help me get my bike started : Yamaha R1 Forum
Motorcycle.com Classifieds!
Old 02-15-2002, 07:46 PM   #1
CJScott
A.K.A****Decifer
CJScott's Avatar
Bikes: 00R1,00TLR,01R6
Angry
Ok so i took my bike apart to polish the frame, When i put it back together it wont start? All the lights and the instruments come on except the neutral light does not come on ( and yes it is in neutral) and the engine wont crank over. I put a jumper wire from the batterie to the starter and it cranks but im not getting any spark. If anyne has any suggestions on what it could be or what i could do to find out please HELP!!!! Thanks
CJScott is offline   Reply With Quote
Old 02-15-2002, 08:44 PM   #2
bender
bender's Avatar
Bikes: 04 R1, 08 CBR 1000RR
Looking at the wiring schematic it looks as though your ignition fuse is blown. This would cause all of your headaches that you've described. There is a fuse box under your seat on the right hand side and your starter relay has fuses in it I believe, the ignition fuse is a 15 amp fuse. Do not put in a higher amperage fuse, if it blows check for a grounded circuit. If nothing is blown I can help you further, get back to me.
bender is offline   Reply With Quote
Old 02-15-2002, 09:12 PM   #3
CJScott
A.K.A****Decifer
CJScott's Avatar
I checked all the fuses like 20 times and they are all good. Do you know what the main reson the neutral light wouldnt be coming on?
Old 02-15-2002, 09:37 PM   #4
bender
bender's Avatar
It looks as though your neutral light is grounded by the neurtal switch but the current flow has to go through the relay unit. The bike should still start even if the neutral switch is f#$ked, the clutch being pulled in and the sidestand up will start the bike if the neutral switch is no good.
Check the sockets the 15 amp fuse is in, it may be that one is not making contact. Your going to need a test light or a multimeter if you want to start testing things. Comments
Old 02-15-2002, 09:39 PM   #5
bender
bender's Avatar
The reason why I'm thinking it's the ignition fuse/socket/connection is this, it provides power to your on/off swich and your ignition unit. The on/off switch closes a relay that allows you to power the starter relay with the start push button. Does your fuel pump click when you turn the key on?
Old 02-15-2002, 10:45 PM   #6
CJScott
A.K.A****Decifer
CJScott's Avatar
My fuel pump does kick on when the key is turned.
Old 02-15-2002, 10:57 PM   #7
CJScott
A.K.A****Decifer
CJScott's Avatar
I also get nothing when i pull in the clutch and the kick stand is up. I will check the ignition fuse and connector first thing in the morning and ill let you know how it goes, I really appreciate your help
Old 02-16-2002, 07:47 AM   #8
CJScott
A.K.A****Decifer
CJScott's Avatar
I checked the fuse and the connector, any other ideas?
Old 02-16-2002, 08:26 AM   #9
bender
bender's Avatar
When you jumpered the starter relay to turn the engine over was the kickstand down? If it was down your bike would not have made any spark when the engine was cranking over because it thinks its in gear. Have you downloaded the 2000 R1 supplementry manual? Have you checked any connections with a test light or multimeter? What I may do is get the schematic and take out all the circuits that are irrelevant to you, this would show you what you need to test.
Old 02-16-2002, 08:28 AM   #10
ChampionR1
988 Of 1000 !!
ChampionR1's Avatar
Bikes: 2001 Champion Edition
Try putting it in first gear then roll it a bit then try going back to neutral see if you can get the light to come on
http://www.r1-forum.com/forums/attac...achmentid=1985
<font face="verdana, arial, helvetica" size="2" > <font color="blue">Modifications:
Full Akrapovic Exaust, Ivan Jet Kit, Dussault Undertail, Scotts Steering Damper, Intuitive Frame Sliders and Blue Xenon Headlamps</font>
ChampionR1 is offline   Reply With Quote
Old 02-16-2002, 09:00 AM   #11
CJScott
A.K.A****Decifer
CJScott's Avatar
I did roll it down a hill ( going @ 8 MPH) trying to pop start it but also got nothing. and the kick stand is up and im still not getting spark
Old 02-16-2002, 09:16 AM   #12
bender
bender's Avatar
Check your PM box.
Old 02-16-2002, 09:09 PM   #13
CJScott
A.K.A****Decifer
CJScott's Avatar
bender , thanks for your help today. after talking to you i understood how to read the schematic. I tested all the relays and im pretty sure the relay unit is bad because i was not getting any continuity where there should have been.
Old 02-19-2002, 04:55 PM   #14
CJScott
A.K.A****Decifer
CJScott's Avatar
so i thought it was thr relay unit that was bad...WRONG , i picked it up today paid $50 for it , came home put it in and nothing. so now i start from scratch. My main question is what would cause the neutral light not to come on? and exactley how do i test the neutral switch for continuity?I think i may have bee doing it wrong .
Old 02-19-2002, 07:53 PM   #15
mach5er
I Jigga high, I Jigga Lo
mach5er's Avatar
Bikes: 01
Wow, this is like a soap opera. Keep up the good work and diagnose that sick R-1. I'll be watching!!!
Later
mach5er is offline   Reply With Quote
Old 02-20-2002, 12:02 AM   #16
ChampionR1
988 Of 1000 !!
ChampionR1's Avatar
I agree with Maxprimal. Its not likely that You would damage a switch or fuses, but more likely to have left off some ground wires or connectors not connected properly.
Check and make sure that the five grounds in the starting system are clean and connected to a good ground. I'll attach a couple pages that are useful.
We will figure this s#*t out sooner or later. Hopefully sooner for Your sake
Old 02-20-2002, 12:17 AM   #17
ChampionR1
988 Of 1000 !!
ChampionR1's Avatar
heres one:
Old 02-20-2002, 12:18 AM   #18
ChampionR1
988 Of 1000 !!
ChampionR1's Avatar
and the other:
Old 02-20-2002, 03:08 PM   #19
CJScott
A.K.A****Decifer
CJScott's Avatar
Ok guys i did a little continuity testing today and this is what i came up with, Starter switch...OK , Battery ground...Ok , Starter motor ground...OK, But when i checked the side stand switch i got nothing . I checked it by putting the positive connector ( from the multi meter) to the green wire and the negative connector to the black and got no continuity, also when checking the neutral switch for continuity i got nothing. I pulled the neutral switch out to look at it , and if you have ever seen one off of the bike it looks like the positive connection goes straight through and it gets grounded out by being screwed into the motor. I checked for continutiy from one end to the other and got nothing. so what do you guys think? what are the chances that both are bad? any comments or any input at all i would appreciate. I am attaching a pic of the neutral switch out of the motor so you can see what im talking about.
Old 02-21-2002, 03:33 AM   #20
CJScott
A.K.A****Decifer
CJScott's Avatar
maxprimal
should i ground all three wires? and shoud i reconnect them to the bike?I know im asking alot of stupid questions but i just dont wanna mess anything else up
