» Site Navigation |
» Motorcycle Forums
11-04-2006, 08:08 PM
#1
Sato Rearsets Brake Spring??
Just got a new set of gold Sato Rearsets and I really can't find a place to logically install the OEM brake spring... Hooked everything else up including the brake switch for the light...
Does anyone know if the spring is supposed to be on there or is not needed?
The legend has returned, I hope you've been practicing.
11-04-2006, 08:20 PM
#2
Bikes: Yep!
Honestly, I have the same sets and as long as front controls light I would not mess with it!!!
11-04-2006, 08:30 PM
#3
Enjoy Da Ride
Bikes: 06 Raven R1
mine came with a small actuator that installed into rear master cylinder, then I spliced into the brake wire.
11-04-2006, 08:49 PM
#4
My D.O.C.
Bikes: '05 Raven R1
 I have Sato rearsets and I did not bother hooking up the rear brake light switch.
11-05-2006, 06:57 AM
#5
Guys... The question is about the brake return spring... I already have the rear brake switch wired...
Thanks
05-21-2007, 05:44 PM
#6
`The Bike Made Me Do It`
Bikes: 2005 R1
i should have looked at this thread before trying to install my sator earsets today... anyone find out something on how to hook up a brake return spring for the stao rearsets??? i dont think the brakes are dragging on the stand but once the fluid gets hot and expands, i'm sure there may be some drag... any help!
2005 R1*DEVIL CARBON FIBER EXHAUST*GRAVES MOTORSPORTS FLUSHY FRONT LEDS*LP REAR LEDS*SATO FRAME SLIDERS & SWINGARM SPOOLS*GALFER SMOKE STEEL BRAIDED LINES*CUSTOM C.REESE FENDER ELIMINATOR*FACTORY SOLO REAR SEAT COWL*CARBON FIBER BAR ENDS*K&N OIL FILTER*PROGRIP TANK PAD*
05-21-2007, 05:49 PM
#7
yield
Bikes: 2002 R1 #335 red/white livery
Hmmmm.... the form factor might simply not work. I run one so get them. Post a pic so we can scheme on a solution.
Asked if he was afraid of dying in an accident, Marco Simoncelli responded: "No. You live more for five minutes going fast on a bike like that, than other people do in all of their life." rip #58 ciao ciao bello
05-22-2007, 04:05 PM
#8
No drag on mine at all... I don't think they were designed to run one....
05-22-2007, 04:07 PM
#9
Track addict!
Bikes: 09 R1, 03 R1, 04 CRF-50, 06 R6(sold)
I don't have the rear brake light hooked up, nor a return spring. Over a year with no problems..
-Sig complements of Buddyluv-
05-22-2007, 04:22 PM
#10
My R1 belongs to someone else!
Bikes: 2005 YZF-R1 Raven (Sold)
i didnt have a return spring either for a year, no problems, but jsut in case
05-22-2007, 04:53 PM
#11
yield
I'm an idiot, I inferred that was what the original post was about. I have the pictured Graves unit on my Attack's...
05-22-2007, 08:11 PM
#12
THE MAN
Bikes: 00 R1 (THE FASTER BLUE ONE)
I have made about 5 of these brake return springs for after market rearsets so far. A trip to ace hardware, and about 30 minutes worth of work will get you what you need.
I have not seen any of the aftermarket rearsets come with a brake return spring, or a place to mount the stock one.
I basically buy a spring and a washer and make what is shown in the pic. I paint the spring so it looks abit better, but it does not really matter.
I think it makes the rear brake feel a bit better (or at least more like stock).
I Pray I am strong enough to never give up.
Worry about doing what is right, and let someone else worry about everything else.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
