07 Custom LED taillight : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 07-08 R1 Mechanical Help
07-08 R1 Mechanical Help Mechinical and Critical Issues for the 07-08 R1
Old 03-27-2007, 07:45 PM   #1
Sock
Ok it has lag.
Sock's Avatar
Bikes: 07 R1 01 F4i
Ok I have a problem. hopefully somebody has one or knows enough about them to help me out.
I just installed the board and the running light and brake light work great. my problem is that when I apply the right turn signal the entire board flashes red and when I cancel the signal it does it's self test (I think that's what it is, it does it when you turn the key to 'on'). The left signal works fine. Any ideas on what it could be?
Yes the green wire is going to the green wire before someone asks that.
thanks in advance.
Sock is offline   Reply With Quote
Old 03-27-2007, 08:26 PM   #2
Sock
Ok it has lag.
Sock's Avatar
Bikes: 07 R1 01 F4i
466 people online and nobody else has any ideas?
Old 04-11-2007, 06:10 PM   #3
62646
mmmmmmhmmmmm....
http://www.customled.com/F_A_Q_/f_a_q_.htm check out the q and a a little ways down, they say that you ahve to have so much load otherwise it just wont do anything maybe on the 07 they go nuts...
62646 is offline   Reply With Quote
Old 04-12-2007, 05:42 PM   #4
nix07r1
I installed the Blaster X on my 07 and no problems to report.... The signal does flash too fast (Gregg's flushies up front as well) but I'm just going to get the plug-in resistor to correct the relay speed. Sorry I can't be more help.
nix07r1 is offline   Reply With Quote
Old 04-13-2007, 03:48 PM   #5
Sock
Ok it has lag.
Sock's Avatar
Bikes: 07 R1 01 F4i
actually talked to them and it's a faulty board.
oh well
Old 05-03-2007, 04:23 PM   #6
PatR1ck07
Bikes: 07 R1
Damn, keep hearing a lot of Faulty Boards, with the BlasterX... makes me second judge buying one...
PatR1ck07 is offline   Reply With Quote
Old 06-14-2007, 10:11 AM   #7
hjsR1
Ride It
Bikes: 2007 R1,
Warning for installing custom LED light
Do not use Krazy glue or any other glue with alot of toxic chemicals in it to seal the lense back together only use a hot glue gun. Any finger prints or anything else that touches the LED lights or the tail light lense will fogg caused by the gases released from the Krazy glue no matter how well you clean it! It is some sort of bizarre chemical reaction. The fog in the lense cannot just be wiped away with windex, rubbing alchohol, or any simple cleaning solution such as that because it will keep comming back. I had to use a plastic cleaner that removed a very thin layer of the plastic to remove the fog and prints on the LED lights and lense. Trust me I found out the hard way and had to cut out the lense twice. The second time around only I used a hot glue gun and made a good seal and it works great now and haven't had any problems. This is just a forwarning for all to avoid the hassle I went through!
The light works awsome and I recomend all to get it, but just take my advice if you do it yourself. Also I hooked a toggle switch for the strobe mode and it looks sick. I tucked the tuggle switch in between the frame on the left side of the bike under the seat. This way it is hidden but still easily accessable. I will post some pics tomarrow if anyone cares to check it out.
hjsR1 is offline   Reply With Quote
Old 06-14-2007, 12:19 PM   #8
MuffDVR
No doot aboot it eh?
MuffDVR's Avatar
Bikes: '07 R1 Charcoal, '07 R1 Bogie Blue Special, '11 KTM 300XC
My board was faulty as well, pissed me off. The damn transistor or w/e it is called broke off while riding the first day so I had to tear it all apart again, line up the transistor to its 3 soldering points, hot glue gun it into place then try my hardest to solder those tiny points together. I was NOT happy!
| Akrapovic Evo II exhaust | Sato Black rearsets | Akrapovic carbon fibre hugger, chainguard and exhaust guard | Gold Marchesini wheels | Ohlins Steering Damper | Dynojet PCIIIusb | GYTR Gel Comfort Seat | Custom LED Tail Light Integrator | 16T Renthal front sprocket | GYTR Rear Seat Cowl | Galfer SS Front & Rear Brake Lines | Watsen Design signals | Smog Block Off Plates | DID 520 chain | Puig DB Dark Smoke Windscreen | Greggs SS Black Bar Ends | Pazzo Shorty Levers|
MuffDVR is offline   Reply With Quote
Old 06-14-2007, 12:20 PM   #9
MuffDVR
MuffDVR's Avatar
Yeah, I learned this hard lesson as well. Hot glue gun worked much better then krazy glue, man was I angry for the fogging of the normal glue. Post up the pics of the toggle switch, I want to add that as well.
Old 06-14-2007, 07:57 PM   #10
POKER PRO
POKER PRO's Avatar
Bikes: 07 Blue R1
I'm gonna buy the blue lensed integrated tail/signal light from clear alternatives for my 07. Should look good.
POKER PRO is offline   Reply With Quote
Old 06-22-2007, 09:24 AM   #11
hjsR1
Ride It
Bikes: 2007 R1,
Toggle switch location for Tail light strobe
I tucked it on the left side of the bike in between the frame so it is hidden yest still easily accessibly while sitting on the bike. Here is a pic.
Old 06-23-2007, 12:17 AM   #12
7777r1
7777r1's Avatar
That's why I waited for the clear alternatives one to come out. The blasterX sounds like too much of a pain. Just for the fact that I didn't have to take apart the stock light and send it away made it a no brainer...The CA light is also plug and play, it works great and is less expensive compared to the blasterX.
7777r1 is offline   Reply With Quote
Old 06-29-2007, 03:42 PM   #13
STX
is the R for race or rocket?
STX's Avatar
Bikes: 07 CHARCOAL R1
Where can you get the clear alternative lights and can someone list all the intergrated lights avalible and where to to get them?I have been looking for some for a while now,I have heard about the one that you have to replace the board,but did not know where to find those either.
STX is offline   Reply With Quote
Old 07-01-2007, 04:07 PM   #14
b1cnrt73
Bikes: 07 R1
same problem as Muffdvr
I had the same problem as muffdvr. Before you but it together mahe sure you epoxy or hot glue the large black resistor on top. Broke off on first ride. Fixed it and working perfect since. Love the look of these. I used 5 min epoxy. Can recut and redo easily.
b1cnrt73 is offline   Reply With Quote
Old 10-05-2009, 04:14 PM   #15
HooksDaMan
I just bought an integrated taillight and it came with two little white boxes with wiring coming of the each side, their is two of them and I don't know what their for please help. Its volarmotorsport.com clear tailight with turn signals.
HooksDaMan is offline   Reply With Quote
04-06 Yzf-r1 Ufo Led Taillight punkdR1 Bikes For Sale 2 05-04-2006 03:24 PM
? for all who have a custom led taillight WhiteGTDropTop Appearance & Mods 1 06-26-2005 10:07 AM
FS: Custom LED '04-'05 R1 TailLight Logik Bikes For Sale 14 06-13-2005 03:41 PM
04 R1 Custom LED Integrated Blinkers FS RiFF Bikes For Sale 8 03-10-2005 09:27 PM
Custom LED packaging - Uncool Problem Child General Motorcycle Discussions 20 04-24-2004 05:06 AM
