How do I remove my exup valve motor : Yamaha R1 Forum
Old 05-17-2007, 07:39 PM   #1
05yamabomber
05yamabomber's Avatar
Bikes: 2007 R6 R Track, 2005 Raven R1 (street)
I want to remove my exup valve, well I was told to safety wire it open. I also heard not to unplug the exup motor. I wanted some input from the guys on the forum. What have you heard? I have graves Y pipe and slip on exhaust. Is there a jumper plug you can "trick" the computer to think that it is still working? This bike is just for the track. There must be a way, im sure guys with full exhausts remove the exup motor. Let me know. Thanks.
05yamabomber is offline   Reply With Quote
Old 05-17-2007, 08:14 PM   #2
broc944
I Ride Alone.
Bikes: 07 R1,02 RC51,73 CB350F,TR2 Replica,78 DT250,Kawi H1 & H2, Zundapp GS125
I think this is what you are looking for. Click HERE.
Full Akrapovic Shortened 3"-BST's-AK20 Axxion Kit-Penske 8987-Y.E.C. ECU-Beringer Front & Rear Mstr Cyl. & Front/Rear Calipers-AP Thumb brake,Ceramic Wheel Bearings-Bazzaz T.C./Quick Shift/ZAFM-Sato Rearsets-Machined Rotors-Robby Moto Throttle-520 Conversion-Tank Foam-Pirelli DRC's-Hyperpro RSC Damper-Gilles Adjusters-Spiegler Lines-Catalyst SS Tail-LiFePO4 Batt-Acumen Gear Indicator-CF Air Box Cover/Front Fender-CRG Bar End Mirrors-Woodcraft Covers/Clip Ons-Speedo Healer-Lots of TI
broc944 is offline   Reply With Quote
Old 05-17-2007, 08:18 PM   #3
chopiesel
chopiesel's Avatar
Bikes: 05 R1, TL1000R
just take the flap out and make a block off plate, then cut the cables at the motor.
chopiesel is offline   Reply With Quote
Old 05-17-2007, 08:48 PM   #4
05yamabomber
Has anyone installed the 7.5K Ohm resistor jumper? Or the sams servo for $99? Im trying to cut all the excess weight off the bike and it would be nice to get rid of that crap.
For now I am going to remove the flap and cut the cables at the motor but it would be nice to get rid of the entire motor.
One more question. What about the kickstand switch? Is there a way to bypass the kickstand switch? I may have to open a new thread for this too.
Old 05-17-2007, 10:14 PM   #5
aaask8tr
04 R1 parts for sale
aaask8tr's Avatar
Bikes: SV650 race bike / CRF 50
Until you get an aftermarket header, leave in the EXUP valve.
The kickstand wires (2 of them) just need to be opened or closed circuit. I forgot. I think there just wired together.
And if you really want to remove the EXUP valve, remove the cables from the motor, you don;t have to cut. If you remove the motor you;ll get an FI code.
Red is faster
aaask8tr is offline   Reply With Quote
Old 05-19-2007, 04:00 PM   #6
HKr1
HKr1's Avatar
Bikes: YZFR1SPV
HKr1 is offline   Reply With Quote
Old 05-19-2007, 06:40 PM   #7
05yamabomber
Well, I talked to Graves Motorsports Tech support and was told there is no issues removing your entire exup valve servo motor (unlugging it), although it will throw a code (engine light will come on). He said most racers just put tape over the light. So that is the route that I am taking. He did mention the "sams servo sub" for $99. But it is not required. (wont do damage). I safety wired my valve open and removed the motor. This is just a track bike and I dont mind taping over the engine light.
Any more thoughts?
Old 05-20-2007, 10:06 AM   #8
yuri_1
yuri_1's Avatar
Bikes: R1 06
PM me your E-mail I have circuit diagram and how-to for a simple electronic device for 5 $ It was posted here by a german guy long time ago. I will test it in the upcoming weeks still looking for some electrician to make it.
yuri_1 is offline   Reply With Quote
Old 05-22-2007, 01:54 AM   #9
05yamabomber
PM sent to yuri_1. I would like to check out the diagram. I can probably build it at my work when I get back in the counrty.
I pulled the servo motor and safety wired the exup flap all the way open, so of course my engine light is on. I will keep everyone posted on a wiring diagram.
Old 06-03-2007, 07:59 AM   #10
SoCalR1Rider
Cracka' What!
SoCalR1Rider's Avatar
Bikes: 1999 - R1 Track. 2001 R1 - Sold (For Now), 2001 GSXR 750 - Track Bike (Sold), 1985 Interceptor, 1985 V65 Magna, 1983 V45 Magna
I have been making the same sort of mods to my '99. I completely removed the EXUP valve rather than just safty it open - it was really simple. I would also like to get rid of the motor, it is just getting in the way. On the 99 if I remove the actuator, the Tach acts crazy jumping from 0 to 8k. The tack is the "check engine light" for the 99, so just unplugging it isn't and option.
I also PM'd yuri_1 - thanks.
SoCalR1Rider is offline   Reply With Quote
Old 06-03-2007, 08:40 AM   #11
mad271r1
Bikes: 2004r1
Hey just curious how has the bike acted since u have done this?? I would like to do the same to mine i have slip on and no converter with pc3 but was told if i removed the valve it wouldnt run right??? for my situation would i benefit from removing the valve??
R1-016 'Venom' Squadron the best Squadron
mad271r1 is offline   Reply With Quote
Old 06-03-2007, 10:15 AM   #12
yuri_1
yuri_1's Avatar
Bikes: R1 06
All PM repled. actually here in some thread is a link to the diagram also discussion about it, but I can't find it.
It's is made for the old R1's 99-03 but it should work on 04-06 also.
As much I know (not 100% shure) disconnecting the exup motor will limit the engine it's not only the light or tacho problem.
Anyway I will send it to anyone interested. If somebody test it please keep us posted for the results
Old 06-03-2007, 02:22 PM   #13
SoCalR1Rider
Cracka' What!
Thanks a lot. I already ordered the components!
Old 06-03-2007, 02:26 PM   #14
Wheat
//Low-Life\\
Hell, share it with us all....
Wheat is offline   Reply With Quote
Old 06-03-2007, 09:47 PM   #15
yuri_1
yuri_1's Avatar
Bikes: R1 06
Ahhh Wheatman As I said there is already a thread about this I'm shure you where involve in it. Didn't you mention this German guy? the thread was about the resistor think.
SoCalR1Rider - keep me posted. I still can't find somebody to make me one
Old 06-03-2007, 09:49 PM   #16
Wheat
//Low-Life\\
Doesnt ring a bell, Send it to me and i'll post it up if you dont wanna. Sounds like you have it figured out...
Old 06-03-2007, 10:13 PM   #17
yuri_1
yuri_1's Avatar
Bikes: R1 06
later today I will host the files and post a link.
Old 06-04-2007, 08:22 AM   #18
05yamabomber
To answer the question, "how does your bike run since you pulled it?" Well, the bike is a track bike only and I am out of the Country until June 16th. I have a track day on July 7th at California speedway. So that will be the first time I will run it.
About the comment on bike wont run right, I called the Tech support at Graves motorsports, was told that the racers are pulling the motor, taping over the Check engine light. Seems to be working ok.
I was told not to do it for the street, but for the track is ok. The exup really helps with back pressure when driving around town.
I will let everyone know after my track day (1 month). I am counting the hours!
Old 06-04-2007, 08:38 PM   #19
SoCalR1Rider
Cracka' What!
The parts shipped out already. I will be at the track on Friday, but might have some time to put one together this weekend and try it out. I have a '99, but they should all work the same. If I get it up and running I will post here.
Old 06-05-2007, 10:48 AM   #20
mad271r1
Bikes: 2004r1
i do alot of street riding also so in my situation might be better to leave it alone???
Headwork Winter Project marcaztls 02-03 R1 Mechanical Help 20612 03-28-2015 11:29 AM
Ouch! Got my Motor Back - Piston & Valve Pics extrakt0r General Motorcycle Discussions 17 07-31-2006 12:31 PM
EXUP valve and error light jimmyp How To's 2 04-29-2004 08:03 AM
Need help checking exup servo motor 414_R1_R1d3R Mechanical / Help 0 03-07-2004 09:15 PM
exup valve TD1 General Motorcycle Discussions 13 01-22-2004 10:20 PM
