» Site Navigation |
» Motorcycle Forums
03-29-2005, 05:37 PM
#1
Bikes: 05 Raven
Sticking shifter
Finally got warm enough to start breaking my 05 R1 in and have one issue, sometimes when I shift up or down the shifter seems to stick all the way up or down till I let the cluch out I've got 594kms on it is this a normal issue for break-in?
03-29-2005, 06:17 PM
#2
I got stanky on my hang down
Bikes: 2004 R1 Silver #1673 (fastest color)
Re: Sticking shifter
My 04 did it as well, it does go away. If it does it when stopped try rocking foward a bit. If it's doing it while you're driving then it may be something else.
PCIII USB|Yamaha Seat Cowl|R&G Frame Sliders|Greggs Custom Barend Sliders|Intuitive 6MM swing arm spools|CRG Shorty Clutch & Brake Levers|Clear Alternatives Brake/Tail Light Integrator|R&R Fender Eliminator|Harris Grips|High Gear Tech Mount|Puig Dark Smoke Racing Screen|Graves Velocity Stacks|Cycle Gadgets Quick Change Oil Kit|Watsons Flushmount Turn Signals|Custom Race Baffles|Graves Clutch Slider|Acumen Gear Indicator|Racer Solutions Remote Laptimer Kit|Galfer SS Brake Lines|Graves Rearsets
03-29-2005, 08:15 PM
#3
smooth=fast
Bikes: Blue 06 R1 -ya know the blue ones are faster
Check for enough clearance between the shift arm and the case. If you have move the toe position recently you may have pushed it on to tight. Should see .005-.010.......of course there is that wheelie-gone-bad that dropped on that side and mashed it in ya?
04-03-2005, 04:02 PM
#4
Bikes: 05 Raven
I've never adjusted the shifter but I checked just in case of assembly error but the shifter isn't binding up on anything the on thing I did notice is that it does is more often when the trans is not under much load like if Im slowng down, drop it down a gear the shifter will stay down till I let out the clutch!
04-03-2005, 07:08 PM
#5
Bikes: None Currently
i had some trouble with the shifting last summer. Came to find out my shift rod eyelet was frozen. You might wanna make sure the eyelets are still free by twisting the shift rod back and forth with your index finger and thumb, it should move pretty much unbound.
RIP my friends: Airknight, Brian, K-flexx, and Dxextreme..
Please ride safely, the street is no proving ground
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
