Looking for a LINK for installing a Yamaha Cam Chain Tensioner.
How do I pre-tension the Yamaha CCT? Do I need to? Do I need to buy a 'special tool' to do the task of pre-tensioning?
you use your hands and push it in. Then use the the retainger clip, to keep it fully in. Once the tensioner is installed, it will release and tension accordingly.
The 01 only requires a narrow flat blade screwdriver. remove the cap bolt, turn the tensioner clockwise to retract it - when you remove the screwdriver it will typically release, and if it doesn't, a light tap on the outside will cause it to release.
Do the carbs have to come off the bike to make the CCT swap?
157.9K members
