Sqeaky Brakes : Yamaha R1 Forum
Motorcycle.com
Old 11-14-2006, 02:14 AM   #1
k1972pat
Ride like theres no tomorrow!
k1972pat's Avatar
Bikes: 2005 R1
Sqeaky Brakes
I just put on some new front Galfer front brakes on my 05 R1. Is there something I can put on them to make them quit sqeaking?
2 brothers carbon slip-ons, PC USB Power Commander,Carbon Frame sliders with Blue piston valve caps, Blue Alum res cap, Blue seat cowl, Puig DB Dark wind screen, Blue Cox radiator grill, Blue Pazzo Racing levers, Fender Eliminator, BMC Racing Filter, DID 530/120link Chain, Vortex 45 tooth rear Sprocket SS 16 tooth front sprocket, SpeedOhealer, HyperPro Steering Damper, Throttlemiesters.
k1972pat is offline   Reply With Quote
Old 11-14-2006, 08:35 PM   #2
RCracer51
The former Stop Doc
RCracer51's Avatar
First off, what compound did you get? and did you prep the rotors?
RCracer51 is offline   Reply With Quote
Old 11-14-2006, 08:38 PM   #3
Sabian
Booya
Sabian's Avatar
Bikes: 1943 Indian Scout 741
Yup...bet you just slapped them babies right on without doing anythign to the rotors right?
"Universe is 14 billion years old. Seems silly to celebrate one year. Be like having a fvcking parade every time I take a piss." -- ShitMyDadSays
Yeah it was head trauma alright....but it was my little head that was traumatized by your mouth.
Sabian is offline   Reply With Quote
Old 11-16-2006, 11:52 AM   #4
k1972pat
k1972pat's Avatar
Bikes: 2005 R1
Yep, did not know you had to do anything to rotors? Do you have to take them off and have them turned like a car?
Old 11-16-2006, 12:40 PM   #5
strgt
nope you gotta spray break cleaner on them and rub the coating off with a rag
strgt is offline   Reply With Quote
Old 11-17-2006, 05:40 PM   #6
SuperG
Grease them....hee hee hee, just kidding! You might want to rub the pads together a few time as well as they might have "glazed" a little if you've been riding it a lot!
SuperG is offline   Reply With Quote
Old 11-19-2006, 01:02 AM   #7
k1972pat
k1972pat's Avatar
Bikes: 2005 R1
Thanks guys for the info.. I'll give em a try.
Old 11-19-2006, 01:43 PM   #8
RCracer51
The former Stop Doc
RCracer51's Avatar
No brake cleaner..... You need to sand down the rotors. Depending on the compound you got. A semi metallic compound will not bite through a OEM or sintered metallic compound. Thus, giving you funny sounds from the front end. Some 400-600 Grit wetsand paper, soap and water, will get things going in the right direction (circle sand on both sides of the discs). Brake cleaner is only used for bare calipers and graffiti removal.
Old 11-19-2006, 01:55 PM   #9
LiquidR1
Life is GRAND
LiquidR1's Avatar
Bikes: 02' Liquid Silver R1
I bought semi metallic pads for my bike and noticed the same thing. They would squeak quite a bit. I didn't even know I would have to prep the rotors. But the squeaking finally stopped. I think they are good and broken in now. So if you are patient enough the squeaking should go away.
When life throws you a curve, just LEAN INTO IT.....YEAH BABY!!!
LiquidR1 is offline   Reply With Quote
Old 11-20-2006, 12:40 PM   #10
strgt
good to know
my front brakes locked up (caused me to go down) why'd this happen? ryanpal General Motorcycle Discussions 69 05-29-2008 10:32 AM
No Brakes (California Superbike School) VPREATR Technique & Riding 28 07-28-2005 07:58 AM
front brakes squeek like crazy... anybody else have that problem? blueyzfr6 General Motorcycle Discussions 3 08-13-2004 03:42 PM
Braking Bike Vs Car Lord Rupert General Motorcycle Discussions 40 08-25-2003 12:47 PM
Radial Brakes a gimmick? KneeDragger77 General Motorcycle Discussions 21 08-15-2003 01:38 PM
