Trying to use the highest/furthest back position with my harris rearsets. On the gear changing side I am having problems fitting the shiftrod through the slot in the frame.
When I bought mine, they supplied an additional shift rod (longer & Kinked) for use in the more "extreme" positions - is this the one you're trying to use?
If so, can you give a little more info on the difficulties you're having?
Sent Greg an email, got a response. I should only use the slot in the frame if I am keeping the stock position. Otherwise I should run the shiftrod outside the frame.
Thanks Guys! will let you know how it goes.
Related Threads
6M posts
157.8K members
Since 2001
