Tuning ???? (sorta long) : Yamaha R1 Forum
SportbikeTrackGear
Old 12-07-2005, 08:48 PM   #1
05raven r1
05raven r1's Avatar
Bikes: 05 black r1, 04 r6 (track)
I have an 04 r6 that I am in the process of setting up for the track and have been trying to do some research into the actual tuning process. First off I was going to do a baseline so I can get an idea where she stands. I already have the mods(haven't installed anything yet):
full graves, velocity stacks, air filter, slide stops, pc3, as well as a couple other minor things.
I really wanted to do the tuning myself but have a limited knowlegde of the process. I'm familiar with pc3, I've installed dozens of them and understand how they work but don't have any in depth experience custom tuning them. I'm pretty quick on the learning curve so that won't be a problem. I've spoken to several different people and everyone always has something different to say. What I wanted to do was install a wide band commander from dynojet and tune it based on that info. I already have the wbc. I understand that optimum A/F ratio does not equal power but is there an A/F ratio where that does exist?
Is there any one out there who thoroughly understands fuel injection tuning and could lend a little advice?
TIA
05raven r1 is offline   Reply With Quote
Old 12-08-2005, 12:03 PM   #2
bryan niles
performance first
bryan niles's Avatar
Bikes: 2005 Raven, 2010 Raven
Re: Tuning ???? (sorta long)
TIA
The optimum A/F ratio for power is about 12.6-1. Do not try to tune the bike with the wbc alone. The wbc is for fine tuning on the track. The best way to tune your bike is to go to a good tuner with a dyno and tune the bike on the dyno. This will be responsible for about 90-95 % of the tuning. The las bit is for 5the wbc on the track.
PERFORMANCE- Sato full Titanium exhaust with MOTO GP carbon fiber Titanium cans- Gold Sato rearsets- Bmc race filter - Factory pro velocity stacks- Pc3USB- Powercommander Ignition module- secondary throttle plates removed- Brembo 19x18 radial master cylinder- DID 520 ERV3 conversion kit- RRP rear sprocket- Attack Performance magnesium triple clamps- Braking wave rear rotor- JG1 custom map- Gilles chain adjusters and lifters- Galfer stainless steel black front & rear brake line- Scotts oil filter-graves fibers-yec clutch springs-Galfer Superbike Wave Rotors-Ohlins damper-Active quick turn throttle billet black-Over adjustable racing linkage-Krankvent-Yec fuel regulator!
COSMETIC- Pro bolt and Yoyodyne titanium bolts and nuts on entire bike- Puig double bubble screen- Graves smog plates- Greggs customs black sprocket cover- Greggs customs black mirror block plates- Greggs customs black license plate bracket- Greggs Satin black fairing plugs- Factory yamaha billet engine case cover- Woodcraft case covers- CRG silver gp perch clutch lever- Gytr clutch guard- Speedohealer- Shogun clutch slider- Shogun black bar ends- Shogun black swingarm sliders- Motowheels red oil cap and drain plug- Rizoma black anodized front and rear brake reservoir- Agras red front axle sliders-Yoyodyne frame sliders-Samco red coolant hose kit-Evolution Composites Carbon Fiber tank cover and panels!
more to come!
bryan niles is online now   Reply With Quote
Old 12-08-2005, 12:05 PM   #3
bryan niles
performance first
here is another chart
more to come!
