HOW TO:AIS Smog Block-Off Plugs 02/03 - Page 3 : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > How To's
Old 01-27-2008, 11:51 PM   #41
Devil1
R1-011 Wolfpack C/O
Devil1's Avatar
Bikes: 06 50th
Right on. The map I have was a custom map for my type of exhaust but he also had Vstacks. My bike runs a little on the lean side.
Sig by Petrol Spice
TEAM:
SO FAST SO CLEAN
Godspeed Chad "Gawarrior" Clifton - June 25, 2008
R1-011 Wolfpack Squadron C/O
NW USA: WA, OR & Alaska
Devil1 is online now   Reply With Quote
Old 02-08-2008, 05:27 PM   #42
hzepeda07
BlingR1
hzepeda07's Avatar
Bikes: 03 R1
I just removed my AIS system and I used a allen wrence that fits inside the elbow and moved it back and forth a couple of times, used more WD-40 and used another little prybar on the underside of the elbow while moving it back and forth. This method works best and it's really quick. All of them came out without problems. Hope this helps others.
hzepeda07 is offline   Reply With Quote
Old 02-14-2008, 09:19 PM   #43
Devil1
R1-011 Wolfpack C/O
Devil1's Avatar
Bikes: 06 50th
Sweet
Sig by Petrol Spice
TEAM:
SO FAST SO CLEAN
Old 03-24-2008, 06:36 PM   #44
Chuckiep216
Clean and simple
Chuckiep216's Avatar
Bikes: 03 R1
Subscribed
Chuckiep216 is offline   Reply With Quote
Old 03-25-2008, 09:45 AM   #45
redneck1089
Beating a dead horse.
redneck1089's Avatar
Bikes: 2003 R1 - Silver/Black/CarbonFiber
Originally Posted by eb six on boost View Post
well if you left the elbows in the head i guess you could just clamp some rubber caps on the ends, not sure how they would go with the heat.
the graves plugs have a step in them, to give a good seal and hold them tight.
After examining my bike I've noticed there's rubber tubing going from the "L plugs" to the AIS, and there's tons of rubber connectors and tubing under the tank, which is right above the engine, and they withstand the high temperatures. I like the idea of just leaving the "L plugs" intact because that way if I ever need to reinstall the AIS for any reason I can, and also because there's no chance of breaking the "L plugs" in the head during removal.
I just need to find something that works to block the "L Plugs." Does anyone have any more ideas?
http://org111.zpcdn.com/0/5349/34233807.15a055.jpg
redneck1089 is offline   Reply With Quote
Old 04-03-2008, 05:17 AM   #46
bean_8044
Bikes: 02 R1
my little thread is all grown up :
bean_8044 is offline   Reply With Quote
Old 04-03-2008, 07:17 PM   #47
Chuckiep216
Clean and simple
Bikes: 03 R1
As long as you remove the radiator, the job is a piece of cake. I used a little high temp sealer around the Graves block offs, then tapped them in with a rubber mallet(so i didn't accidentally hit anything like the fork tubes with a metal hammer) and a long flat punch. As easy as 1...2...3.
And yes i did remove the whole smog unit. I put it in a box with all of the other stock parts i take off of her.
No more popping when i let of of the throttle or down shift, just a mean rumble.
Here are some pic's what they look like installed:
Old 04-03-2008, 07:23 PM   #48
02R1FUN
MMmmmuu Phhhhhaaaaa
02R1FUN's Avatar
any feedback on the charcoal canister removal?
EXUP http://www.r1-forum.com/forums/showthread.php?t=262749
I hate your loud, stinky diesel
02R1FUN is offline   Reply With Quote
Old 04-03-2008, 07:38 PM   #49
redneck1089
The problem for me is I don't want to remove the L shaped plugs that are already in there; I just want to block em with something. Never know when I might have to put the AIS back on.
Old 04-03-2008, 08:12 PM   #50
Chuckiep216
Clean and simple
Bikes: 03 R1
You can always put the smog unit back on your bike. As for the L shaped plugs.....go to your local Yamaha dealer and order them when you decide to put them back in.
Do you still have the tractor trailer sized mud flap rear fender too?
Old 04-03-2008, 08:15 PM   #51
redneck1089
It would be hard to pull the smog block offs out of the engine head, wouldn't it?
The mud flap has been cut in half to make it smaller! Cops around here don't like it if you don't have a light on the license plate, so I've made it look as best I can.
Old 04-03-2008, 08:33 PM   #52
Chuckiep216
Clean and simple
Bikes: 03 R1
I was a little concerned with extracting them at first also. I read about a couple of guys snapping them off. So i decided to take as much off as possible, that made my experience so easy. I used a pair of plyers and twisted back and forth like a clock, 10:00 to 2:00 twist using penitrating oil. As i was twisting back and forth i was also pulling out on it.
Stop worrying and get to work............
Old 04-03-2008, 10:39 PM   #53
redneck1089
No, I mean I want to leave the stock "L plugs" in there, just block them somehow. If I were to remove the L plugs and put in the smog block-offs from Graves, it would be impossible to put the AIS back on if I ever need to.
I'd really just like to block the damned L plugs some how. Don't care too much about the weight savings of removing the whole AIS unit.
Thanks for your response.
Old 04-04-2008, 09:55 AM   #54
bean_8044
Bikes: 02 R1
if you dont care about the weight savings then just unplug the electrical connector going to the AIS box and cap the line that goes to the airbox. thats how mine was when i got it
Old 04-11-2008, 05:41 PM   #55
leeindy
Bikes: 03 R1
subscribed. need to get those
leeindy is offline   Reply With Quote
Old 04-11-2008, 05:45 PM   #56
Devil1
R1-011 Wolfpack C/O
Devil1's Avatar
Bikes: 06 50th
I just bought my set... they'll be waiting along witha bunch of other goodies....
Sig by Petrol Spice
TEAM:
SO FAST SO CLEAN
Old 04-20-2008, 06:30 PM   #57
leeindy
Bikes: 03 R1
so did any one figure out how to just cap the L plugs. im thinking rubber caps and line clamps.
Old 04-20-2008, 07:32 PM   #58
redneck1089
Nope, never did find a way. It's not a huge concern for me to block the AIS right now because dynoing my bike isn't in my budget this summer. I can live with popping, I suppose.
It still would be nice though if someone could/can find a way to leave the L plugs in and just block it that way.
Your idea sounds like it would work. Let me know if you end up going through with it.
Old 04-20-2008, 07:39 PM   #59
leeindy
Bikes: 03 R1
ill give it whirl tomorrow. my full m4 shows up then.
Old 04-20-2008, 08:15 PM   #60
Chuckiep216
Clean and simple
Bikes: 03 R1
Your rubber caps will melt. Keep in mind, it's hot exhaust from the head.
plugs & AIS smog block offs 08 R1... crazylegs 07-08 R1 Mechanical Help 7 01-02-2011 09:41 AM
AIS block off without smog block off plates Leftinthedust 04-06 R1 Mechanical Help 4 04-28-2007 10:11 AM
2002 r1 graves smog block-off plugs alr1 How To's 2 04-26-2006 11:21 PM
Smog Block Off Plugs? Ksths2 Mechanical / Help 3 10-25-2004 05:11 PM
how to install Graves AIS Smog Block-Off Plugs ElectronR1 Mechanical / Help 2 08-11-2004 08:49 AM
