Slipper Clutch : Yamaha R1 Forum
Old 12-31-2004, 11:22 AM   #1
thecraw
l337 R1
thecraw's Avatar
Bikes: 04/R1 Silver
Slipper Clutch
I know the main reason for getting one is to limit the back torque on down shifting, which Ive run into many times on the track, thus why Iam considering getting one..
But my question is this, will installing the slipper clutch make doing power wheelies or clutch wheelies harder to do ?
thanks
thecraw is offline   Reply With Quote
Old 01-01-2005, 10:03 AM   #2
thecraw
l337 R1
thecraw's Avatar
Bikes: 04/R1 Silver
bump
Old 01-01-2005, 02:12 PM   #3
Shadow R One
Off Topic mod
Shadow R One's Avatar
Bikes: 04 Ducati 998s FE
I dont know but I doubt it...
Ah, the elusive balance point...the G-Spot of wheelies if you will.
The early bird gets the worm but the second mouse gets the cheese
http://www.r1-forum.com/gallery/wate...php?file=17141R.I.P. FastblueR1 7-13-03
Shadow R One is offline   Reply With Quote
Old 01-01-2005, 02:27 PM   #4
Lespaul66
2006 R6R and new 2008 ZX10R
Lespaul66's Avatar
Bikes: 2005 ZX-10R and 2006 Yamaha R6R and 2009 R1 after few months
thanks
I would like to instal also STM slipper cluth but this is the reason I must think about it...
I dont have any experience but I suppose that there will be greater risk to flip up...normally the big engine and high compression ratio cause a large engine braking when shutting the throttle...same thing which is not good during hard front wheel braking and cause rear wheel bounching - but which is good if the FRONT wheel comes too up....
Lespaul66 is offline   Reply With Quote
Old 01-01-2005, 02:33 PM   #5
xdonniedarkox
yield
xdonniedarkox's Avatar
Bikes: 2002 R1 #335 red/white livery
Nope it wont...
Asked if he was afraid of dying in an accident, Marco Simoncelli responded: "No. You live more for five minutes going fast on a bike like that, than other people do in all of their life." rip #58 ciao ciao bello
the art of the moto: The Trench Plate Diaries
xdonniedarkox is offline   Reply With Quote
Old 01-01-2005, 03:18 PM   #6
04R6Limited
04R6Limited's Avatar
Bikes: 2004 Yamaha R6 Silver
No. If you are on throttle it will act normal. When you get off the throttle and are still in gear it will engauge and allow the rear wheel and motor to spin on their own also allowing you to downshift with out touching the clutch. upon giving it gas it will let go and power the rear tire again as normal.
04 R6 Liquid Silver Mine on 7-3-04, GYT-R slip-on, GYT-R V-Stacks. More to come for next year.
I think I broke myself. 10-30-04
http://memimage.cardomain.net/member...9/735329_3.jpg
04R6Limited is offline   Reply With Quote
Old 01-02-2005, 12:57 AM   #7
Lespaul66
Lespaul66's Avatar
yes
Yes... but how about the potential flip up problem as I described ???
Old 01-02-2005, 02:48 AM   #8
Redrocket996
flipper
Redrocket996's Avatar
Bikes: Ducati 996s (stolen) + 2003 R1
Re: yes
This is a problem and I have first hand experience of this. I had a slipper clutch fitted when my bike was serviced and the garage also messed about with the fuelling. The end result was on my first ride after getting it back I wacked it up in first and due to the new fuel mapping the front jumped up really erratically I rolled of the throttle to bring the front down a little as I normally would but............................................... .........it kept rising and flipped me off backwards. I've now got used to the clutch and the fuelling problem has been fixed but it certainly makes wheelies harder. I now have to use the back brake more.
Now I've got a question here and I don't mean to hijack the thread but this sort of runs on from your question. How much back brake can you use if the front is coming up too fast before you lock the back wheel up? I am really paranoid about locking the back wheel on the brake whilst the front is in the air.
Redrocket996 is offline   Reply With Quote
Old 01-02-2005, 09:59 AM   #9
2fasst
2fasst's Avatar
Bikes: R6
Re: Re: yes
Your front end would be long down already before that happen
Anti-bling
2fasst is online now   Reply With Quote
Old 01-02-2005, 07:07 PM   #10
XFACTOR
D= V x T
XFACTOR's Avatar
Bikes: 04` R1
I installed a Yoyodyne slipper clutch........never noticed any difference in the front end being "harder" to bring up, or "pop" up unintentionally, feels the same.....but I have so much more entry speed going into turns with the confidence of not having the rear end getting squirrelly when down shifting. One of the best mods. I"ve ever done, to any bike I"ve had
2009 CCS Mid-Atlantic and SouthEast
Amatuer Champion
Unlimited Superbike
Unlimited GP
XFACTOR is offline   Reply With Quote
Old 01-02-2005, 10:36 PM   #11
thecraw
l337 R1
thecraw's Avatar
Bikes: 04/R1 Silver
Thanks for all the response guys, Also my next question would have been what slipper clutch do you recommend, I see xfactor uses Yoyodyne, is there other brands that I can compare with..
Thanks again for the help
Old 01-02-2005, 11:14 PM   #12
Looneybomber
Until it sleeps
Looneybomber's Avatar
Bikes: Red 99' R1 15,900miles Tranny doesn't shift :-( '03 Black cbr600rr
I'm wondering about wear. How long will these clutches last before needing to be rebuild (new plates and fibers ect) My clutch has 16k on it and it works great.
Full arata, Ivans airbox mod, BMC filter, SS galfer. (thanx R1@150) Ivans jetkit, DID VM530, Sprocket Specialist 42t, 01' front end, GP shift, ZG black screen, flushmounts (not installed) & clear tail lights
Looneybomber is offline   Reply With Quote
Old 01-03-2005, 04:09 AM   #13
Ponykiller
Mustang Hater!
Ponykiller's Avatar
Bikes: '05 R1
Well the whole idea about a slipper clutch is that when the rear wheel drives the engine, the clutch will either disengage completely, or slip some - depending on the "strength" of the engine braking. By strength I mean a high rpm/low gear compared to a low rpm/high gear. The first combo would be stronger engine braking.
So, the clutch is going to slip more. Fortunately, we have wet plate clutches. This means slipping a clutch won't burn it up like in a car (dry plate). Short answer: slightly more wear, but worth it if you want to ride on the track.
For those of you who don't understand exactly how a slipper clutch works, take a few minutes to search for a diagram. I could describe it, but without a diagram you won't really understand.
Ponykiller is online now   Reply With Quote
Old 01-03-2005, 04:31 AM   #14
Redrocket996
flipper
My slipper clutch is a sigma clutch for a Ducati 996 and I was told to expect between 4000 and 6000 miles depending on how hard I used it.
Old 01-03-2005, 11:02 AM   #15
thecraw-r1
167.38 rwhp
thecraw-r1's Avatar
Bikes: 2004 R1 Silver/2005 MV Agusta 1000 Corsa
Ive been looking around the only ones I find are the STM, I Have 04 R1
I read on the forum someone mention JOS/Yoyodyne, but I cant find it anywhere for the R1
WSMC # 568
LP Carbon Fiber Frame Sliders/Clutch/Handlebar/Rear Spool, Custom Led Tailight, Rear peg brake LEDS, Greggs Flush mounts, Power Commander PC3 USB, BCM Air Filter, Zero Grav DB Dark Smoke Windscreen,Termignoni Carbon Cans TI Half System,Velocity Stacks,GYTR CF Lower Trim,GYTR CF Exhaust Shield,GYTR CF tailhugger/Chainguard,Ohlins Steering Dampner, Yoyodyne Slipper clutch,Galfer Stainless Steel brake lines Front/Rear, Afam 16 tooth sprocket, CRG Shift/Brake Short Levers, Custom Map, Ohlins YA-343 Rear shock, Ohlins R/T Forks, Marchesini Gold forged Mag wheels, DID erv3 520 Conversion, Veypor VR2 computer. Shark Race Skinz. Gilles quick chain adjusters, Barnett CF Clutch Kit, AIM MXL Pista Logger/Display
thecraw-r1 is offline   Reply With Quote
Old 01-03-2005, 11:11 AM   #16
2fasst
2fasst's Avatar
Bikes: R6
that's it? 4-6K? I wonder if the STMs last longer? I know they do cost more.
Anti-bling
Old 01-03-2005, 03:31 PM   #17
XFACTOR
D= V x T
XFACTOR's Avatar
Bikes: 04` R1
call Fred at Yoyodyne, got mine for$795
http://www.yoyodyneti.com/default.aspx
Amatuer Champion
Unlimited Superbike
Unlimited GP
Old 01-03-2005, 04:41 PM   #18
thecraw-r1
167.38 rwhp
thecraw-r1's Avatar
thanks
WSMC # 568
Old 01-03-2005, 09:41 PM   #19
xdonniedarkox
yield
Fred is a great guy and has a very experienced perspective on racing, and all things included.
Old 07-28-2010, 07:54 PM   #20
illrohan
RavenR1der
Bikes: '07 R1
slipper clutch wear
I've got just over 7k on my clutch and this is the third season I've been one wheelin' it. No sign of any slipping yet. Also, as far as flipping the bike back... I love the slipper clutch. When I get off the gas a little to bring it down, it lands on air. When I had my 2000 R1, it would slam down so hard I snapped the mount for my headlight assembly. A few times I thought I'd fractured the rim it landed so hard.
illrohan is offline   Reply With Quote
