To soak or not to soak? : Yamaha R1 Forum
Graves Motorsports
Old 07-19-2005, 05:12 PM   #1
rvpimp
Live fast or die slow!
rvpimp's Avatar
Bikes: 2003 r1 Limited edition
I'm replacing my burned out cluch fibers after an embarrising mishap at the track... They are K series Barnetts. Do I need to soak them overnight and does anyone know if these are any better than the regular $70.00 EBC's? Thanks in advance.
rvpimp is offline   Reply With Quote
Old 07-19-2005, 07:04 PM   #2
Tony C SBFMC
Bikes: 05 R1
yes soak them and as far as ebc I run them and like it
GYTR Carbon Pipes, Smog block offs, Angel Eyes, Factory Pro stacks,Vortex spockets, RK chain, GYTR air filter, PC3, GYTR head and base gaskets, BRG fuel pressure mod aka fuel pill, Rossi Graphics Kit, Smoked Headlight gaurds. Mild port and polish, Custom front sprocket cover
Tony C SBFMC is offline   Reply With Quote
Old 07-19-2005, 07:32 PM   #3
Wheat
//Low-Life\\
Wheat's Avatar
Soak em....
Wheat is offline   Reply With Quote
Old 07-19-2005, 08:39 PM   #4
rvpimp
rvpimp's Avatar
Thanks guys, soaking has commenced...
Old 07-19-2005, 08:49 PM   #5
martinc
martinc's Avatar
Bikes: 99 R1/07 1098S TRE
I dont soak mine,I just rub them with new oil very well.
Saves time,does the job.
martinc is offline   Reply With Quote
Old 07-19-2005, 09:20 PM   #6
LDHR1
see you at the races and ride
LDHR1's Avatar
Bikes: 2005 R1,2001 R1 just sold
tell us more about the fuel pill, I used to vary fuel pressure to tune my LT1 camaro. I always wondered if that option was available for the R1. I remember eyespy's post about the R1 needing 35% across the board on his bike. Just the thing for fuel pressure mods. What is your current pressure?
see you at the races and ride safe.
LDHR1 is offline   Reply With Quote
Old 07-20-2005, 07:45 AM   #7
Tony C SBFMC
Bikes: 05 R1
I got the fuel pill from BRG in walnut creek, CA they did all the tuneing I frogot the fuel preasure I have all the paperwork at home I will let you know when I get off work its only like a $20 mod but then you need to do some new mapping
