» Site Navigation |
» Motorcycle Forums
| Off Topic Talk All off-topic posts. Music, Sports, Movies, Humor, etc... (No NWS) |
11-17-2012, 01:37 PM
#3561
Venom GA state lead.
Bikes: 2006 R1
Pretty darn well. I've painted just about every gun I have with it in some form or another.
When I build AR's I'll duracoat Ultra flat tactical black to get the upper, lower, and barrel to all match. Lately ultra flat tactical flat dark earth... It's my new obsession.
I've scraped them on my steel seat mounts and other things putting them in the back of my jeep and it didn't scratch chip or flake... just got a shiny mark there when you look at it at a certain angle in a certain lighting.
Usually do all my camo with it.
If you prep it right and paint it right and let it cure right it's on for life. ...just about.
It's even a b*tch to strip with chemical stripper.
R1-016 "Venom" GA state lead Venom sign-up click here
sig courtesy of Petrol_Spice
"The limits of tryants are prescribed by the endurance of those whom they oppress." -Fredrick Douglas
OE forks w/Ohlins 20mm FPK guts & racetech springs, Penske 8983 shock, susp./geometry set by GMDATL.com, Graves V-Stacks, Graves full system SS w/Ti cans, PCIII w/Ign. Module & QS, Motion Pro throttle revolver, CRG shorty levers, Vortex rearsets (GP shift), AIS delete, SS brake lines.
11-17-2012, 04:32 PM
#3562
MummyMan
Bikes: 1999 r1, 07 GSXR 1k
Not big into handguns and monday gonna go get my hk45ct.
What ammo do you guys recommend? Eventually gonna reload and looking for quality ammo so i can compare a box to reloading equipment/supplies. Hard to compare things and know what to look for when I don't know what is considered good ammo? Any recommendations on brands, grains, type, etc?
11-17-2012, 04:48 PM
#3563
Born Again Patriot
Bikes: 2009 YZF-R1, Raven
Is that the stuff you bake to cure?
SIG courtesy of Petrol Spice in care of InkedR1Pilot
Thanks Uncle P!
R.I.P Marco Simoncelli #58 01/20/87 ~ 10/23/11
R.I.P Andre (Twistgrip)
Ride On Brothers...
11-17-2012, 04:50 PM
#3564
I just use 230gr ball and HP. All federal
From my rooted Nexus 7 sucka
11-18-2012, 02:07 PM
#3565
The Lead Farmer
Originally Posted by huck3631
Just so you dont think im F*cking with ya heres a receipt from a 9/15/2012 purchase i made there
You could get it for that a month ago, can't now.
Originally Posted by Fikays
Kirk is a total chick.
11-19-2012, 06:06 AM
#3566
Hey Jason have you run across anybody that has used this?
http://www.barrettrifles.com/p-1641-...mark-4-m1.aspx
11-19-2012, 08:45 AM
#3567
The Lead Farmer
Originally Posted by WarMachine
I saw one demo'd and it seemed to work as long as things weren't too bad as far as weather.
11-19-2012, 08:47 AM
#3568
I think it's a decent go between with the other system i posted. Still have to use some marksmanship skills, especially with windage.
11-19-2012, 08:51 AM
#3569
The Lead Farmer
I wouldn't use one myself. Trading skill for technology is ok as long as the tech will always be able to be serviced. Using it as a crutch instead of learning the skill properly makes you dependent on it. That I don't like.
11-19-2012, 08:59 AM
#3570
That's understandable, knowing the skill first is definitely better, since tech can, has and will fail.
11-20-2012, 06:32 AM
#3571
Bikes: 2006 R1
No it will cure at room temp. Just don't bang it around while it's curing.
I thing the cure times are:
1 hour for touch
24 hours for reassembly
7 days for general use
30 days for hardcore use and abuse
11-20-2012, 06:35 AM
#3572
Bikes: 2006 R1
I like Federal Hydroshok and HST. Other good choices are Speer gold dot, Hornady XTP and FTX, and Winchester PDX
11-21-2012, 10:50 AM
#3573
I got stanky on my hang down
Bikes: 2004 R1 Silver #1673 (fastest color)
PCIII USB|Yamaha Seat Cowl|R&G Frame Sliders|Greggs Custom Barend Sliders|Intuitive 6MM swing arm spools|CRG Shorty Clutch & Brake Levers|Clear Alternatives Brake/Tail Light Integrator|R&R Fender Eliminator|Harris Grips|High Gear Tech Mount|Puig Dark Smoke Racing Screen|Graves Velocity Stacks|Cycle Gadgets Quick Change Oil Kit|Watsons Flushmount Turn Signals|Custom Race Baffles|Graves Clutch Slider|Acumen Gear Indicator|Racer Solutions Remote Laptimer Kit|Galfer SS Brake Lines|Graves Rearsets
11-21-2012, 03:14 PM
#3574
SuperModerateur
Bikes: 1980 Huffy Santa Fe
Nothing like 70degrees for T'giving holiday. Went to the gun range today and went thru about 1200 .22's and 200 5.56's. My 14-yr old and I play a .22 shooting game that never gets old. We mark a vertical line on the backstop embankment and place 3 golf balls on the line. Then, we each load 25-rd magazines and shoot at the balls. The object is to shoot the balls onto the other guy's side on the line so that when you're done with the 25 shots there's more golf balls on the other side than on your side. A well placed shot, just barely grazing the bottom of the ball at either 4 o'clock or 8 o'clock will send the ball up to 20' in the opposite direction towards the top of the embankment, where it will then roll down the entire embankment and veer to the left or right depending on what it hits.
There's a ton of different strategies. It's great because it's never the same shot twice and the ball always does something different, plus you can screw the other guy by anticipating his shot and shooting a split second prior to him so he wastes his shot. You can even wait until he is concentrating on one particular ball, then shoot one of the other balls, followed by shooting dirt or broken clays, etc... that may be around it to cover the ball and hide it. I had 2 balls on his side that I had hidden and when he finally got the ball he was shooting at onto my side of the line, he couldn't find the 2 hidden balls and had to shoot at piles of debris hoping the ball was in the pile. He was so frustrated he burned up his last 10 shots and never found either of the balls. We had half the people at the range gathering around to watch at one point. Good times!
The 3 golf balls lasted us the whole time, they're nearly indestructible.
11-21-2012, 03:18 PM
#3575
Sounds like fun, get vid if you can next time out
Sent from my Rooted S3 fool
11-21-2012, 03:34 PM
#3576
The Lead Farmer
I'm going to have to try that, sounds like fun!
11-21-2012, 11:47 PM
#3577
my girlfriend likes girls
Bikes: Vman1300's 05 R1
sig by petrol
IRISH RACING
11-21-2012, 11:55 PM
#3578
The Lead Farmer
Looks like a shopping list to me.
11-22-2012, 06:27 AM
#3579
SuperModerateur
It looks like the minimum requirements spec for the common geardo.
11-23-2012, 06:04 AM
#3580
Viva La Figa
Bikes: 03 Liquid Silver
Finally got to shoot my PSA yesterday! It worked flawlessly and only too two adjustments to zero.
200 rounds including 60 rounds rapid fire and not a single hiccup.
"No. You live more for five minutes going fast on a bike like that than other people do in all of their life."~Marco Simoncelli
R1-016 `Venom` Squadron
NESBA #71
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
