» Site Navigation |
» Motorcycle Forums
08-12-2006, 08:45 PM
#1
gas light wont stop blinking
 its driving me crazy but on my 00 R1 the gas light always blinks.. even with a full tank.. any ideas how to fix this??
08-12-2006, 10:11 PM
#2
Il Padrino
Bikes: 2010 R6, 2009 KTM 530 EXC, 2006 Gixxer 750, 2004 YZ125, 2002 R1
Not sure about the '00, but on the newer models that happens if you don't have the fuel level guage connector connected.
AMA/AFM/WERA #195
2010 R6 (Race bike), 09 KTM 530 EXC (Supermoto), 06 GSX-R750 (135,000 miles), 04 YZ 125, 02 YZF-R1 (133,000 miles).
08-13-2006, 04:51 PM
#3
I got stanky on my hang down
Bikes: 2004 R1 Silver #1673 (fastest color)
Re: gas light wont stop blinking
Have you tried disconnecting the battery to let it reset?
PCIII USB|Yamaha Seat Cowl|R&G Frame Sliders|Greggs Custom Barend Sliders|Intuitive 6MM swing arm spools|CRG Shorty Clutch & Brake Levers|Clear Alternatives Brake/Tail Light Integrator|R&R Fender Eliminator|Harris Grips|High Gear Tech Mount|Puig Dark Smoke Racing Screen|Graves Velocity Stacks|Cycle Gadgets Quick Change Oil Kit|Watsons Flushmount Turn Signals|Custom Race Baffles|Graves Clutch Slider|Acumen Gear Indicator|Racer Solutions Remote Laptimer Kit|Galfer SS Brake Lines|Graves Rearsets
08-15-2006, 07:35 PM
#4
where would that plug be??? and i havent but will reset the battery... also i went 121 miles without filling the tank, how many miles can i go???
thanks
08-15-2006, 09:05 PM
#5
Il Padrino
Bottom of the tank. You should have two wire connectors plugged into it.
121 miles - you're about on fumes.
AMA/AFM/WERA #195
08-16-2006, 10:48 AM
#6
The Original One
Bikes: YZF-R1 '98
IF its the same as the '98, you will find a green connector behind the LHS plastic tank infill (Bottom rear edge of tank). That is the connector for the Fuel level Sensor.
If this is plugged in, it sounds like time to check all the loom connectors, check the internal connections are clean, none burnt and apply dielectric/silicone grease.
See THIS thread.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
