Newbie Attempt : Yamaha R1 Forum
Old 04-06-2006, 07:36 PM   #1
MustangsnR1s
One day as a Lion
MustangsnR1s's Avatar
Bikes: 05 R1
Lightbulb Newbie Attempt
Im going to install a new oem fuel tank on my 05 R1 because I put a tiny ding in my stock tank and im nervous about it with fuel pump and all that. any tips tricks things I should know.. ANYTHING!!! would help...
http://www.myspace.com/70691839
MustangsnR1s is offline   Reply With Quote
Old 04-07-2006, 12:28 AM   #2
Samsir
OMG It's fast
Samsir's Avatar
Bikes: Yamaha R1 2005, YZ450 2005
Re: Newbie Attempt
Hi,
Been there, done that.
Straight foreward, but be careful with the fuel pump. There is a gasket between the pump and the tank you need to be careful with.
Careful not to damage the gasket. If in doubt, put in a new one. (You do not want a leak there)
When you loosen the pump and want to take it out of the old tank, it can feel like the pump is too big to get out of the tank. Take your time and whiggle it out.
You should use a crisscross pattern when you put back the 6 bolts holding the pump. Torque to 0,4nm.
Good luck!
Samsir
Yamaha R1 05, Ohlins rear shock, Ohlins front internals, Ohlins steering damper, Yoshimura tri ovals, powercommander, wideband commander, Goodridge brake hoses, Gilles rearsets, Digi gear indicator, GP Type clipons, SEBI moto race fairing, 520 DID race kit, Gilles chain adjusters, R&G crash mushroms on forks, center and rear, STM slipper clutch, Graves velocity stacks, Graves smog block off plates, Sam's servo sub, Speedo healer and more.
Samsir is offline   Reply With Quote
Old 04-07-2006, 07:52 PM   #3
MustangsnR1s
One day as a Lion
Bikes: 05 R1
Thanks for the reply!! I feel better about it. U ROCK
Old 04-08-2006, 02:02 AM   #4
bestman77
Back From the Dead
bestman77's Avatar
Bikes: 03 R1 Limited, 05 R1 Blue
Re: Re: Newbie Attempt
Originally posted by Samsir
Hi,
Good luck!
Samsir
Good write up if i might add
bestman77 is offline   Reply With Quote
