Carb sync adapter ? : Yamaha R1 Forum
Motorcycle.com
Old 02-07-2005, 07:16 PM   #1
Lonnie
R1-4FUN
Bikes: 2000-R1
Carb sync adapter ?
Is there any problem with leaving the adapters in the engine & using small vacuum plugs to cap off these tubes instead of removing them.
Syncronizing the carbs would be rather fast if the tube replacement was not involved.
If you did this, did you use the o-rings for seals or the brass washers?
Thanks in advance for any info.
Lonnie Pavtis
Lonnies Performance Automotive
Lonnie is offline   Reply With Quote
Old 02-07-2005, 09:17 PM   #2
telerider
Revelation 1:69
telerider's Avatar
Bikes: 04 R1 BABY!!! faster than raven
i did that to my 01 and it worked just fine
telerider is offline   Reply With Quote
Old 02-08-2005, 08:14 PM   #3
Ben99R1
Bikes: 1999 R1
pm martinc. I think he left the adapters on. Also if you check the carbtune website the sell extra adapters just for that reason.
If anyone need to get bailed out of jail give me a call 323 893-7042
Ben99R1 is offline   Reply With Quote
Old 02-08-2005, 08:16 PM   #4
Droog
Do or do not, there is no try
Droog's Avatar
Bikes: Yamaha R1 (2000)
Good idea, I don't see why not?
"Time is never wasted if you're wasted all the time"
Droog is offline   Reply With Quote
Old 02-08-2005, 09:02 PM   #5
Lonnie
R1-4FUN
Bikes: 2000-R1
Thanks guys,
I appreciate the info.
It would be well worth the cost of the adapters to never have to remove & replace them. I may actually check the carbs a few times a year since it will be easier to do.
Lonnie Pavtis
