Temperature : Yamaha R1 Forum
Old 09-20-2002, 09:51 AM   #1
don_Reyno
less writing, more riding
don_Reyno's Avatar
Bikes: 2002 R1 Silver
Just a quick question-
What temperature does your bike normally run at in traffic? Every time I am stopped at a traffic light and the outside temperature is somewhere between 85 - 95 degrees, my bike's temperature goes through the roof...constantly between 200 and 220 degrees. Is this normal? Does this happen to everyone's bike?
Akrapovic Full Evolution carbon can, PCIIIr, Scotts damper, Boxr Ram air, Graves Velocity stacks, BMC air filter, Intuitive Frame Sliders, Zero gravity DB windshield, Home made fender elimiantor w/led turn signals, Gregg's flushmounts, OEM seat cowl, Graphic art silver gauge
don_Reyno is offline   Reply With Quote
Old 09-20-2002, 12:55 PM   #2
bluer101
The Blue One's are FASTER!!!!
bluer101's Avatar
Bikes: 2001 R1 Blue
Thats normal, here in Florida mine in traffic ranges from 214-226, and at 220 the fan comes on.
The highest my bike has gone was 238, stuck in traffic on South Beach, Miami.
MODIFICATIONS:
Akrapovic C/F Slip-on Exhaust | Dussault Undertail | Dussault Flush front turn signals | Dussault rear LED Flux turn signals l Libertek F1 flasher l Ohlins steering damper | blue R1 RPM gauge | custom matching Blue Pit-Bull swingarm stand | R1 gas cap logo | YAMAHA solo seat | PIAA Super Plasma GT headlight bulbs | CATZ Hyper Bright Brake LED's | Scorpio SR-i500 Alarm.
bluer101 is offline   Reply With Quote
Old 09-20-2002, 03:23 PM   #3
kpyzfrwon
Once u go turbo u never go bac
kpyzfrwon's Avatar
Bikes: 1998 turbo R1 and Blue 04 on order
If you are really concerned about the temp just splice a spst(single pole single throw)switch...$2.99 local radio shack into your fan switch that enters your radiator. I use this exact setup on my turbo r1 AND Redline's Water Wetter and my bike rarely goes over 195 EVEN in 100 degree summer heat.
In other words simply flip the switch when u feel its getting to hot. CAUTION: just don't forget to turn it on at a stoplight in the middle of August!!!!
kpyzfrwon is offline   Reply With Quote
Old 09-20-2002, 05:22 PM   #4
Shadow R One
Off Topic mod
Shadow R One's Avatar
Bikes: 04 Ducati 998s FE
Just be carefull, you dont want to over cool the engine.
The engines are designed to operate at certain temperatures so if you cool them too much then the tolarances will be off
Ah, the elusive balance point...the G-Spot of wheelies if you will.
The early bird gets the worm but the second mouse gets the cheese
http://www.r1-forum.com/gallery/wate...php?file=17141R.I.P. FastblueR1 7-13-03
Shadow R One is offline   Reply With Quote
Old 09-20-2002, 05:37 PM   #5
turnone
turnone's Avatar
Bikes: 2002 Yamaha R1, really fast blue
i live in vegas and in stop and go it will be between 215 and 226 or so fan kicks on at 220 and its good.. i get going and it will drop below 200 easy... its NORMAL
turnone is offline   Reply With Quote
Old 09-21-2002, 12:45 PM   #6
R1 JUNKY
Enjoy yourself bitches!
R1 JUNKY's Avatar
Bikes: R1 2001 Faster Blue option
I don't think theres any chance of over cooling a R1 sitting at the lights with the fan on,try grabbing the exhaust besides the motor dose have a thermostat, you know, that thing that doesn't let any coolant through until it's at the right temp.
R1 JUNKY is offline   Reply With Quote
Old 09-21-2002, 01:10 PM   #7
Shadow R One
Off Topic mod
I am talking about the people that wire up a switch to turn on the fan whenever they want
With the switch, the thermostat is bypassed
Old 09-21-2002, 01:31 PM   #8
Limited R1
Limited R1's Avatar
Bikes: 2001 Champion Edition R1 #815
Mine runs up to 224 at the lights but the fan kicks in and cools it down preety quick.
http://www.r1-forum.com/gallery/data...066BANNER2.gif
Champion Limited Edition
Akrapovic Full System
Ivan's Jet Kit
Ivan's airbox mod
K&N filter
Ohlins Damper w/Harris mount
520 conversion DID gold 16/45
Intuitive Sliders
Self made Clutch Slider
Self made Radar detector mount (stem stand)
Escort 8500 detector
Garmin Zumo 550
Limited R1 is offline   Reply With Quote
Old 09-21-2002, 05:41 PM   #9
ShaSha
ShaSha's Avatar
Bikes: I've been de-fanged
Yep, I don't think you have anything to worry about. Mine runs like everybody else's: 200-225 (fan kicks in at 220) in stop-n-go, 185-200 on the move !
ShaSha is offline   Reply With Quote
Old 09-21-2002, 05:59 PM   #10
winders
No stunts and no posing!
winders's Avatar
Bikes: '03 Kawasaki ZX-6RR
Shadow One,
The thermostat is mechanical on the R1 and all bikes I can think of. With a switch, the thermostat is not bypassed. Actually, if the switched is installed properly, nothing is bypassed. All that is done is the rider can turn on the fan if he desires. On the '02 R1, the Coolant Temperature Sensor reports the coolant temperature to the ECU. If that temperature reaches a certain value, the fan is turned on.
The thermostat on the '02 R1 is designed to open when the coolant is in the 160 to 185 degree range. If the fan is left on and the coolant temperature gets below 160 degrees, the thermostat will close and no coolant from the radiator will flow into the engine.
The only way to get the coolant too cold, would be to remove the thermostat from the thermostat housing. This would cause the coolant to flow through the radiator at all times.
Scott
winders is offline   Reply With Quote
Old 09-22-2002, 07:24 AM   #11
don_Reyno
don_Reyno's Avatar
Thanks for the input guys, I feel a lot better now...
Old 09-22-2002, 02:41 PM   #12
R1 JUNKY
R1 JUNKY's Avatar
Fan switch bypasses the thermostat? ,i think not my friend
Thanks Winders for taking the time to explain that to shadow one
I get sick of having to reply to people who don't know what their talking about
