proper sag setting : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 04-06 R1 Mechanical Help
04-06 R1 Mechanical Help Mechinical and Critical Issues for the 04-06 R1
Motorcycle.com Classifieds!
Old 02-05-2007, 09:06 PM   #1
PCHNorth
Bikes: R1
proper sag setting
I have a stock 2006 R1 and I weigh 182 lbs. If stock settings were where they are supposed to be, to properly set the sag, I went 2 turns in on the forks and went 3 clicks anti-clockwise on the damper. I was hoping to get some opinions from people who have done this more than me!
PCH North
PCHNorth is offline   Reply With Quote
Old 02-05-2007, 10:05 PM   #2
PARKER10
WSMC #520
PARKER10's Avatar
Bikes: 2005 Yamaha R1
You can buy a video from www.traxxion.com that explains everything
PARKER10 is offline   Reply With Quote
Old 02-22-2007, 03:36 AM   #3
Kangaroo
para bellum
Kangaroo's Avatar
First welcome to the forum
Second, look at the sticky for suspension settings
Everybody rides differently. It's easier if you ask what you want your bike to do better or why it needs improvement now. if you can't tell the difference. Start clicking away and write down the changes in the bike's behavior for each adjustment. You'll then find your settings. Don't use generic settings. they are good to only use as a starting point.
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is online now   Reply With Quote
Old 02-22-2007, 07:51 AM   #4
1fastmf
Pfft!
1fastmf's Avatar
Bikes: 2002 YZF-R1
Follow this thread. I posted up an explaination on the SAG settings. I also enclosed a zip file with an excel spreadsheet that will do the math for you. You just need to take the measurements.
http://www.r1-forum.com/forums/showthread.php?t=185692
I know the thread is about tires...but it's in there....
1fastmf is offline   Reply With Quote
Old 02-23-2007, 03:45 AM   #5
Flat Spot
In 7, Eyes on 8, Pray for 9
Flat Spot's Avatar
Bikes: 2006 MV Agusta Brutale 910s
What is your static sag set to? I measured mine (the best I could by myself) and measured 1" in the rear and 3/4" in the front. I have a friend coming over tonight to help me double check my measurements. I think I want more in the front if I'm not mistaken.
Flat Spot is offline   Reply With Quote
Suspension Experiment Philosophico Mechanical / Help 12 01-14-2007 07:01 AM
04 R1 Setting Up Proper Sag And Suspension. Kaution How To's 1 12-22-2004 04:09 PM
need help setting the sag of my 04 in the rear!!! blueyzfr6 General Motorcycle Discussions 2 07-05-2004 03:50 PM
setting sag? turd1 Mechanical / Help 18 05-28-2003 12:10 AM
Suspension question ozR1 Mechanical / Help 11 04-20-2003 09:47 AM
