HOW TO: Install a Translogic Dash - Page 7 - Yamaha R1 Forum: YZF-R1 Forums
post #121 of 381 (permalink) Old 12-06-2012, 08:45 AM
Translogic Dash current gear indicator
Very nice Job!!! Looks killer!!!
Do you know if the 06 R1 has gear indication?
did you connect anything for gear display other than Neutral indicator?
Thanks!
jdgolightly is offline
post #122 of 381 (permalink) Old 12-07-2012, 04:46 PM
I'm an Englishman in WI.
Redgecko's Avatar
Thanks!
The 06 R1 doesn't have gear indication in it's own right obviously but when you connect this dash it will give gear position, :Fact
Here it is in demo mode (click on the pic)
Redgecko is offline
post #123 of 381 (permalink) Old 12-10-2012, 01:19 AM
Originally Posted by iGoldeneye View Post
Since I'm ordering one of these I'm jumping in the mix too... Hopefully I can be of some assistance (probably not really )
So has anyone seen these?
Fuel pump wiring diag.
Our "proposed" solution wiring diagram:
Since we now know this isn't an on-off type of indicator, but more of a "resistance based" schematic, I believe there is a resistor in the OEM dash leveraging how and when the light comes on... Here are more details:
(from G/W wire to dash)
Full Tank Output = 20 to 26 ohms
Empty Tank Output = 134 -140 ohms
(DISCLAIMER: these numbers were pulled from an eletronics website)
We need to know what voltage is required to power the LOW FUEL light on the OEM dash... That way we can get enough variables to plug into the circuit diagram posted above
We can implement pots instead of resistors in the interm to determine what numbers will suffice, then replace the pots with resistors for the final circuit diagram...
I want to investigate further but I'm currently working on a huge project at work; luckily the Translogic is the little reward I'm giving myself for knocking down such an INSANE project
Hi All
i've just noticed this thread,
I installed a Translogic MD3 dash onto my 2002 [5PW] R1 early this year and I too was concerned about the omission of a low fuel warning light
the top wiring diagram is lifted from the R1 circuit diagram
the bottom wiring diagram was from a post i created on a electronics website, a very helpfull chap created the curcuit diagram for me and I even ordered all the component parts, the cost was pennies, about £15 -and that was for double of everythinhg [just incase I messed up!]
that's were the story ends, it'll be one one my winter projects to create the circuit, it'll be tiny [the size of a matchbox] so it'll be easy to place behind ont the side panels
Paul
tornado is offline
post #124 of 381 (permalink) Old 12-10-2012, 08:36 AM
Throw Some D's On It
Toecutter's Avatar
Great job, looks sic!!
Sig by Petrol Spice
"I live, love, and I Slay--I am content."-Conan
"He's a Sultan. The only thing he did different from the rest of us was getting pushed out of a rich p*ssy."--Diazarusmc
History does not entrust the care of freedom to the weak or timid.--Dwight Eisenhower
"I am ripper, I am slasher, I am the teeth in the night!"--Beowolf
"I hope you contact syphilis from the male prostitute you frequently visit and DIE! (How's that for being subtle?)"--ImNotAsCoolAsU
Toecutter is offline
post #125 of 381 (permalink) Old 12-10-2012, 12:24 PM
Thanks for the demo, it looks incredible, however that was a demo of the display, which has capability of gear indicator, but I can't find any details of gear position indication on any R1's prior to 09 years, does anyone have a digital gear indiator like, Datatool, GiPro, etc.? I've not heard anyone state how they work?
post #126 of 381 (permalink) Old 12-10-2012, 12:57 PM
WERA? ¯\_(ツ)_/¯ #21
iGoldeneye's Avatar
Originally Posted by tornado View Post
Hi All
Paul
Thanks Paul and welcome to the forum if you haven't been formally introduced already!
The info you provided deemed to be highly valuable until I received my version of the TL dash... Which didn't include a low fuel wire, but a mileage countdown My 'LOW FUEL' indicator comes on when I'm down to the final 30 miles on the trip meter, which is about when my OEM low fuel light would come on
Hmmm... Not quite 100% sure of the question you're asking, however, the TL dash not only "displays" the gear indicator, but it has one built in, as the dash does not use the OEM gear indicator on the 09+ models. The Translogic gear indicator is programmed when you calibrate the dash initially (you will need to calibrate RPM's, MPH, and gear position) So if your bike doesn't have one, it does once you install the Translogic Dash
Here are some shots of my install... ()
OEM Dash removed
Posi-Taps into OEM Dash Harness
OEM Speed Sensor Posi-Taps
Engine Temp Sensor
Yes, you will pull more than the tank
TL Dash installed...
Thanks Uncle P!
WERA #21 | INSTAGRAM @igoldeneye21
Originally Posted by bacchus40
Being a biker is not a welfare sport.
iGoldeneye is offline
post #127 of 381 (permalink) Old 12-21-2012, 07:50 AM
Epictetus's Avatar
Hope you guys can help...
Down to the last wire on my translogic Dash Install and I can't figure out what to do with the temp wire-
This makes sense and it is what I wish my TL harness came with
However this is what I have-
(see attached image)
That two pin connector is definitely for the temp sensor for the TL wiring instruction and the fact that everything works besides the temp sensor - however I do NOT have the metal tab just a plug? What exactly am I missing or what do I need to do?
any help would be much appreciated Carbon R1!
thanks
Faluire is that scary thing you see when you take your mind of the goal.
Epictetus is offline
post #128 of 381 (permalink) Old 12-21-2012, 02:44 PM Thread Starter
You are missing the temp sensor from your kit. It connects to that plug and gets bolted down like mine.
Contact Translogic and send them that pic, I hope they send it without argueing.
CARBONAR1 is offline
post #129 of 381 (permalink) Old 12-21-2012, 03:04 PM
Epictetus's Avatar
Really? Damn. I knew something had to be missing.
I appreciate the help. Did anyone ever figure anything out on the fuel light?
post #130 of 381 (permalink) Old 12-21-2012, 07:53 PM
WERA? ¯\_(ツ)_/¯ #21
iGoldeneye's Avatar
If you have the latest version, it comes with a fuel mileage countdown. No more useless fuel light indicator wire
Thanks Uncle P!
post #131 of 381 (permalink) Old 12-21-2012, 08:34 PM
Hope is what makes us Human.
Benocehcap's Avatar
I want one so BAD!
“Not every legend is a myth, some are flesh and blood. Some legends walk among us, but they aren’t born, they’re built. Legends are made from iron & sweat, mind and muscle, blood and vision and victory. Legends are champions, they grow, they win, they conquer"
Benocehcap is offline
post #132 of 381 (permalink) Old 12-22-2012, 06:38 AM Thread Starter
They all have a mileage countdown. It's wiring a light to activate as a low fuel warning, that's eluding us!
post #133 of 381 (permalink) Old 02-19-2013, 08:02 PM
Love that Crossplane...
Ironhorz's Avatar
Bump... Just figured I'd bring this one back to the front to see if anyone made any progress on the low fuel warning light debacle.
Thanks Petrol Spice
"Men sleep peacefully in their beds at night because rough men stand ready to do violence on their behalf."
George Orwell
2012 R1 WGP 50th Anniversary #1277 Build
Ironhorz is offline
post #134 of 381 (permalink) Old 02-19-2013, 10:40 PM
WERA? ¯\_(ツ)_/¯ #21
iGoldeneye's Avatar
Well, the guys with earlier versions may have some new discoveries... Us with the newer model only have countdowns; no wire
P.S. My countdown has been pretty spot on set at 130 miles
Thanks Uncle P!
post #135 of 381 (permalink) Old 02-19-2013, 10:47 PM
1290!
ebags's Avatar
WTF what happened to the kick ass James Bond case they used to come in (see first post).
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
Colin Chapman
PETROLSPICE ORIGINALS®
ebags is offline
post #136 of 381 (permalink) Old 02-20-2013, 04:31 AM
Redgecko's Avatar
Robbed
Redgecko is offline
post #137 of 381 (permalink) Old 02-20-2013, 04:47 AM
1290!
ebags's Avatar
Originally Posted by Redgecko View Post
Robbed
Aye....
Still want one though
Colin Chapman
ebags is offline
post #138 of 381 (permalink) Old 02-20-2013, 05:37 AM
Benocehcap's Avatar
some dude as one for sale here on the forums. But my bike is an 01, not sure if its possible to plug it :
post #139 of 381 (permalink) Old 02-20-2013, 06:08 AM
Gearheaded's Avatar
It sold Ben..
Whoody whoody woo!
You pecker head....
R1-016 Venom Squadron
Gearheaded is offline
post #140 of 381 (permalink) Old 02-22-2013, 02:38 PM
Benocehcap's Avatar
Crap!
i signed and still cant see pix
http://www.yamaha-forum.net/forum/showthread.php?t=325
Translogic micro dash install help andy_dea Appearance & Mods 41 11-10-2015 07:08 AM
help with translogic dash install and er 1 2 slick+r1=glory Mechanical / Help 0 03-25-2011 03:52 AM
Translogic Micro Dash? nobody General Motorcycle Discussions 3 10-31-2006 01:06 AM
