» Site Navigation |
» Motorcycle Forums
11-26-2005, 01:17 AM
#1
ohhh yeahhh baby
Bikes: Black/Flame 2003R1
sweating reservoir tube
Hi
my 2003 R1 has been in a heated and dehumidified garage for the last month, unused - too cold and icy! Its also under a sheet, when I checked over it the other day the front brake reservoir connecting tube was coated in blobs of brake fluid which upon wiping off seemed to be a much darker colour. I think the fluid may have leached through from inside the tube to the surface.
Its not the original tubing, it is the longer tube that came with the Gilles Vario bar handlebar kit.
Could it be that they have supplied me with some crappy tubing?
seems strange that I have been using the bike over the summer and not had this problem before.
Any ideas?
Ian
2003 Black w/Red Flames R1
Akrapovic Carbon slip-on
Custom stainless fender eliminator
Gilles Vario-bars
R&G, lots of
Mini alloy indicators
Yokes dropped 5mm
Scotts damper
11-26-2005, 02:25 AM
#2
Bikes: 98,1/2. R1
is it clear hose? if so they ALL sweat!
11-26-2005, 02:51 AM
#3
Beware of Subaru Outbacks!
Bikes: RIP 04 R1, totaled '94 Ninja ZX6
but would it sweat in a heated garage?
11-26-2005, 07:10 AM
#4
ohhh yeahhh baby
Its black rubber. So this has happened to other people then. There is no safety issue I presume?
Gilles Vario-bars
R&G, lots of
Yokes dropped 5mm
Scotts damper
11-26-2005, 09:00 AM
#5
Action figure sold separately
Bikes: Red/White/Black 2004 R1 (track), Silver 2004 R1 (street), Red/White/Black 2000 R1 (track), 1987 FZR 1000 (street), 2000 black white and chrome Harley Davidson FLHTPI , 2002 XR400, 2002 XR50 (x2)
I would replace the tubing with one that doesn't suffer from this problem. The Brembo tubing (available from the yoyodyne website) has always worked best for me.
11-26-2005, 12:56 PM
#6
Bikes: 98,1/2. R1
its the first ive heard of black hose sweating, make sure the hose on barb angle is correct and clamps are tight, if all else fails get genuine hose. btw its not really a "safety" issue but might damage paint etc.
11-26-2005, 01:40 PM
#7
I've seen inferior black hose do it, and worse, actually swell and contaminate the fluid within it.
11-26-2005, 02:15 PM
#8
7 More Days 'til the '09 Debut
Bikes: 2002 R1
I would say it's a safety issue; if the fluid can leach out of the tubing then air and moisture can leach into the fluid (the air and moisture that the brake fluid absorbed from the atmosphere is why the brake fluid on the outside of the tubing was darker) and contaminate it. Brake fluid will absorb any moisture in the air that it is exposed to which will make your brake fluid more compressible and compromise your braking abilities. If you haven't ever experienced this before then count yourself luck because it is very unpleasant and depending on the situatin can be very scary as well.
I'm with the other on replacing the tubing with some quality stuff that won't have the same problem; you probably can't go wrong with the Brembo stuff.
Sharkskinz fairings; Puig light smoke screen; Graves swingarm spools, clutch,frame sliders, & triple clamp (black); Intuitive bar sliders (black); Lightech 1/4 turn race fuel tank cap (silver); PCIIIUSB; Scorpion Extreme C/F exhaust; BMC filter; CRG adjustable brake lever (silver); LED tail light integrator; EXUP removed; radiator fan override switch; Pitbull stands.
Coming Soon: Custom exhaust mounting bracket and TZ250 tailsection conversion!
11-26-2005, 02:28 PM
#9
Foggy Rules
Bikes: Silver/Gray 02
actually my Brembo clear hose is holding up rather well, no sweating since I switched to zip ties. Its even been out in sub zero (F) weather for a couple days, than brought in doors, and still didn't sweat.
all the problems I originally had with the clear yoyo tubing I created-
1. over tightened screw type band clamps put minute slits in tubing causing sweating
2. in an effort to get a more pliable rear section, I seperated the coextruded tubing
I'd still like to find some of the blue/green tubing that didn't sweat, or require changing bi-monthly
I have noticed since I started using clear that after a season the fluids appear darker, no longer clear, like weak tea, I assume its from heat cycles & UV exposure. Never noticed it before with black tubing
11-26-2005, 02:39 PM
#10
Bulldogger
Bikes: 2004 R1/ 2001 Gsxr 600 Track
From what I understand, you are correct!
Immaculate Motorsports
BDI Insulation
LP USA
WSMC #113
Greggs Sprocket Cover, Greggs Flushmount Signals, Greggs Fender Eliminator, Tail Light Intergrater, GYT-R CF Clutch Guard, GYT-R CF Tank Sides, GYT-R CF Ring Inserts, GYT-R CF Tank Pad, Dynomite CF Airbox Cover, Dynomite CF Rear Hugger, Dynomite CF Front Fender, Puig Dark Smoke Windscreen, Solo Seat Cowl, DynoJet Power Commander IIIusb, DynoJet Quick Shifter, PVM 4 Piston Mono Bloc Calipers, Sprocket Specialist 47-Tooth Rear Sprocket, Brembo 20x19 Radial Master Cylinder, Brembo Brakelight Switch (Front), Galfer S/S Braided Lines (Front/Rear), Blackstone Tek Carbon Fiber Wheels, Galfer Wave Rotors (Front/Rear), TI Rotor Bolts (Front/Rear), Galfer HH Pads (Font/rear), Ohlins R/T Forks w/Superbike Upgrade, Ohlins Rear Shock, Ohlins Steering Damper, Eibach 10.0k/g spring, Graves Full TI Exhaust System (Ovals), Graves Velocity Stacks, Graves Fully Adjustable Rearsets, Graves Clip-Ons, Graves Billet Triple Clamp, Graves Upper Fairing Clips, Graves Reservoir Bracket, Graves Steering Damper (50mm) Bracket, Graves Left Engine Cover, Graves Right Engine Cover, Graves Frame Protectors, Fiber Clutch Plates, Sprocket Specialists/RK 520 Conversion, Harris Clutch Slider, Savanna Systems "ServoSub", Intuitive Rear Spools, Vortex Billet Fuel Base/Cap, BMC Race Filter, Pazzo Racing Brake/Clutch Levers, Renthal Grips, Parts Unlimited Urethane Lines, Cox Racing Radiator Guard, Brembo Rear Reservoir and Bracket
Preperation:
Camshafts Degreed (105/105)
AFM/WERA/CCS/AMA Safety Wired
GMD Computrack Measurement
DynoJet 250i Dyno Tuned (SBK/Prod)
U4 and MR9 maps included.
11-26-2005, 03:20 PM
#11
Ghostrider Squadron XO
Bikes: 02 R1
 i've heard the same thing
11-26-2005, 11:22 PM
#12
Bikes: 98,1/2. R1
ahh i stand corrected on the sweat thing, hmmm, now to solve the discoloring thing then.
11-27-2005, 04:23 AM
#13
ohhh yeahhh baby
Could I replace it with a cut out section of my old original brake hoses?
Gilles Vario-bars
R&G, lots of
Yokes dropped 5mm
Scotts damper
11-27-2005, 04:30 AM
#14
Bikes: 98,1/2. R1
just buy new hose its cheap as dirt.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
