Chains and Sprockets! : Yamaha R1 Forum
SportbikeTrackGear
Old 12-11-2004, 08:39 AM   #1
kspare
My R1 Eats Shoes
Ok, so I can admit I don't know alot chains and what is better. So i'm asking for help from people who do know.
I've heard about the 520 kit and that it's basically lighter and that the stock chain is ok. I've got a 04 r1 and i've dropped a tooth on the front already, so what I want to know, is it worth it to get a better chain over the stock if mine is ok?
What are good sprockets to get? Does weight play a factor with sprockets?
I did do a search too btw, didn't find the answers I was looking for.
I do the 1/4 track once in a while, otherwise I play on the twisties alot, but if I can get more hp outta my bike, i'd like it.
04 Red R1, Full Ti Hindle Race System, BMC Race Air Filter
USB Power Commander, Dynojet Quick Shifter, Custom Painted Windscreen
Passport 8500 Radar, Custom LED Mods
Decked, Ported, Polished Head with Valve Job
Barnet Carbon Fibre Clutch, NGK Iridium Plugs, 40 Shot of Nos
DID Gold X-Ring Chain, Alum Sprockets
Factory Pro Velocity Stacks, Ohlins Steering Damper
Galfer Steel Braided Lines, Nos Purge Valve, Yamaha Solo Seat
kspare is offline   Reply With Quote
Old 12-11-2004, 08:46 AM   #2
joedpr
La Cachucha Feliz 66
joedpr's Avatar
Bikes: 09R1 Cadmium Yellow
Same questions, different year. mine is a '03.
I do roadrace & commute on mine.
Any help would be apreciated
joedpr is offline   Reply With Quote
Old 12-11-2004, 08:51 AM   #3
kspare
My R1 Eats Shoes
From the reading I have done. I've not interested in a 520 conversion. I ride my bike hard.
So what is the best setup for a 530 setup?
Old 12-11-2004, 08:51 AM   #4
kspare
My R1 Eats Shoes
Old 12-11-2004, 08:57 AM   #5
02R1guy
For the Love of.........Riding
02R1guy's Avatar
Bikes: 1979 Kz-650 (sold),1999 Yzf-600r (sold) 2002 Silver R1(sold), 2006 Raven R1
Guys it all depends on you and how you ride. If you clutch wheelies or are quite hard on your drivetrain (tranny, chain/sprockets) then stay with the 530 or stock (also 530)
if you are looking for every last bit of hp or racing etc and/or are smooth to your drivetrain than a 520 from DID or RK is just fine.
I've had awesome longevity with my DID 520 ERV2 and Titan tough sprockets on my 02 and have put 15,000 miles on it and will replace in the begining of the next season just for safety since in all honesty my chain and sprockets aren't showing much wear but I'll replace anyway.
I got less life on my 99 Yzf600r from clutching wheelies
It's up to you
NESBA "I" #77
02R1guy is offline   Reply With Quote
Old 12-11-2004, 09:01 AM   #6
kspare
My R1 Eats Shoes
ok, so I do wheelies and lotsa street racing with buddiees, we frequent the 1/4 track, but we do a few trips to the mountains too, so it sounds like the 530 is for me.
Would I benefit from a new chain over the stock?
Do aftermarket sprockets make a difference? IE. Weight, longevity
Old 12-11-2004, 09:11 AM   #7
02R1guy
02R1guy's Avatar
I'd stay with stock wear/beat that one and then replace it with a slightly better/lighter/cooler looking(gold) one. I kept my stock one on til 8k then replaced and will replace next yeat with around 23k on it
NESBA "I" #77
Old 12-11-2004, 09:17 AM   #8
Kevap
LETS GO RED WINGS!
Kevap's Avatar
Bikes: 05 & 10 Black R1s
Stock sprockets will give you the best longivity as they are STEEL. 90% of aftermarket rear sprockets will be aluminum and will wear alot faster. Sure they will be a little bit lighter... but not worth the cost of replacing them more often IMHO.
Your stock chain and sprockets can last you a long time if maintained correctly. Like 25,000 miles.
sig pic courtesy of THE GODFATHER!
TEAM: SO SCARED NO LEAN
Godspeed to my fallen brothers - elviswarrior, Gawarrior, Vman1300
Kevap is offline   Reply With Quote
Old 12-11-2004, 09:22 AM   #9
bigkvn1
Bulldogger
bigkvn1's Avatar
Bikes: 2004 R1/ 2001 Gsxr 600 Track
I guarentee you can ride the piss out of your bike and not hurt a good 520 setup
Immaculate Motorsports
BDI Insulation
LP USA
WSMC #113
Greggs Sprocket Cover, Greggs Flushmount Signals, Greggs Fender Eliminator, Tail Light Intergrater, GYT-R CF Clutch Guard, GYT-R CF Tank Sides, GYT-R CF Ring Inserts, GYT-R CF Tank Pad, Dynomite CF Airbox Cover, Dynomite CF Rear Hugger, Dynomite CF Front Fender, Puig Dark Smoke Windscreen, Solo Seat Cowl, DynoJet Power Commander IIIusb, DynoJet Quick Shifter, PVM 4 Piston Mono Bloc Calipers, Sprocket Specialist 47-Tooth Rear Sprocket, Brembo 20x19 Radial Master Cylinder, Brembo Brakelight Switch (Front), Galfer S/S Braided Lines (Front/Rear), Blackstone Tek Carbon Fiber Wheels, Galfer Wave Rotors (Front/Rear), TI Rotor Bolts (Front/Rear), Galfer HH Pads (Font/rear), Ohlins R/T Forks w/Superbike Upgrade, Ohlins Rear Shock, Ohlins Steering Damper, Eibach 10.0k/g spring, Graves Full TI Exhaust System (Ovals), Graves Velocity Stacks, Graves Fully Adjustable Rearsets, Graves Clip-Ons, Graves Billet Triple Clamp, Graves Upper Fairing Clips, Graves Reservoir Bracket, Graves Steering Damper (50mm) Bracket, Graves Left Engine Cover, Graves Right Engine Cover, Graves Frame Protectors, Fiber Clutch Plates, Sprocket Specialists/RK 520 Conversion, Harris Clutch Slider, Savanna Systems "ServoSub", Intuitive Rear Spools, Vortex Billet Fuel Base/Cap, BMC Race Filter, Pazzo Racing Brake/Clutch Levers, Renthal Grips, Parts Unlimited Urethane Lines, Cox Racing Radiator Guard, Brembo Rear Reservoir and Bracket
Preperation:
Camshafts Degreed (105/105)
AFM/WERA/CCS/AMA Safety Wired
GMD Computrack Measurement
DynoJet 250i Dyno Tuned (SBK/Prod)
U4 and MR9 maps included.
bigkvn1 is offline   Reply With Quote
Old 12-11-2004, 09:26 AM   #10
kspare
My R1 Eats Shoes
what's a good 520 setup that will handle that then?
Old 12-11-2004, 09:33 AM   #11
AnonymousR1
Track addict!
AnonymousR1's Avatar
Bikes: 09 R1, 03 R1, 04 CRF-50, 06 R6(sold)
-Sig complements of Buddyluv-
AnonymousR1 is online now   Reply With Quote
Old 12-11-2004, 09:35 AM   #12
AnonymousR1
Track addict!
Either the DID Erv2 or the RK GB520GXW, both are very strong 520 chains..
I've got the RK..No problems here..
Old 12-11-2004, 12:17 PM   #13
firehawk2003
Ask the Master Chief
firehawk2003's Avatar
Bikes: Harris R71
DID 520ERV2. Hasn't given me any problems. Put about 1000 pretty hard miles on it so far, and no stretch adjustment yet. I use AFAM alloy sprockets, but a 520 chain combined with a steel or stainless steel (Sidewinder) sprocket would give the best longevity.
firehawk2003 is offline   Reply With Quote
Old 12-11-2004, 12:36 PM   #14
R1LOON
R1LOON's Avatar
Bikes: Liquid Silver 03 R1
Ive got nearly 13000 miles on my stock chain and sprockets, no major wear yet. Would it matter if i just bought new sprockets like Renthal and just keep the stock chain and change it later on? Also ive seen a chain and sprocket set on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.d...MakeTrack=true any idea if there any good?
http://img.photobucket.com/albums/v7...and-border.gif
03 R1 (silver) with a sprinkling of parts and mods to make it that touch better!
138.6rwhp ~ 74.5ftlb Torque..... at the moment!
"I refuse to tiptoe through life only to arrive safely at death"
"a good friend would bail you out of jail,a best friend would be the one sitting next to you saying " damn that was fun"
R1LOON is offline   Reply With Quote
Old 12-11-2004, 12:43 PM   #15
02R1guy
02R1guy's Avatar
No replace together with that kind of mileage since both are worn equally. If you put a new chain on old sprockets or vs versa it will wear the new part at a faster rate since the parts like to together.
not a good idea to do just 1
NESBA "I" #77
Old 12-11-2004, 12:50 PM   #16
R1LOON
R1LOON's Avatar
Thanks for the advice, i was thinkin if i dont go for the SSS chain and sprockets in the ebay link (if there any good or not) to go for 530 renthal sprockets with a DID gold x ring chain. 530 coz i do clutch ups, although im as smooth as i can be still would rather have the heavier duty one.
Old 12-11-2004, 12:53 PM   #17
R1LOON
R1LOON's Avatar
Sorry guys another question for ya, what chain grease, wax or lube do you use for your chains? Ive been using putoline chain and sprocket lube, it seems to keep the chain in good condition but it goes everywere, i.e all over my rear wheel and on the under side of my seat.
Thank again
Old 12-11-2004, 01:00 PM   #18
Lestat77
Lestat77's Avatar
Bikes: 04 R1
If you go with a hard anodized rear aluminum sprocket from Sprocket specialist or AFAM you'll get good wear out of them. They also drop a considerable amount of weight over the stock steel rear sprocket. A pound maybe 2Ibs.
Personally I'd just change the sprockets.
Lestat77 is offline   Reply With Quote
Old 12-11-2004, 01:24 PM   #19
02R1guy
02R1guy's Avatar
I have tried a bunch of lubes and like Honda chain lube and Motul chain lube
NESBA "I" #77
Old 12-11-2004, 02:09 PM   #20
NSDQ
Racing is everything
NSDQ's Avatar
Bikes: Thompson Metalcraft Unlimited Edition 04 R1
I don't race, I'm primarily a street rider, and I don't clutch wheelies, but I opted to keep things stock for longevity. The only thing I will replace once a year (or more) will probably be tires. As far as weight reduction goes, I bought an exercise bike.
"I must study politics and war that my sons may have liberty to study mathematics and philosophy" - John Adams
RIP - Kelly "K-FleXXX" Brown - 6-15-2006 - I will be riding with you soon, my friend, but not yet. Not yet.
If you are able, save for them a place inside of you and save one backward glance when you are leaving for the places they can no longer go. Be not ashamed to say you loved them, though you may or may not have always. Take what they have taught you with their dying and keep it with your own. And in that time when men decide and feel safe to call the war insane, take one moment to embrace those gentle heroes you left behind. - Major Michael Davis O'Donnell
Sig courtesy of Jimi DeFlanko
NSDQ is offline   Reply With Quote
