Oil pressure issues : Yamaha R1 Forum
SportbikeTrackGear
Old 11-20-2006, 06:35 AM   #1
Cajunham
Ex R1 Rider
Cajunham's Avatar
Bikes: 2000 R1(Sold) 2008 B-King
Oil pressure issues
I have a 2000 R1 with 28000 miles that I'm having a problem with. I keep blowing the seals on oil filters. I have tried 3 diffrent kinds of oil filters including oem, Amsoil, and Pure One. I don't have any smoke comming from the bike at idle or when at high rpm so I don't think that it is a ring issue but you never know. Anyone have any sugestions on what it might be? I'm trying to avoid tearing the engine apart trying to figure out what is going. Any sugestions would be appreciated. Thanks
Cajunham is offline   Reply With Quote
Old 11-20-2006, 08:51 AM   #2
William YZF-R1
The Original One
William YZF-R1's Avatar
Bikes: YZF-R1 '98
I have read 2-3 similar posts to yours over the same number of months. There have been several plausible suggestions to the cause, but I don't recall anyone returning with a definitive answer.
Found one thread:
http://www.r1-forum.com/forums/showt...ing+oil+filter
William YZF-R1 is offline   Reply With Quote
Old 11-20-2006, 09:00 AM   #3
Crankshaft
chicken strips w honey mustard
Crankshaft's Avatar
Bikes: 1980 RS 250, 2000 R1(binned), 2004 R1(lost in the divorce)
Make sure when tightening a filter(by hand) that there is a nice progressive feel to it. One time on my '04, I had a filter spin on nicely but stopped too abruptly. Turned out the gasket was thinner than the last filter(same brand) and the filter bottomed out on the threaded stud.
Good luck.
post up what you find out.
Just because you do not take an interest in politics doesn't mean
politics won't take an interest in you. Pericles (430 B.C.)
"I'm so Asian, I got grounded for B's on my report card" The BFA (1-31-07)
i used to be confused and now i just don't know...
R1-016 Venom Squadron #46
Crankshaft is offline   Reply With Quote
Old 11-20-2006, 10:09 AM   #4
JAYSTENSEC4CYL
THE MAN
JAYSTENSEC4CYL's Avatar
Bikes: 00 R1 (THE FASTER BLUE ONE)
There is an oil pressure reliefe valve in the oil pan. When the pressure gets too high it is made to let the higher pressure bleed off.
My guess is you have two seperate problems. One the valve is not working to release the pressure, two and worse there is an oil blockage somewhere which is causing the high oil pressure.
Please keep us posted with what you find.
I Pray I am strong enough to never give up.
Worry about doing what is right, and let someone else worry about everything else.
JAYSTENSEC4CYL is offline   Reply With Quote
changing the oil....joke of the day speedster00 Off Topic Talk 4 09-12-2006 08:26 AM
Changing oil filter Erasmus Mechanical / Help 39 02-06-2006 01:17 AM
can aplying vacuum to crankcase make you lose oil pressure?? vcyclenut General Motorcycle Discussions 3 01-12-2006 07:01 PM
installing oil pressure gauge? adamgeek Mechanical / Help 5 09-20-2003 05:53 AM
Oil pressure guage CruiseMissile Mechanical / Help 1 12-23-2002 09:22 PM
