Track Bike Help! - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
Trackdays / Schools A place to improve your skills and discuss trackday and riding school events.
post #21 of 32 (permalink) Old 11-12-2012, 03:01 PM Thread Starter
DILLIGAF
diazarusmc's Avatar
Ok I feel like a dumbass. I just remembered that I disconnected the wires that go to the clutch switch. Would you guys suggest going through the trouble to pull those two wires from the harness and connect them as they were just for the function of that clutch switch. Sorry if these are stupid questions but I've never set up a bike for track only use so I got a little happy with the wire removal when I started this last year .
Rain or shine I'm ridin.
R1-016 'Venom' Squadron
"Fat arms are NOT huge biceps, they're fat arms. Cover up"
diazarusmc is offline
post #22 of 32 (permalink) Old 11-12-2012, 03:16 PM Thread Starter
DILLIGAF
diazarusmc's Avatar
Originally Posted by Blue Streak View Post
how fast is it spinning? Take the bike of the stand and if it runs away on you in neutral than you have a problem
I am guessing your clutch might not be fully engaging and maybe that is why you cannot stary it in gear with the clutch pulled in... hard to tell though since you have palyed with the wiring too.
Can you clutch in with the bike running and change gears nornmallY?
I took the bike off the stand and sat on it to see if it tries to pull away in first gear w the clutch pulled in and it didn't so I guess the clutch is disengaging properly. Also I am able to change gears as normal.
post #23 of 32 (permalink) Old 11-14-2012, 04:49 AM Thread Starter
DILLIGAF
diazarusmc's Avatar
Thanks for helping me figure out the kick stand switch everybody. What so you guys recommend as far as the radiator fans? Should I put those back on? Also, do I need to reconnect the clutch switch?
post #24 of 32 (permalink) Old 11-16-2012, 05:49 AM
Want to know what I would do honest to baby jesus?
Get on my bike and hammer the **** out of it for about 5-10 minutes shifting thru every gear and getting everything free, then see if the clutch loosened up from being used, oil when left for a long time can get very very very very tacky and I could easily see the clutch being gummed up and needing to be ridden and having a oil change after, if you put a carbon clutch on it it will drag because the springs are new, and I mean barely stop with your hands fast in fist 5 k later it was perfect.
hawaiian808 is offline
post #25 of 32 (permalink) Old 11-16-2012, 06:43 AM
R1 Forum Star
z064life's Avatar
Originally Posted by diazarusmc View Post
I left it running for a while and then tried it again and I couldn't stop the wheel with my foot. It stopped w the brake and when the brake was released it wouldn't start spinning again. Any idea why I can't start it in gear w the clutch pulled in and the kickstand switch wired to itself?
clutch switch is broke or disconnected if you can't start it in any gear but N.
Phantom Squadron XO - http://www.r1-forum.com/forums/50-r1-012-%60phantom-squadron%60/
z064life is offline
post #26 of 32 (permalink) Old 11-16-2012, 08:33 PM Thread Starter
DILLIGAF
diazarusmc's Avatar
Yeah I remembered that I disconnected it when I was removing the turn signal and horn control. My question is, do I really need to have that clutch switch connected? Also, should I put the rad fans back on?
post #27 of 32 (permalink) Old 11-16-2012, 08:46 PM
Gearheaded's Avatar
Yes on fans!
Also, the whole first gear clutch thing, mines the same.
Can't stop the tire from spinning with clutch pulled in first
Whoody whoody woo!
You pecker head....
R1-016 Venom Squadron
Gearheaded is offline
post #28 of 32 (permalink) Old 11-16-2012, 08:50 PM Thread Starter
DILLIGAF
diazarusmc's Avatar
Ok. So back on with the fans. Someone mentioned I wouldn't need them on there. Can't remember who it was. Anyway, what about the clutch switch wires? Is it necessary to reconnect that?
post #29 of 32 (permalink) Old 11-16-2012, 08:58 PM
RANDOM VICTIM BASTARD S.O.B.
R1_OOKLAH's Avatar
only reconnect if you want to start while not in "N"...its purely up to you and you're preference.
Fans..i would say yes but im no track bike builder, just what i would do.
Originally Posted by Petrol_Spice
But she was a Thai Ladyboy with a 8 inch penis and a hard earnt taste for ass juice.
2010 R1 TRACK TRIM
1997 THUNDERACE #3
2004 R1 INCAPACITATED
PHANTOM SQUADRON #530
Sent from a phone no one cares about using no app to speak of.
R1_OOKLAH is offline
post #30 of 32 (permalink) Old 11-16-2012, 09:03 PM Thread Starter
DILLIGAF
diazarusmc's Avatar
That's what I was thinking. I was just unsure if there was some secondary safety feature or function of the clutch switch.
post #31 of 32 (permalink) Old 11-16-2012, 09:04 PM
FWIW, my bike doesn't have the radiator fans. So, I have to be careful if I'm idling waiting to go out. You don't need them. But, it's a good idea. You might have gotten it from me in another thread.
As to the clutch wires, disconnected.
fjorn is offline
post #32 of 32 (permalink) Old 11-16-2012, 09:09 PM Thread Starter
DILLIGAF
diazarusmc's Avatar
I think ur right Fjorn. It was you . I'll probably just put them back on to be on the safe side. Thanks everyone for all of the advice.
