throttle body jammed please help?? : Yamaha R1 Forum
Motorcycle.com
Old 03-04-2006, 12:23 AM   #1
righthooks
scrapen it!
righthooks's Avatar
Bikes: 05 yamaha scrapen it
i was wondering if you guys could help me with something...i recently crashed my bike and i am in the process of puting it back together....its in nuetral when i start it....when i start it...it sounds like im pulling on the throttle...but im not...so i was thinking my throttle body is jammed or something...what would i do to un jam it or...is it broken?? please help
righthooks is offline   Reply With Quote
Old 03-04-2006, 12:29 AM   #2
korrupt1
working on that new bike
korrupt1's Avatar
Bikes: Trek 4200...not as fast as the R1
lift the tank....examine the throttle bodies and associated hardware and inspect for any damage...loose or missing parts....etc.....replace and retune
korrupt1 is offline   Reply With Quote
Old 03-04-2006, 12:32 AM   #3
righthooks
scrapen it!
righthooks's Avatar
if the airflilter/air.intake tubes arn't connected sucurely to the throttle body(not tight)...would that cuase it to do that??..because everything else looks fine.?? please help..thanks alot
Old 03-04-2006, 12:48 AM   #4
wfoR1pilot
Obama in the Whitehouse? ??
wfoR1pilot's Avatar
Bikes: '03 R1 '02 FZ1 '05 R1
Not sure I understand: It sounds like when you start it, it revs like you're twisting the throttle, no?
First I would check to make sure the throttle/grip is in the closed position. Next I would check to be sure there are no kinks in the cables. After that I would check to be sure the cables are both connected on the throttle bodys. Finally, (if the others don't work) take the throttle apart (at the grip, not the throttle body) and do the "push / pull" test on it to be sure it is moving correctly.
Some more info from you (what is it really doing) might help!
BSR
'01 929RR(Black/Yellow)(Sold)
'02 FZ1 (Race Blue)(Sold)
'03 R1 (black/flames) (Sold)
'05 R1 (no color specified)(Sold)
'02 Silver ///AMG(Sold)
'08 Prius (Black)
'07 R1 (Red)
Rome did not create a great empire by having meetings, they did it by killing all those who opposed them.
RINN: "I felt something move... you know down there.." clicky
wfoR1pilot is offline   Reply With Quote
Old 03-04-2006, 12:53 AM   #5
righthooks
scrapen it!
righthooks's Avatar
hey thanks alot for your help....yes i disasembled the throttle hand mechanism thingy..and the wire is hooked just fine..im thinken my throttle body is jammed... ....but i dont know what to look for to know for sure..can u help...thanks alot..seriously
Old 03-04-2006, 12:56 AM   #6
korrupt1
korrupt1's Avatar
starting to sound like a jammed a jammed butterfly assembly...but dont quote that..
if your intakes are looking good then I would go farther into the throttle bodies and check out the butterflies and the main assemblies there in.
Old 03-04-2006, 01:04 AM   #7
righthooks
scrapen it!
righthooks's Avatar
hey thanks alot....ok ill have to check that out...how easy do these throttle bodies break?....i crashed it..but the initial impact was not that hard...just a long slide.... everything around and on the engine looks untouched...but i know some stuff could have got shaken around...from just pulling the tank the throttle bodies look fine...should i take the throttle body off completely?
Old 03-04-2006, 01:07 AM   #8
korrupt1
korrupt1's Avatar
just check em before removing anything!!
I crashed mine pretty good New Years Eve...and she came out fine....mine took a 100 yard slide with me in tow right behind her....and came out fine....but if you had a hard enough impact a butterfly COULD have gotten stuck open....cehck to see if they have easy and fluid movement...if not then think about removing....I dont take anything off unless absolutey needed.
Old 03-04-2006, 01:13 AM   #9
righthooks
scrapen it!
righthooks's Avatar
hey thanks alot for your info...what exactly is the butterly?(sorry )?....if the fluid isnt runing it would cuase it to do that?....
>reply<...ya my crash started at 75mph and i only had a t-shirt on it sucked real bad...and i know what u mean by sliding along with your bike...lol
Old 03-04-2006, 01:22 AM   #10
korrupt1
korrupt1's Avatar
butterfly is a metal looking deal on the inner part of the throttle body....you "open" the throttle and it allows for more air to come in..closed you cant see down the TB.....and by fluid I mean non restricted movement...shouldnt hang up anywhere in its travel from fully closed (off position) to fully open (wide open throttle)
keep your ears close to the TB's (throttle bodies) and see if you can hear anything at all scraping or if you can see anything getting hung up.....that would be were I would start looking myself....sounds like something got a bit jarred and maybe hanging up some.
sucks to hear about your crash man......gear is your friend...wished I woulda had my lid on when I went down because I took a solid wallop to the head from mine...lucky I didnt fock up my brain any worse than it is already.
and no need to be saying sorry...thats what the forum is about...asking questions and getting answers and making a few friends along the way.
Old 03-04-2006, 01:27 AM   #11
righthooks
scrapen it!
righthooks's Avatar
ok im gonna do that tommorow..thanks alot...apreciated more than you know..
>no helmet ...wow dude.!...< your lucky...my helmet saved my life<
Old 03-05-2006, 07:26 PM   #12
righthooks
scrapen it!
righthooks's Avatar
please help....what happens if there was some smoke comen out from the throttle body???or maybe underneath it??? ... i adjusted the throttle cable and its not reven up so hi anymore but still doesnt idle...goes from like 3rpm's than jumps to 6rmp and then back down..its all wacky..any ideas...please help??
Old 03-06-2006, 11:10 PM   #13
righthooks
scrapen it!
righthooks's Avatar
??????????? please help????
-=05 yamaha all hooked up getten my scrape on=-
