» Site Navigation |
» Motorcycle Forums
| 04-06 R1 Mechanical Help Mechinical and Critical Issues for the 04-06 R1 |
02-15-2007, 11:24 AM
#1
In 7, Eyes on 8, Pray for 9
Bikes: 2006 MV Agusta Brutale 910s
Tire pressure question
Don't get upset with me, because I did a search for this before posting. Couldn't find a straight answer, so I'm asking.
I am running on Michelin Pilot Power 2CT's right now and wanted to know what PSI I should be set at. The manual recommends 36 up front and 41 in the rear (cold). That seems a little high, so I'm running 32 front and 35 rear. Should I go with the higher settings for normal street use?
02-15-2007, 12:57 PM
#2
I found the answer I was looking for. The pressure rates that are listed are maximum's and not the ideal psi for normal street use. I will stick with my psi rates around 32-35.
02-16-2007, 06:40 PM
#3
Bikes: 2004 R1
My Michelin guy advised me to keep Pilot Powers at 36 front and 35 rear on the street AND on the track (these are mainly street tires). And it is true, at these pressure the tires behave excellent in my case.
2CTs are just Powers with slightly softer outside 10/11% of the thread, otherwise no different at all.
If you use racing tires on your trackdays then pressures should be way different of course (lower).
'04 R1 Silver
'01 Moto Guzzi V11 Sport
'99 SV650S
'04 V-Star 1100 Silverado (sorry)
02-22-2007, 03:25 AM
#4
para bellum
each tire manufacturer has a recommended psi for the tire and their uses. At trackdays, Michelins tend to be 35-36. Pirellis 30-32. Go figure.
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
02-25-2007, 05:07 AM
#5
fast
Bikes: '09 CBR1000RR (track), '11 FLHTK (street), '13 BMW R1200GS (street)
i use 2ct also, 35/35 is the best i can feel....
03-03-2007, 02:53 PM
#6
Bikes: 2003 YZF-R1 LE(black w/ flames)
tire pressure
hey there i am running Dunlop 208 in the front and rear. just wondering what i should run for tire pressure. i ride on streets no tracks where i live.
03-03-2007, 03:40 PM
#7
If you crash it they will come
Bikes: '05 R1
yamaha recomends 36 psi in front, and 42 on the rear. ive never tried any other pressures than that because it just feels right. in my opinion, more pressure would make the tires 'stiffer' and not allow them to heat up properly.
03-04-2007, 07:03 AM
#8
then thats what i will run, i dont have the owners manual.
03-04-2007, 07:15 AM
#9
para bellum
42 is very high
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
03-04-2007, 08:25 AM
#10
THE GUNNY
Bikes: 1999 YZF R1 & fastest pocket bike on the planet
anything over 40 is too high
03-04-2007, 10:33 AM
#11
Wannabe Knee Dragger :p
Bikes: 2005 r1
okay yes 40 psi is kinda high..but it all depends on your weight and application.
i've been running stock setting now and i don't see a problem.. actually i was running 32 psi in front and 36 psi in rear. with the stock tires and my tires wore out so fast... got a set of Bridgestone BT-020 and work great on the stock settings.. the dunlops wear so fast for my daily driving and my lard ass (270 lbs.) and tires are so expensive and i opt to get Bridgestone BT-020 cause of the extended mileage factor..
it all depends on application.. set your tires to what you need them to do..
i know a guy who stunts and prefers a lower psi so he can do all his tricks. you just have to find the magic number to fit your needs..
hope this helps...
joel..
03-06-2007, 03:43 PM
#12
Bikes: '05 R1
bravo, good man. bravo.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
