» Site Navigation |
» Motorcycle Forums
| 00-01 R1 Mechanical Help Mechanical and Critical Issues for the 00-01 R1 |
07-01-2007, 09:12 PM
#1
R1's are the best.
Bikes: 2000 Yamaha R1 (RED)
00-R1 starting problem
I have a 2000 R1 that just died on me. lights come on and engine cranks fine. It is not getting any spark to any of the plugs witch make me think its not the coils. The parts guy at the shop thinks that it is either the CDI box or stater. I heard roomer that it could be the rectifier/regulator. It was running fine and turned it off, when I tried to turn it back on it woudnt ignite. I finally got it to start and gave it a good rev and it died. It turns over strong but will not ignite and stay running. Any opinions?
07-02-2007, 07:47 AM
#2
My R1 Eats Me.
Yep. Check the rectifier. It's right under the seat. About the size of a cigarette box. Look at your wires and make sure none are melter or corodded. I have this model and it is very common.
WES
07-02-2007, 03:33 PM
#3
para bellum
yeah sounds like the reg/rec. It stops regulating and you're pretty hosed. Some signs are burned out connectors on the r/r and a really hot and bulged battery.
let me know how it goes.
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
07-02-2007, 07:18 PM
#4
R1's are the best.
I took off the r/r and inspected the connector. This connector has three white wires that I believe go to the stater.?. and has one red and one black wire. The middle white wire looks burnt out.. I think im going to try to re-do the connector and if that does not work I will buy the r/r. I hope its not the stater or CDI box, $. Would anyone know how to test a stater coil or r/r without having another one on hand???
07-02-2007, 07:38 PM
#5
Has anyone seen my ratchet?
Bikes: A few of them
WES
The wife now rides my old 00 and I had the same deal, bike died, acted crazy, and the rectifier plug pins were melted, I did a repair, and it has been fine. Run a search you will find ways to test every aspect of your problem.
Mine 07 R1 -Blue
Hers 00 R1 -Blue
The Boys 00 & 01 R6 -Blue
Mine 00 Yam Banshee -Blue
Hers 00 Yam Banshee -Blue
Mine 97 Yam GP 1200 -Blue
Hers 97 Yam WaveVenture 1100
Mine 04 YZ250 -Blue
The Boys 2 -02 Yam YZ 125's -Blue
The Girl 01 Yam Blaster -Blue
Pit Bikes 4 CRF50's -Blue
47cc Pocket Bike -Blue
49cc X7 R1 Replica -Blue
The Boys - 2 modded Goped Sports
The Girl - Geo Bigfoot Goped
SCARAB SPORT 302 !!!!
07-03-2007, 08:47 AM
#6
Step up or step off
Bikes: 2000 R1
know any one on here selling them?
07-03-2007, 11:54 AM
#7
I believe the rectifier is less than $70, but you can easily fix the pind on the plug.
Mine 07 R1 -Blue
Hers 00 R1 -Blue
Mine 04 YZ250 -Blue
07-03-2007, 05:02 PM
#8
My R1 Eats Me.
Yes. Very easy fix. What I did was cut the wire back about 4 inches into the harness. I then cut the section out of the plug that was melted. Went to Lowes, Auto store, etcccccc and bought some connectors to put on the new end. The wire is no longer connected to the main connector. I wanted to I could disconnect that wire while leaving the main harness connected.
I then put a fan on my rectifier so it never gets hot now. I was in traffic on the highway moving around 10 mph and the rectifier was cool to the touch.
It doesn't even take a big fan.
http://www.r1-forum.com/gallery/wate...php?file=15023
WES
07-03-2007, 05:06 PM
#9
Even better than mine, however even my simple fix has no issues .... here is the thread
http://www.r1-forum.com/forums/showthread.php?t=194553
Mine 07 R1 -Blue
Hers 00 R1 -Blue
Mine 04 YZ250 -Blue
07-03-2007, 07:31 PM
#10
My R1 Eats Me.
Originally Posted by yamahog
Dude. Mine looks exactly like that pic you posted on there. Exactly. Great minds think alike.
WES
07-08-2007, 09:39 PM
#11
No Job! Get Out Bitch!
Bikes: 2001 R1 (sold), 2006 R1
My R/R went bad on my 01 also.
I installed a muffin fan several years ago and have never had a problem since.
07-19-2007, 12:23 AM
#12
Make sure batt. voltage is at least 12.4. Your CDI will not work without at least 12.4 volts. The bike will still turn over fine but no ignition.
07-19-2007, 07:11 AM
#13
Step up or step off
Bikes: 2000 R1
i can get that out of the bat but i took it out last night for a little while and tried to ride and stop and before i got back i barely had enough juice to start it back up. i got it started and got it home so i am thinking it must be the stator now!
08-04-2007, 03:07 PM
#14
Bikes: 2000 R1
Best bet, chek the voltage. I changed out the stator, flywheel, and thought I was ok... till today. My rectifier may be ok, but the wires are totally corroded. I pushed my bike about a half mile back to my house, but in 100 F weather.
Went and bought a voltmeter and just wondering how to use this... Im a plumber, not a electrician! Where exactly do you check?
08-07-2007, 08:40 AM
#15
The connections from the plug to the rectifier MUST be the first thing you guys check! The first and easiest way to check voltage is from at the battery with the bike off, with the bike at idle, and with the bike at 5000 rpms.
Mine 07 R1 -Blue
Hers 00 R1 -Blue
Mine 04 YZ250 -Blue
08-07-2007, 01:46 PM
#16
Step up or step off
Bikes: 2000 R1
It was the burned plugs that was giving me trouble. I am starting to think that might have been the problem from the begining. oh well atleast i know everything else is good. Thanks guys for all your help
08-07-2007, 01:54 PM
#17
Bikes: 2000 R1
Good, now ride out to my place and show me what Im doing wrong! LOL! I think it may be the same for me. gonna take it all apart tonight to seee what is wrong, and then also install a lil fan on the r/r too. new stator is here, and I can now see about getting the bolt to take off that damn flywheel.
08-07-2007, 02:21 PM
#18
Step up or step off
Bikes: 2000 R1
I went to advanced auto and purchased a couple of bolts to take off the flywheel. i had to cut the tip of the bolt off with a hack saw and then put it on an impact gun to take it off. if you can also tap it with a rubber malet to losen the flywheel. it is a pain in the ass but i will come off. remember, there is oil in there so you might want to have a pan ready to catch it when you take off the cover.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
