Techtronics Quickshifter Install Question : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 02-03 R1 Mechanical Help
02-03 R1 Mechanical Help Mechnical and Critical Issues for the 02-03 R1
Old 06-10-2007, 12:17 AM   #1
DeconSly
DeconSly's Avatar
Bikes: 2003 R1 Race bike
Hey everybody
I've got a small question I’d like to get some opinions on. If anybody has ever installed a Techtronics PQS3 quickshifter on a R1 and can give me the answer all the better.
I'm 98% done with the install but can't see to find a proper connection for the tacho signal. I tried the grey wire from the crank shaft position sensor because my Clymer manual says it provides rpm data to the ecu. That didn't work! Now my Datatool DiGi gear indicator makes a connection to the yellow/black wire coming from the meter as a tacho signal so I tried that and still I get nothing.
To give you a better idea of what not working means. The PQS3 has ratio menu and in that menu it has a EnG display that should show the engine rpm. This stays at zero.
Any help would be greatly appreciated
DeconSly is offline   Reply With Quote
Old 06-12-2007, 12:50 PM   #2
DeconSly
DeconSly's Avatar
For anybody who might want to install a Techtronics quickshifter on a 02-03 R1. The right connection was to use one of the coil negative leads. I used the orange wire form coil #1
yellow/black wire from the meter that works for the Datatool DiGi gear indicator would not work with the quickshifter
Need Install pictures for QuickShifter on 03 R1! AnonymousR1 General Motorcycle Discussions 9 08-04-2006 02:18 PM
Techtronics Quickshifter How To R1 Kid How To's 6 03-27-2006 03:20 AM
Techtronics quickshifter need help!!! R1 flewbyu Mechanical / Help 4 01-23-2005 07:43 PM
Techtronics Quickshifter All inclusive $375 SV Rider Bikes For Sale 3 09-06-2004 02:44 PM
Question: Libertek relay install Banchi94 Appearance & Mods 5 11-16-2003 11:15 PM
