STM clutch : Yamaha R1 Forum
Graves Motorsports
Old 12-20-2005, 09:14 PM   #1
PanR1
PanR1's Avatar
Bikes: Yamaha YZF-R1 2004
STM clutch
Hey guys I have a problem with my 2004 R1 that appeared the last 3 days and I am lost. I have recently installed on my baby a slipper clutch by STM, and since then the gears became stiffer. The problem though is that when I rev the bike and I up-shift quickly sometimes the gears seem to jam and the clutch lever is half empty when I pull it back to change gears again. Thus I have to stop the bike and try to find neutral to have the gears back in place! Any help pls is more than welcome...
R1 Rules !!!
PanR1 is offline   Reply With Quote
Old 12-20-2005, 09:18 PM   #2
xdonniedarkox
yield
xdonniedarkox's Avatar
Bikes: 2002 R1 #335 red/white livery
Contact Vahakn. He lives on Cypress and knows them. PM him and good luck
Asked if he was afraid of dying in an accident, Marco Simoncelli responded: "No. You live more for five minutes going fast on a bike like that, than other people do in all of their life." rip #58 ciao ciao bello
the art of the moto: The Trench Plate Diaries
xdonniedarkox is offline   Reply With Quote
Old 12-21-2005, 03:48 AM   #3
.04r1.
Are you sure it's installed correctly? For example, if you remove the clutch basket, you need to be sure you align it with the oil pump drive gear when you put it back on. Also, be sure to use the thrust washer after that- there's no mention of this in the instructions. Lastly, there are 3 pins that align the drum stopper hub and the hub. These aren't in the instructions or even on the parts diagram! Worse, my pins were in the bottom of the box, underneath the cardboard.
.04r1. is offline   Reply With Quote
Old 12-28-2005, 10:52 AM   #4
Vahakn
Vahakn's Avatar
Bikes: 2003 Silver R1
the fellow forum member has been contacted and problem fixed
R.I.P. K_FleXXX June 15, 2006
Vahakn is offline   Reply With Quote
Old 12-28-2005, 10:59 AM   #5
Redrocket996
flipper
Redrocket996's Avatar
Bikes: Ducati 996s (stolen) + 2003 R1
For future reference, what was the problem?
Redrocket996 is offline   Reply With Quote
Old 12-28-2005, 11:35 AM   #6
xdonniedarkox
yield
right on Vahakn...
Old 12-28-2005, 11:42 AM   #7
Vahakn
Vahakn's Avatar
the last clutch fibre plate was installed wrong. the correct way is to stack it inline with the rest of the pack(all fins in the same groove of the clutch basket), and not rotated on the clutch basket.
Old 12-28-2005, 10:01 PM   #8
Azsportbiker
R1 Brian
Azsportbiker's Avatar
Bikes: Red 04 R1 LE 99 R1 Sold
Vahakn,
I had PM'd you back requesting a set of instructions to install my STM on my 99. I never heard back from you. It doesn't look too bad, but I want to find where all of the little balls go. Im not around a Fax very often, and if you had the chance, I would gladly pay for the directions if you could email me them.. I also remember you saying you are a dealer for these, I would like to see about purchasing one of the STM diagpram springs on your recomendation. I currently have a Barnett 6 spring conversion, and dont have any springs other than that. Thank you very much for your time..
Im also not familiar with where Cypress is.. Is that in the states ?
P.S. For those reading, I did not purchase the slipper from Vahakn, I got it off Ebay, and it didnt have the directions. He was nice enough to respond to a post, and PM me..
Thanks again,
Brian Azsportbiker@aol.com
Red 04 LE..Termi Slipons and Y pipe,FactoryPro Stacks, BMC Race Filter, PC with custom Ledesma Map..Ohlins RT Forks,Ohlins rear shock,and damper, Marchesini Gold Forged Alluminum wheels,Vortex adj rearsets,Vortex Black anodized sprocket,Goodridge braided lines and Galfer HH pads,DID ERV3 520 chain,GC Flushmounts, CRG Roll-a-clicks in black,Puig tinted DBscreen,Speedo Healer, Dunlop Qualifiers,Graves AIS blockoffs, and a fat man riding it
Azsportbiker is offline   Reply With Quote
Old 12-28-2005, 10:02 PM   #9
xdonniedarkox
yield
Cypress is near Greece close (kind of) to Italy...
Old 12-28-2005, 10:05 PM   #10
terrence
Ahhh, Southwest Winters...
terrence's Avatar
Bikes: '04 R1 in red
This kinda sh*t gives me goosebumps
What a freakin forum
terrence is offline   Reply With Quote
Old 12-28-2005, 10:06 PM   #11
Azsportbiker
R1 Brian
Sweet.. No wonder he knows about STM's..
These really look like a well made, and designed product.. I cant wait til I get to use mine
Old 12-28-2005, 11:17 PM   #12
Vahakn
Vahakn's Avatar
Originally posted by Azsportbiker
Vahakn,
Thanks again,
Hello there Brian
we have not scanned the instructions yet. the small steel balls should go onto the first layer of the clutch system at the bottom. you should use a bit of greese and install them on the magnesium colored base of the slipperclutch. there are small holes if u may that go across the direction of the base of the system. it sucks not to have a scanner. let me take a pic of the paper and trasnfer the pic to my PC. Rergarding the spring, The STM slipperclutch for the 03 modeldoes not have a spring included in the kit. it uses the original spring from the bike itself. You may however purchase a secondary spring to fine tune the slipperclutch. the more powerful the spring tension, the more engine braking while the slipperclutch is in action. i have it on my bike and did not install the secondary spring. it's mostly for road use anyway. the secondary spring is mostly suited in the track where u realy push the limits of the bike and u trail brake. We are in the process of becoming forum sponsors to help the members out with info and sales. We are importers of the brand and we supply to dealers. we do retail to customers and wholesale to dealers. The admin of the forum will inform all of our progress in the sponsorship.
Old 12-28-2005, 11:47 PM   #13
Vahakn
Vahakn's Avatar
thanks for the support bro i love this forum.
Old 12-29-2005, 04:36 AM   #14
.04r1.
Are you sure? This is the first I've heard of it- No surprise, since STM's instructions suck.
Old 12-29-2005, 04:46 AM   #15
turd1
turd1's Avatar
Bikes: 98,1/2. R1
did you end up using ramair on your bike?
turd1 is offline   Reply With Quote
Old 12-29-2005, 04:48 AM   #16
Vahakn
Vahakn's Avatar
the Slipperclutch was designed with the original clutch pack of the R1. the total thickness of the pack (fibres, and metal plates) should be at 43mm. We usually recommend the customer to purchase a fresh pack. we have always prefered graves clutches since it eliminates the 2 metal rings on the original one. We always make sure the last fibre plate is installed exactly like the rest of the pack, and not resting on a separate groove on top of the clutch basket. the actuation of the STM slipperclutch is a bit stiffer on the clutch lever. eliminating the 2 metal rings of the original greatly improves the feel of the clutch. yes i agree with u regarding the instructions, but that's what we are here for
Old 12-29-2005, 06:08 AM   #17
Azsportbiker
R1 Brian
I agree !! Thanks so much for the info, I think I am closer now to it..The small steels are the only ones I am unsure of now.. I found a couple great pics when I did a search.. I do appriciate the help !
Blur.. I do have a Ram air on mine now. I am about to get my flatslides on. For some reason the bigger motor didnt like the stock air box up on the top end..
Old 12-29-2005, 06:12 AM   #18
turd1
turd1's Avatar
Bikes: 98,1/2. R1
cool i thought i remembered somewhere you were selling a ramair box? maybe you were buying one? i couldn't remember! ..
Old 12-29-2005, 06:15 AM   #19
Azsportbiker
R1 Brian
I thought of selling mine for a little while.. I was going to start putting my ol gal back to stock.. Then I said screw it, and started buying things again !
Its allready an animal, I cant wait to try it with the carbs, and the slipper
Old 12-29-2005, 06:26 AM   #20
turd1
turd1's Avatar
Bikes: 98,1/2. R1
i can at least vouch for the slipper
