tachomter error codes : Yamaha R1 Forum
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!Graves Motorsports
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 98-99 R1 Mechanical Help
98-99 R1 Mechanical Help Mechanical and Critical Issues for the 98-99 R1
Graves Motorsports
Old 06-08-2007, 01:07 PM   #1
trevasja
With the ignition on and engine not running I get the tach jumping from 0-6 then back to 0
Are there codes associated with this??
Thanks
JEFF
trevasja is offline   Reply With Quote
Old 06-08-2007, 01:41 PM   #2
ChrisR102
GO BIG OR GO HOME!
ChrisR102's Avatar
Bikes: 2002 R1, 2007 R1 (stolen)
does it do it real quick as soon as you turn the key on. cuz i think it's supposed to. what year? and are there any other problems besides that?
2002 R1-Sportech chrome windscreen, spiked windscreen bolts, hotbodies undertail exhaust, dynojet PCIII, vortech chrome spiked frame sliders, sixty61 spiked swingarm spools and barends, tricktape vinyl graphics, scott's damper more to come....
ChrisR102 is offline   Reply With Quote
Old 06-08-2007, 02:15 PM   #3
trevasja
No it does it continuously - 0 - 6K - 0 - 6K every 5 seconds
It does the same thing when it is running.
1999
Thanks
Old 06-09-2007, 12:46 PM   #4
mickr1
My R1 used to eat me!!
mickr1's Avatar
Bikes: 2000 R6/Upgraded 2002 R1/Totalled after 10 weeks/2002 R6/Stolen so now 1999 R1 and KLR 650 99
are you sure it is not 7000rpm as this is the exup
www.sites4bikes.com
Polished Rims
Carbon Vented front mudguard
Carbon Vented rear hugger
Braided hoses front and rear
Yoshi R7 oval stainless slip on
Ohlins steering damper
R1 top yoke cover
R1 wavy rear disc
R1 reservoir cap
Double bubble irridium screen
Pazzo Shorties
Datatool System 4
mickr1 is offline   Reply With Quote
Old 06-09-2007, 05:44 PM   #5
trevasja
Got it!!
I never ran out of gas before. Tach goes to 8K when i am emty
Thanks
JEFF
Old 06-10-2007, 12:19 AM   #6
mickr1
mickr1's Avatar
Tacho will show 7k rpm for the exup and 8k rpm for the fuel sender
Check connections under the tank
Also you might want to check the big white connector under the left fairing infil....be careful when you pull it as the pins are known to corrode and break off....if all pins are intact then spray clean and apply some dielectric grease
This big plug can show multiple errors
Good luck
www.sites4bikes.com
Polished Rims
R1 top yoke cover
R1 wavy rear disc
R1 reservoir cap
Pazzo Shorties
Datatool System 4
