspiotis's Avatar
Originally Posted by Redgecko View Post
One thing at a time
hahahah
by the way i tested that and nothing... when the oem dash says 45 degrees the TLS says 55 degrees!! so this myth busted...
R1 2006 (SBK project)
markosaspiotis is offline
post #104 of 381 (permalink) Old 08-25-2012, 10:00 AM
1290!
ebags's Avatar
Ah yes, I remember that now.
Colin Chapman
ebags is offline
post #105 of 381 (permalink) Old 08-25-2012, 10:41 AM
Redgecko's Avatar
Bit of extra info, the led will flash when the sensor plug is removed from the tank, so it is getting power from elsewhere too.
With the plug disconnected from the tank, the OEM dash connected and low fuel, the green/white wire has approx 14v at the plug.
Only problem is I have no idea now what this means
post #106 of 381 (permalink) Old 08-25-2012, 10:54 AM
if we test what signal gives the sensor form the tank with the plug removed from it?? what signal it will gives with low fuel in the tank and what with normal fuel???
post #107 of 381 (permalink) Old 08-25-2012, 10:56 AM
i have done the same as Ben and redgecko!!! but iwas thinking if i can connect it to the OEM temperature valve... i tested it and nothing... incorrect signal!!!
post #108 of 381 (permalink) Old 08-25-2012, 11:51 AM
WERA? ¯\_(ツ)_/¯ #21
iGoldeneye's Avatar
Thanks Uncle P!
WERA #21 | INSTAGRAM @igoldeneye21
My 2015 R1M Racebike Build
View my MOD ADDICTED 2012 R1 build thread
Originally Posted by bacchus40
Being a biker is not a welfare sport.
iGoldeneye is offline
post #109 of 381 (permalink) Old 08-26-2012, 08:15 AM
Redgecko's Avatar
Well this is progressing well
post #110 of 381 (permalink) Old 08-26-2012, 09:55 AM
WERA? ¯\_(ツ)_/¯ #21
iGoldeneye's Avatar
[insert famous patience quote here]
At least we know a lot more than we did initially. A lot of the simple theories are now laid to rest now that you are hands on and testing. Thanks to SySt we have someone with expertise to execute a project plan that just might work. Hopefully my Translogic will be here soon and I can be more of a contributor once I rip my bike apart (still my daily commuter). The funny thing is, we aren't the only ones trying to accomplish this; but if we pull it off...
Sent from my iPhone using MO Free
Thanks Uncle P!
post #111 of 381 (permalink) Old 08-26-2012, 04:08 PM Thread Starter
Originally Posted by igoldeneye View Post
Ben-
Your bike is the new garage queen. Hop to it!
I'll let you in on a secret...the day before I crashed I recieved a tub of tank foam. If the fuel level is detected by a float, it's not going to work anyway....
CARBONAR1 is offline
post #112 of 381 (permalink) Old 08-26-2012, 06:07 PM
R1 Forum Star
z064life's Avatar
I can confirm my fuel light on the AIM dash worked......until I added foam
I've since had to coast in twice
Phantom Squadron XO - http://www.r1-forum.com/forums/50-r1-012-%60phantom-squadron%60/
z064life is offline
post #113 of 381 (permalink) Old 08-26-2012, 07:01 PM Thread Starter
I suspected as much.
post #114 of 381 (permalink) Old 08-26-2012, 07:49 PM
R1 Forum Star
z064life's Avatar
At least I made it to or close to my pit both times....PJ tried to get next to me to give me a push on track
z064life is offline
post #115 of 381 (permalink) Old 11-02-2012, 05:06 PM
WERA? ¯\_(ツ)_/¯ #21
iGoldeneye's Avatar
This a thread revival ladies... My Translogic is on the way
Thanks Uncle P!
post #116 of 381 (permalink) Old 11-02-2012, 07:36 PM Thread Starter
Very cool.
post #117 of 381 (permalink) Old 11-03-2012, 11:25 AM
Whats a chicken strip???
TopChef's Avatar
Be patient & you will get it all setup! If you have some basic electrical skills this is not a tough job at all. Finding the ignition coil wire was not easy for me. That is because I didn't know where to look though. After much appreciated help from Ben & Ian, I found it. You are going to need to put your bike on a dyno when you are finished with the installation so that your dash can be calibrated. That is one step I did not see coming. It is possible to do it while riding but it will not be as accurate not to mention it is hard to find a spot long enough to set all of the gears while maintaining a constant speed.
I sent you a pm with my phone number. Call me anytime & as many times as needed. I was blown away at how patient Ben & Ian were when I was installing mine so it's the least I can do to return the favor. I had a ton of questions & they continued to walk me through it until it was done. There were times when I expected them to say buzz off dude
http://i1038.photobucket.com/albums/.../Topchef-1.png
Sig by the one & only Petrol_Spice
TopChef is offline
post #118 of 381 (permalink) Old 11-03-2012, 04:02 PM
WERA? ¯\_(ツ)_/¯ #21
iGoldeneye's Avatar
Thank you sir! I just got your PM and I will be contacting you! This looks like one of those projects that could go a lot smoother with someone who has already been there, done that. I might just get fancy and do a 09-13 Translogic Install How-To
I read in a 2006 thread that a forum member utilized the oil pressure indicator for a low fuel indicator- Has anyone confirmed this to work?
Thanks Uncle P!
post #119 of 381 (permalink) Old 11-04-2012, 05:50 AM
Al3x's Avatar
Sent from my GT-I9300 using Motorcycle.com Free App
If you cant win...... Don't try.
http://www.danasoft.com/vipersig.jpg
Al3x is offline
post #120 of 381 (permalink) Old 11-04-2012, 05:03 PM
Lifetime Premium Member
4yamahas's Avatar
I put a microdash on an 01R6 about 7 years ago . Never pursued getting the fuel guage to work but it sounds like it may be possible .
The dash I have has a fuel indicator , but it has to be set based on mileage . It was more trouble than it was worth . I just keep an eye on odometer and look in the tank like a dirt bike .
4yamahas is offline
Translogic micro dash install help andy_dea Appearance & Mods 41 11-10-2015 08:08 AM
help with translogic dash install and er 1 2 slick+r1=glory Mechanical / Help 0 03-25-2011 04:52 AM
Translogic Micro Dash? nobody General Motorcycle Discussions 3 10-31-2006 02:06 AM
