» Site Navigation |
» Motorcycle Forums
12-29-2007, 02:52 PM
#21
Beating a dead horse.
Bikes: 2003 R1 - Silver/Black/CarbonFiber
It's for more accurate tuning. I couldn't care less about saving a few pounds.
12-30-2007, 12:03 AM
#22
Originally Posted by eb six on boost
well if you left the elbows in the head i guess you could just clamp some rubber caps on the ends, not sure how they would go with the heat.
the graves plugs have a step in them, to give a good seal and hold them tight.
but i guess youve got to ask why you even want to remove the ais.
if its weight saving or for a more accurate tune.
ive done my bike and a mates, and none of them broke off, and not even bent.
just take your time and twist then around for a couple minutes before you start to pull them out. and use plenty of penatrating oil.
Some rubber caps would probably work alright. There's rubber hoses that run directly beside the engine and they survive...
I'm not too worried about keeping an extra pound or two on my bike--I'm more concerned about one of these things breaking and me not being able to get it out.
12-30-2007, 08:19 AM
#23
KP
Bikes: r1
if it does break off weld a bolt on it and pull it off....i broke two off and had to do that....Like said above,take your TIME and you will be ok....
02 R1,.with some Goodies...!  !...
drag racer
2006 Yamaha R1 LE #487
all the bells and whistles
12-30-2007, 08:28 AM
#24
KP
Bikes: r1
drag racer
12-30-2007, 08:44 AM
#25
Thanks for the response, but believe me... I'm no welder, and that doesn't sound that appealing to me.
12-30-2007, 09:32 AM
#26
KP
Bikes: r1
let us know how u do...!
drag racer
12-30-2007, 12:08 PM
#27
RIDE OR DIE
Bikes: 02 R1 is the best ever, 91 GSXR 750 SOLD
I also broke one off and I used a screw extractor to take them all out in about 5 minutes tops. A little bit of WD40 is all you need. I hit them with a little bit of WD40 broke them all off and took them all out with the screw extractor in like I said 5 min tops. It work so good when I did my bud's bike it only took me about 40min's from start to finish.
Full Yosh,Power commander,BMC filter,slide stop,v-stacks,AIS Smog plugs,Extremtech3 rear shock 1in lift,Racetech springs & valves fork,Traxxion Fingertip preload Adj Kit,Indiglo white face tach,Speedo Healer,Vortec 520 kit 1-F 2+R,Vortec clipons,Vortec triple tree clamp,CRG levers,Speedtech tinted screen,mirrow blocks,Steel braided lines F&R,Sato rear sets,Lp inter tail light & flush turn signles,Lp CF frame sliders & clutch slider & rear spools,Solo tail,CF frame cover,CF F&R fenders,
01-08-2008, 06:47 PM
#28
MMmmmuu Phhhhhaaaaa
So what is done with the two wires connecting to it?
01-08-2008, 07:21 PM
#29
KP
Bikes: r1
they run up under the gas tank,just disconnect it,thats what i did,and i have had zero problems....
drag racer
01-08-2008, 09:44 PM
#30
MMmmmuu Phhhhhaaaaa
Everything worked out great, and I got good exercise pulling the ports out of the head
01-09-2008, 05:15 AM
#31
KP
Bikes: r1
nice...!!
drag racer
01-25-2008, 04:59 AM
#32
R1-011 Wolfpack C/O
Bikes: 06 50th
So when you go to do this mod, I see most of you break shit. lol.
Sig by Petrol Spice
Godspeed Chad "Gawarrior" Clifton - June 25, 2008
R1-011 Wolfpack Squadron C/O
NW USA: WA, OR & Alaska
01-25-2008, 06:16 AM
#33
MMmmmuu Phhhhhaaaaa
just be patient and use lots of penetrant.
01-25-2008, 09:28 AM
#34
I'm still thinking about whether this mod is worth it or not. If I attempt it I think I'll use a mini torch I have to heat the ports up and then try pulling them out.
01-26-2008, 04:08 AM
#35
R1-011 Wolfpack C/O
Bikes: 06 50th
I can't see a single pic from this. So I still have no idea how to do it.
Sig by Petrol Spice
01-26-2008, 08:49 AM
#36
MMmmmuu Phhhhhaaaaa
heres all the crap
01-26-2008, 10:12 PM
#37
R1-011 Wolfpack C/O
Bikes: 06 50th
Hey thanks. So ther is 4 of them? and most of those bends break?
Sig by Petrol Spice
01-27-2008, 03:15 AM
#38
KP
Bikes: r1
yup there is four of them,if you take ur time they will all come out in one piece,i got 3 of 4 out in one piece.....
drag racer
01-27-2008, 05:01 AM
#39
R1-011 Wolfpack C/O
Bikes: 06 50th
Nother ?
Do you think if I install these and a set of Vstacks that I will really need a new map?
Sig by Petrol Spice
01-27-2008, 10:01 AM
#40
MMmmmuu Phhhhhaaaaa
I did the block offs, slide stops, ram air and the v stacks. Thought my bike was going to run like shat until I got a new map, but to my surprise it runs great. I dont feel pressed to get a custom map like I thought I was going to be.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
