Custom LED Flasher Relay Problem : Yamaha R1 Forum
Old 06-24-2006, 02:43 PM   #1
Squid R1der
Looking for Redemption
Bikes: 99 Red/White R1
I had trouble with my factory flasher relay not working with the LED turn signals i had bought, so i bought a Custom LED flasher relay to correct this problem. I installed it and it works just fine, but the green turn signal led on the instrument cluster doesn't flash with the turnsignals, it doesn't illuminate at all. What is the deal with this?
Squid R1der is offline   Reply With Quote
Old 06-24-2006, 04:04 PM   #2
Squid R1der
I also noticed that i'm getting a bit of "bleed through" on the opposite turn signal,
For example, i have hooked the Right Rear LED turnsignal up and the Left Rear isn't hooked up. Both of the Front LED signals are hooked up. I turn on the Left signals, the Left Front illuminates normally, the Right Front illuminates/blinks slightly/dim. The Right Rear signal however does illuminate/blink very slightly and dim. If i were to hook the Left Rear up also, then it will do the same thing when i turn Right Turn signals on.
The Bleed through seems to only be in the rear signals?
I am basically having the same problem as this guy,except i don't have a problem with my brake lights.
http://www.r1-forum.com/forums/showt...hreadid=100881
Old 06-24-2006, 06:21 PM   #3
Squid R1der
I actually managed to fix this problem by wiring in two "incandescent" light bulbs meant for a car/truck in the circuit with the LED's. What else could i wire in the circuit other than the light bulbs that will achieve the same effect??
Old 06-24-2006, 06:33 PM   #4
tomygunr1
-NYC R1-
tomygunr1's Avatar
Bikes: 2001 R1 Custom Drag Bike, 2001 R1 built to my lady's specs for her, 2006 R1 164 Rhp., 2012 Raven Full Custom.
you can wire in-line one resister per circuit that needs to flash propely!! i only had that bleed-thru on my 98!! my 01, and 06 work 100% with LED's on all 4 corners!!
2001 R1 DRAG BIKE: 12" over Mcintosh swingarm, lowered, 30 shot NOS, lots of chrome, JE 13:1, Graves cams, Orient Express head work, and many custom mods!!!!!!
2006 R1: lots of R1 blue painted parts, lots of titanium, 164 rhp, and many attention getting mods!!
2001 R1: flushmounts, ARROW full exhaust, wheel stripes, K&N with IVAN'S needles and airbox mod, speedo-healer, 520 conversion, and galfer pads. all set up for my lady to ride!!
2012 Raven Full Custom Built by Enigma Kustoms!!
tomygunr1 is offline   Reply With Quote
Old 05-10-2010, 07:26 PM   #5
longboard_dood
600s are 4 those that fear HP
Bikes: 2006 R1...sweetness
i just spent a little time hunting around for my rear turn signal switch relay on my 2006 R1. I had purchased the lockhart phillips relay and it is similar to the stock one, but not exact (maybe i didnt get the right year). But the stock switch relay is on the right side under the seat and its easily accessible (nothing on top of it). On an 06, if you have to cut something you are doing it wrong :-) Its the only wire on the right side that has the same connection plug as the relay.
longboard_dood is offline   Reply With Quote
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
