Can't put in gear! : Yamaha R1 Forum
Graves Motorsports
Old 01-25-2005, 12:12 PM   #1
Calvin_Blue_R1
Zleeepin' 02 Blue R1
Bikes: Blue O2 R1
Unhappy Can't put in gear!
Hey fellow riders, I have a problem with my 02 R1. My bike is near new as I seldom ride it since I'm in and out of the country (US) for most of the time. I have my family start up the bike on the stand every week but when i brought it down from the stand and started her up, it will go into gear but would stall for some reason. Any idea at all? My bike has less than 2000 miles on it and have changed the motor oil at around 500 miles. I try to take good care of her but I guess she's mad at me for leaving her for so long (been about a year now). Any mechanical help or advice is greatly appreciated fellas. Thanks a bunch.
Regards,
C.
Calvin_Blue_R1 is offline   Reply With Quote
Old 01-25-2005, 12:16 PM   #2
R0N1N
R0N1N's Avatar
Bikes: 2004 R1
Is the kickstand down? Sounds like the kickstand switch. Or maybe check you clutch.
http://www.r1-forum.com/gallery/data...8signature.jpg
current mods:
Factory Pro Velocity Stacks | Puig Dark Smoke Windscreen
16/45 sprocket combo | Race Baffles | Shogun Sliders
R0N1N is offline   Reply With Quote
Old 01-25-2005, 12:47 PM   #3
Droog
Do or do not, there is no try
Droog's Avatar
Bikes: Yamaha R1 (2000)
Yeah kickstand switch.
By the way, don't periodically start the bike. Change the oil and filter, get a trickle charger, fill the tank, add stabalizer and let it sit. Constantly starting it ( Without a proper ride to fully bring it to temperature ) does more harm than good.
"Time is never wasted if you're wasted all the time"
Droog is offline   Reply With Quote
Old 01-25-2005, 12:50 PM   #4
Calvin_Blue_R1
Bikes: Blue O2 R1
Ronin, thanks for the speedy response! I don't think it's the stand as I was ready to ride off after warming up and it was up. Just once i step it into 1st gear or whatever gear (2 too) it will just choke. If it was the kickstand how can i check? Also how can i check the clutch, shoot i don't even know where's the clutch Sorry a bad mechanic and a beginning rider
Old 01-25-2005, 01:03 PM   #5
yzfgirl
What day is it?
yzfgirl's Avatar
Bikes: '00 R1, '99 1200XL & '04 VRSCB
Well, if it is not the kickstand switch, then I would guess if you didn't have fuel stabilizer in it and it has been sitting for a year - chances are the gas is bad.
yzfgirl is offline   Reply With Quote
Old 01-25-2005, 01:09 PM   #6
Calvin_Blue_R1
Bikes: Blue O2 R1
what is that stabalizer? Is it some additives for the fuel/gas tank so it doesn't rust? What if i let it idle till it's dry?
Well i don't think it's the gas because the bike starts up just fine, just that I can't put it in gear thanks for everyone's help so far.
Apppreciate it
C.
Old 01-25-2005, 01:21 PM   #7
chuckh
MY R1 ATE THE BANK!
chuckh's Avatar
Bikes: 99 R1 track 2008 R1 in Red and White.....
If its running till you try and put it into gear then the clutch has locked up !!!!
I IS THE JESTER 99 R1 Track Bike in black... 2008 R1 in Red And White ....................
chuckh is offline   Reply With Quote
Old 01-25-2005, 01:24 PM   #8
Calvin_Blue_R1
Bikes: Blue O2 R1
anyone know how I can unlock the clutch? Any easy way? Like banging on some parts? Hahah it only hurts when you laugh...anyways, that's what I thought too.
So 2 things i should check, the kickstand switch and the clutch lockup.
More research!
Old 01-25-2005, 01:30 PM   #9
Helix007
You will die alone
Bikes: 2k Are Won
im thinking your clutch is rusted or dried up, i would also drain the gas out and refill it with some fresh gas...gas is only good for a couple months AT BEST..i'm amazed it started at all...it is probably all gummed up in your fuel system...
Helix007 is offline   Reply With Quote
Old 01-25-2005, 03:42 PM   #10
Droog
Droog's Avatar
Apppreciate it
C.
I meant for general storage. Your fuel tank is just that. A tank for your bikes fuel, not a fuel storage tank. Fuel breaks down over time into varsol. Kind of bad for your engine. Stabalizer helps stabalize the fuel.
Old 01-25-2005, 08:27 PM   #11
camaro 22
I love fast things
camaro 22's Avatar
Bikes: 03 R1 99 GIXXER 600
My clutch was recently locked up from sitting so long. As soon as I put it in gear, it just cut off. If it's your clutch, try this. With the bike off and in first gear, hold the clutch in and push the bike. If the bike don't move then your clutch plates are locked up. Just let the bike warm up, turn it off and repeat the first gear pushing to force the plates free.
Shawn
2003 Silver and Black R1
Chrome wheels, Yoshimura Stainless exhaust, LED undertail, Led front signals, Harris R1 grips, LP RED levers, RED Bar ends, RED gauge face
Other rides
1997 Z28 Vert- Fast w/ many mods
1999 Durango- Custom
camaro 22 is offline   Reply With Quote
Old 01-26-2005, 10:20 PM   #12
BSR-1
burnin' up the streets
BSR-1's Avatar
Bikes: 05 Raven #8734, 2011 S1000RR
well?
was it the clutch plates?
or the sidestand/clutch switch?
the curiosity's got me.
Originally Posted by marcaztls View Post
I just want to stroke it all the time. (For you BSR )
BSR-1 is offline   Reply With Quote
