07 R1 engine start event : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 07-08 R1 Mechanical Help
07-08 R1 Mechanical Help Mechinical and Critical Issues for the 07-08 R1
Old 04-17-2007, 09:57 AM   #1
th21
My GF ate me~~
th21's Avatar
Bikes: YZF R1 2007
Hello~
I just got my 07 R1....
And I found a problem that it's difficult to start the engine smoothly..
I tried 2~4 times for starting successfully when cool....
And tried 2~3 times for starting successfully when hot....
then it was still 2~4 times for me to do this when cool down 3 hours later...
Is there anyone having the same conditions??
Please let me know what's probably wrong.......>_<
Lovely country -- Native Taiwan
http://picasaweb.google.com/pme02th
th21 is offline   Reply With Quote
Old 04-17-2007, 09:59 AM   #2
Wheat
//Low-Life\\
Wheat's Avatar
Give it a little gas.
Wheat is offline   Reply With Quote
Old 04-19-2007, 09:02 AM   #3
JDollaz
Rebel w/ a Cause
JDollaz's Avatar
How Many Miles is on it?????
Happened to me a few times, But with less than 100 Miles.
Also it was +-40 Deg. Outside while i was Trying to start...
+1
I gave it a little gas and it started right up..
And FYI if you have a Problem getting into first from there.
The Kickstand has a Sensor, and wont go into gear with it down,,,
it will Stall...(Safety Feature)
R1-013 Lucky 13th Squadron: NY!
Sig Provided by : The Artist formerly know as Petrol !
JDollaz is offline   Reply With Quote
Old 12-06-2007, 03:02 PM   #4
Angelking
Angelking's Avatar
Bikes: 2007 Red R1
As soon as it starts to fire, hold the starter in a tiny bit longer. Works everytime.
AK
Angelking is offline   Reply With Quote
Old 12-06-2007, 03:42 PM   #5
MaJoR ChAoS
Memento Mori
MaJoR ChAoS's Avatar
like others have said, you need to hold the starter slightly longer than you would on other bikes you are used to and give it a little gas.
Also wait for that whiring sound to happen twice before you start.
MaJoR ChAoS is offline   Reply With Quote
Old 12-06-2007, 03:51 PM   #6
chadder
Hoosier Daddy
chadder's Avatar
Bikes: 07 Candy R1
AK
chadder is offline   Reply With Quote
Old 12-11-2007, 05:20 PM   #7
299
I'm slow,but i may not be last
299's Avatar
Bikes: Yamaha 01,04,07 R1 and Sparkz
does it happen to UK versions as well?
The R emblem on the rear is the legendary symbol of invincibility. Look at it close now dude, because you'll never see it again!......
299 is offline   Reply With Quote
Old 12-23-2007, 11:44 AM   #8
Josh_mp5
i have noticed that if i give it a little throttle right after it starts it will die. Any idea what would cause that?
Josh_mp5 is offline   Reply With Quote
Old 12-23-2007, 02:54 PM   #9
Angelking
Angelking's Avatar
Bikes: 2007 Red R1
uuhhh.....maybe try not doing that.
I let mine idle for for a few seconds anyway to let the oil flow.
AK
Old 04-20-2008, 10:44 PM   #10
getRdonecriss
my 2007 R1 is also having starting problems. has anyone found a fix for this. i also need to know if there is a recall on the ecu because my warranty is out and if i have to pay for it does any one know the cost.thanks for any help
getRdonecriss is offline   Reply With Quote
Old 04-21-2008, 10:45 AM   #11
tnole23
go go juice gonna make me win
tnole23's Avatar
Bikes: 2008 R1 Raven
new ecu is roughly $960.
tnole23 is offline   Reply With Quote
Old 04-21-2008, 11:00 AM   #12
getRdonecriss
hello friend im new to the forum and thanks for the shout out i have been having some minor problems with my 07 R1 and its geeting on my nerves.
Old 04-21-2008, 11:02 AM   #13
getRdonecriss
are you having any problems with your bike starting and if so is there a fix are will the new ecu fix that problem also
Old 04-21-2008, 08:47 PM   #14
yankin&bankin
Squid
yankin&bankin's Avatar
Bikes: '01 YZ-250,'02 YZ-250, '04 919 (Sold) '05 R1 (Sold) '07 R1
Not necessary.
yankin&bankin is offline   Reply With Quote
Old 04-21-2008, 08:48 PM   #15
yankin&bankin
Squid
22 ENGINE CONTROL UNIT
4C8-8591A-21-00 (replaces 4C8-8591A-20-00) 1 $867.28
www.crotchrocket.com
Old 04-26-2008, 07:19 AM   #16
Gridlock
#%^@$%^ Bike Thieves!
Gridlock's Avatar
Bikes: 2007 Charcoal R1, 2002 HD Sportster
Sine I got the de-lagged ECU in mine, it takes a little more to get it started when cold. Normally I will hold the starter and it will crnk 5-6 times and try to catch, but won't. I have learned to just keep holding it until the 7th or 8th turn over when it will catch for real and start.
Pazzo Levers | Gregg Flush Mounts |Ohlins Steering Damper | Michelin Pilot Powers | Competition Werkes Plate Relocater | Intuitive Swingarm Sliders | Graves Frame Sliders | Graves CF Slipons w/Cat Eliminator | PCIII USB | K&N Air Filter| Galfer Brakelines
My photos @ Flickr.com
R.I.P. Glenn "Elvis" Breaux - June 17, 2007
R.I.P. Chad "GAWarrior" Clifton - June 25th, 2008
Gridlock is offline   Reply With Quote
help... R1 wont start thegreatonex25 04-06 R1 Mechanical Help 10 03-29-2007 06:22 AM
help! R1 wont start thegreatonex25 Mechanical / Help 1 03-27-2007 04:28 PM
Truck Questions Devil's Wings Off Topic Talk 57 05-21-2006 12:12 AM
Difficult to start when engine is cold Shadow27 Mechanical / Help 3 08-30-2004 08:11 AM
hot engine start problem Rico750 Mechanical / Help 0 05-27-2002 05:02 PM
