» Site Navigation |
» Motorcycle Forums
Oil and Lubrication For discussion on oil and lubrication
11-21-2005, 04:48 PM
#1
Track bound.
How to Change Your Oil FiveOh style.
I was just changing my oil tonight and it dawned on me that I have a few little tricks to make the most of the change. So, why not share them with my forum brothers? This applys directly to '02-03 R1s, but it should also work on the current generation. Regardless, test to make sure that the bike will crank without starting before dropping the oil!
Here goes:
First off you want the bike hot. So run it standing still until the fan kicks on (~220*), then shut it down and get right to work. This assures that the oil is as thin as it gets in order to drain as much as possible. Most people know this, but it's worth mentioning. Go ahead and drain the oil and remove the filter. Wait until the oil stops. Make sure your bike is in neutral.
Now with the filter and drain plug still out comes the first trick. Put the bike into diagnostic mode. While holding both buttons on the cluster turn the key to run. Continue to hold down the buttons until it displays "diag". Release the buttons and then press and hold them again until it says "d01:xx". In diagnostic mode the fuel injectors are disabled. Crank the bike for two 5-6 second bursts, with a rest in between, and watch how much more dirty oil comes out. Mostly from the filter boss.
Another common trick is to pre-fill the filter with oil. Do it! Pour it right up to the brim and wait for it to soak into the media. Then fill it up once more. Reinstall the filter and drain plug. Pour in the remainder of the oil amount spec'd in the manual. Cap it and then do the diag trick again. Cranking once more for about 6 seconds. This assures the the filter and the rest of the oiling path is primed and ready to go. Turn the key off, then back on again to clear out of diag mode. Start the bike and run it for about 15 more seconds, shut it down and wait 1 minute or so for the oil to settle. Then top off according to the window.
Hope this helps!
11-21-2005, 04:53 PM
#2
X_Infantry
Bikes: 05 R1 - 06 WR450 Supermoto
Sounds like a good plan to me - just not so sure about running the bike for 15 sec with no oil ?
11-21-2005, 04:57 PM
#3
Track bound.
You aren't running the bike. When it is in diag mode displaying "d01:xx" the bike will not fire. Put the kill switch to off if it make you feel better. You are mearly cranking the motor, no harm done.
11-21-2005, 05:07 PM
#4
X_Infantry
New info for me - Never heard of it being done but does should like a great idea..
11-21-2005, 05:29 PM
#5
Akrapovic xplane
Bikes: 09 R1 Raven
 I will give it a try...thanx
sig courtesy of Petrol Spice
Nearly all men can stand adversity, but if you want to test a man's character, give him power! - Abraham Lincoln
Lucky 13th Squadron
11-21-2005, 05:34 PM
#6
GET OUT!
Bikes: 07 R6
I have a question. I'm kinda new to bikes and is there any special oil filter wrench I should use or just channel locks with a towel over the teeth.?
E85 ADDICT
Originally Posted by yescubanb2000
Ive seen some pretty horrific things in my life but those hairy tits just made my stomach turn.
11-21-2005, 05:40 PM
#7
Track bound.
The local parts store should have ratchet drive filter wrenches that go over the end of it. Strap wrenches work too. Channel locks will get it off, but you needd to make sure it's on tight, and channel locks are a no-no for that.
11-21-2005, 05:50 PM
#8
GET OUT!
Bikes: 07 R6
Thats why I was askin. I have a normal wrench that I use to change my Evo's oil, but I don't think it will reach on the bike. Plus, I'll probably burn my hand trying to get the oil filter off and on. Is there any technique to put the filter on so when I tip it to put it on I don't spill oil?
E85 ADDICT
11-21-2005, 06:03 PM
#9
Track bound.
If you fill the filter up twice, it should just about absorb enough that it wont spill. The filter goes on horizontally, so you can't leave too much in there.
11-21-2005, 06:07 PM
#10
GET OUT!
Bikes: 07 R6
Thanks man, you been a real help. I usually figure out things by trial and error, but I don't wanna mess up anything.
E85 ADDICT
11-21-2005, 06:32 PM
#11
Bikes: 04 R1 (#14, blue stock now black-raven )
Here is a tip if you are looking for something to take off your oil filter with. I have a '04 and it doesn't have much clearance between the filter and the exhaust, so a strap or one of these (image below) works great. If you can't find one I know snap-on carries them.
Oh and one more thing you forgot to mention is to put a light coat of oil on the rubber seal around filter before installing it.
11-21-2005, 06:36 PM
#12
Track bound.
Yup, I debated on whether to mention it or not. Couldn't decide whether to just tell my tricks, or full blown how-to.
11-21-2005, 06:49 PM
#13
I just figured I would mention it. Some guys might have never changed their oil before, and will try doing it based on what is on this tread. It is actually really simple to do; maybe the hardest thing to do is take off the lower plastics and figure out how to take off the filter without getting 3rd degree burns on your hand (oh gloves help also around the pipes). If I remember correctly it tells you how to do it in the manual.
11-21-2005, 07:11 PM
#14
Like The Rising Phoenix
Bikes: 2005 R1..............(2000 R1 SOLD)
my trick for not getting burned..... remove fairings... start bike.... turn off bike.... remove drain plug... and filler cap.... then let oil drain and pipes cool.... then remove filter with above mentioned oil filter wrench.... haven't been burned once doing in that way
Specs: 2005 R1....
147.5..... Stock Dyno Run.....
155.9..... After Mods.....
Awards: 2nd Place 2005 Ken's Dyno Shoot Out
Mods: Harris Grips And Tank Protector/Intuitive Frame & Clutch Sliders/GYT-R Spools/LP Carbon Fiber Triple Tree Cover/GYT-R High Flow Air Filter/Graves Full Ti Exhaust With Round Mufflers/Dynojet PC III USB/Sam's Survo Sub/Factory Pro V-Stacks/Graves AIS Plates/OPP Racing Carbon Fiber WSBK Ram Air Ducts/Tyga Race Glass/Color Rite Paint/Ohlins Steering Damper/Attack Rear Sets/Graves Race Fairing Stay w/Quick Relese Plugs/Custom Haga Replica Graphics/CRG Shorty Brake Lever/CRG GP Clutch Lever&Perch
Things To Come Soon: Ohlins Rear Shock With Graves Spec Valving/STM Slipper Clutch/520 Chain Coversion
Nesba #41 (I Class)
11-21-2005, 07:49 PM
#15
Bikes: 2004 YZF-R1 and more
WTF do u guys have huge ass monkey hands or something... i've had no problem not getting my hands near the pipes. Besides a few burns will toughen ya up for the future ;-)
The Mummy Rulez
11-21-2005, 07:51 PM
#16
You know what they say big hands, Big...
Gloves
11-21-2005, 07:52 PM
#17
what big hairy patches on the palms to go with them
LOL
The Mummy Rulez
11-21-2005, 07:54 PM
#18
Rezident Cynic
Bikes: Red '04
ok so I asked the monkeys at eh yammy steelership about prepping the oil filter before putting it on, and I was told not to put any additional oil on it, and to just put it on dry. Can't remember why exactly but I do remember they told me specifically not to prime the filter with oil before I put it on. Are they full of shit again?
11-21-2005, 07:59 PM
#19
Well I typically prime the filter before putting it on. I usually don't put a lot in but I have always done it that way I don't see why it would hurt to prime the filter. However they are not talking about the rubber seal that should always be done.
11-21-2005, 08:00 PM
#20
Track bound.
I can't believe they told you that. If you leave it dry there will be a 2-3 second delay before any oil gets to the top end.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
