Charging problem.... : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 02-03 R1 Mechanical Help
02-03 R1 Mechanical Help Mechnical and Critical Issues for the 02-03 R1
Old 04-22-2007, 12:33 PM   #1
mavspire
Hibernating
Bikes: Too Many!
Bike started misbehaving the other day. Oh well she's about due to make a fuss.
Initially it started with poor starts/bump starting. Now it's completely dead.
Just as it died, it looked as though it was running really low on electric power, lost one headlight altogether (bulp blew) the other headlights low-beam blew shortly after....only 1 high beam left running)...digi gear indicator was spazzing.....rolled up to the driveway and killed it...bah!; clearly the battery was keeping the bike going and not getting charged.
SO ....ran some tests;
Old Battery; 11.8v (after riding to 'sauga from hamilton)
Spare Battery 12.8v
Tossed the spare battery in; wired it up; it fired right away no probs)
Spare Battery Off: 12.8v
Spare Battery standy: 12.5v (no headlights, just gauge cluster/fuel pump)
Spare Battery running: 12.34v; (no headlights)
Spare Battery running: 12.11v; (1 high beam)
CLEARLY; I was not getting ANY charge to the battery whatsoever.
So on to test the stator and rectifier/regulator.
3 phase Stator wire:
Service manual spec says 0.19~0.23 ohms
Checking at harness:
1-2 => 0.2 ~ 0.3 ohms
1-3 => 0.2 ~ 0.3 ohms
I dont know whether there is supposed to be continuity between the 3 posts; but there definitely IS.
There are ***NO*** burnt/corroded plugs.
So if its one of the two; which one is it? Or is it both?
Sigh; my first day off with 21c and im stuck doing this bs =\
mavspire is offline   Reply With Quote
Old 04-22-2007, 02:42 PM   #2
onefastmx5
Bikes: Nothing right now :(
I bet the regulator is toast. Also, The Ohm test on the stator doesn't always work. I have seen a stator test good on ohms, then I did a amp output test and found it to be a bad stator.
onefastmx5 is offline   Reply With Quote
Old 04-22-2007, 03:11 PM   #3
mavspire
Hibernating
Bikes: Too Many!
Forgot to also mention; when revving at 5000rpms there was no change in the voltage.
How else can i test the stator?
Old 04-22-2007, 09:00 PM   #4
onefastmx5
Since there is no test for the regulator, I'd put a new one in first and inspect the wire connector on it for burn marks/good connection.. since its such a common problem. To do the amp output test you need an inductive amp meter clamp and I check the AC voltage coming from each white wire, and they should all be pretty close. The service manual kinda sux for electrical because they ahve you go through a few checks and at the end, conclude replace X part without a test for it.
Old 04-23-2007, 11:38 AM   #5
mavspire
Hibernating
Bikes: Too Many!
The harness plug and the rectifier itself are both mint and show no signs or corrosion or burning. It's really weird.
By any chance will an 04+ R1 rectifier work? They look totally different (bigger heat sinks on the 04) but the plugs are the same.
Old 04-24-2007, 03:02 AM   #6
02_r1inboston
02_r1inboston's Avatar
Bikes: 2002 r1
I'm not technical but seem to be having the same problem, second new battery in less than a month and went to start it this am and nothing.
02_r1inboston is offline   Reply With Quote
R1 Charging System Part 1 (long) Sam Farris Mechanical / Help 20 10-14-2011 04:22 AM
Tranny/cluch problem..... HELP!!!!!!!!!!! XShogunR1X Mechanical / Help 31 04-07-2007 02:42 AM
Charging problems, cant figure out!! tjtripp Mechanical / Help 4 12-31-2003 05:26 PM
Valve guiding problem R1 '98-'01 EUROPE ? GeR1ben Mechanical / Help 18 12-24-2003 01:00 AM
problem w/ charging system sKy27R1 Mechanical / Help 2 04-11-2003 04:01 PM
