Speed problem : Yamaha R1 Forum
Old 10-13-2002, 02:21 PM   #1
ttretas
ttretas's Avatar
Bikes: R6
Question
My friends 2000 R1 has is speedometer not working. We checked the fuses and they were ok. The sensor of the bottom of the engine is well connected. We can't figure it out. Does anyone wan't to give it a go??
ttretas
ttretas is offline   Reply With Quote
Old 10-13-2002, 02:36 PM   #2
LiquidR1
Life is GRAND
LiquidR1's Avatar
Bikes: 02' Liquid Silver R1
I don't know how difficult it would be to see the connections but have you checked behind the speedo itself??? Of maybe the sensor is bad. Is there a way to Ohm it out or check it's output???? I'm not sure what kind of sensor it might be so I can't be more specific than that. Hope that helps.
When life throws you a curve, just LEAN INTO IT.....YEAH BABY!!!
LiquidR1 is offline   Reply With Quote
Old 10-13-2002, 09:53 PM   #3
martinc
martinc's Avatar
Bikes: 99 R1/07 1098S TRE
check all plugs(in the front)....one must be corroded.
take your time and take off the upper fairing.
martinc is offline   Reply With Quote
Old 10-14-2002, 08:12 AM   #4
ttretas
ttretas's Avatar
Bikes: R6
Ok thanx guys. It was the speed sensor in the gear box. Gotta replace it.
ttretas
Old 10-14-2002, 08:23 AM   #5
LiquidR1
Life is GRAND
LiquidR1's Avatar
Cool I'm glad you guys figured it out.
Old 10-14-2002, 09:03 AM   #6
martinc
martinc's Avatar
ttretas
first time i"ve heard of this.....
Old 10-14-2002, 03:46 PM   #7
ttretas
ttretas's Avatar
Bikes: R6
What? The speed sensor or the gear box? j/k
I'll let you know what was the exact part malfuctioning.
ttretas
Old 10-14-2002, 03:48 PM   #8
LiquidR1
Life is GRAND
LiquidR1's Avatar
SWEET!!!
