Yamaha R1 06 de-restrict - Page 2 : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 04-06 R1 Mechanical Help
04-06 R1 Mechanical Help Mechinical and Critical Issues for the 04-06 R1
Motorcycle.com
Old 08-08-2007, 12:18 PM   #21
ØLMHEIM
ØLMHEIM's Avatar
Thanks swedie. Thats may be the way to go.
ØLMHEIM is offline   Reply With Quote
Old 08-18-2007, 11:45 AM   #22
Duck
Duck's Avatar
Bikes: 08 R1
Same in the UK too, get the immobiliser
try www.ebay.co.uk
There are two types of people in the world, the thinkers and those that just get on and do it.
Duck is offline   Reply With Quote
Old 08-18-2007, 04:57 PM   #23
GTSCustoms
F$% one donut just isnt enough
GTSCustoms's Avatar
Bikes: Currently own custom 2006 R1 and 2006 GSXR1000, 2003 GSXR1000 (custom, sold on ebay), 2001 tl1000r (sold), 1999 r1 (given away to close friend)
try www.ebay.co.uk
sounds cool, let us know how this works out for you
2006 R1 mods are in the making, see: My project Bike
Digital Photos hi-res shots courtesy of Minacious
GTSCustoms is offline   Reply With Quote
Old 10-03-2007, 06:50 AM   #24
ohlarikd
Life is better on a R1
ohlarikd's Avatar
Bikes: 06 50th R1, 05 KTM 525 SMR
What ever happened to this? Has anyone ever Dyno'd one of these 'restricted' bikes to see how much is held back?
Derek
ohlarikd is offline   Reply With Quote
Old 10-03-2007, 03:22 PM   #25
newyorkchuiR1
newyorkchuiR1
newyorkchuiR1's Avatar
Bikes: Yamaha R1 "05" - Honda600RR "03"
Exclamation E.c.u.
does anyone know's if Ivan's Tre fix the timing on the "04 - 06"
my "05" R1 rocks !!
newyorkchuiR1 is offline   Reply With Quote
Old 10-04-2007, 09:09 AM   #26
1longR1
Ghostrider Squadron
1longR1's Avatar
Bikes: 00 r1 now 04
there is no need. unless its in country that restricts the motor on bikes..which in US the biks are not restricted. the tre.. is Timing Retard Eliminator... there is not timing retard in the 04-06 R1's. now suzuki does this on busa and gszr1k only in 6th gear. the TRE fools ECU that bike is in 5th gear all time which kills the gear indicator and only runs the 5th gear mapping on bike. most guys at dragstrip remove the TRE from busas.. as it slows them down in 1/4 mile. only good for top speed stuff really. but again the 04-06 R1 do not have any type of retard in timing, so no need for them. they dont need retard as bikes wont surpass the manufacturers agreed upon 186 mph limit anyway, due to HP, aero and gearing. the R1 will top out at whatever speed it will with HP, gearing and aero on bike. so if you make 250 hp then it will surpass the 186, but in stock form it wont quite get there.
R.I.P K_FleXXX June 15, 2006
R1-015 `Ghostrider` Squadron
1longR1 is offline   Reply With Quote
Old 11-18-2007, 09:06 AM   #27
BBuso
BBuso's Avatar
Bikes: Blue '06 R1,nlue race bubble, led rear light, akra , SS brake front,rapidbike 2
http://nl.youtube.com/watch?v=9j-unRCKKw8
how to deristrict an 06 R1, unfortunately in french...
BBuso is offline   Reply With Quote
Old 11-18-2007, 11:32 AM   #28
1longR1
Ghostrider Squadron
1longR1's Avatar
Bikes: 00 r1 now 04
yes.. but some european models, including the R1 are restricted over there. US models are not restricted in hp so it wont work for bikes in states.
Old 01-13-2008, 04:46 PM   #29
MotoGPracing
MotoGPracing's Avatar
Bikes: YZFR1SPV
Good Find
MotoGPracing is offline   Reply With Quote
Old 01-26-2009, 09:05 PM   #30
canadianR1rider
R1, It carries the Respect.
canadianR1rider's Avatar
Bikes: 2006 Yamaha YZF-R1
Question Wtf?
OK guys so I'm trying to follow this thread, my 06 r1 hits the rev limiter in all gears but 5th. Yet in 5th, at 299kmph i am limited out at 11600rmp(approx). So being there is another oh, 2000rpm left, there has to be a simple change out. I agree that no matter what you do to a stock bike improving BHP you will still hit the same 186 magic number only you get there faster. But is there no way to get through the speed limiter(I have researched through other road racers and the answer is not the ECU from another country as they all use the same ECU, short of ordering a Racing ECU and complete harness)?
Ray
CanadianR1Rider
canadianR1rider is offline   Reply With Quote
Old 03-01-2009, 07:42 PM   #31
mccutch2u
MYR18U
mccutch2u's Avatar
Bikes: 2004 R1, 05 r1, 2009 r6
i have seen 189 on my speedo then it quits but i doubt that i am going that fast considering gearing even with all of my mods so even if you were a true 200mph i think the speedo will quit at 189
I have been thinking of going to maxton to get a true top speed mph
2004 R1, FULL TIFORCE TI EXHAUST PC3, IGN MODULE, GRAVES BLOCK OFF, BMC AIR FILTER, PAZZO LEVERS LP DBL BBL WINDSCREEN,
mccutch2u is offline   Reply With Quote
Old 08-07-2009, 06:08 PM   #32
Larosh
2005 R1 Euro spec - only 100 bhp :-(
Guy's, firstly... excellent site!!!!
I have bought a used 2005 R1 but after putting up ~100 miles on it I was unhappy with the power, especially after ~8K rpm. Further investigation shows the bike to have originated in France which suggests it is restricted explaining the lack of power. I spent a lot of time searching on this (again.. excellent!!) site and found some info (http://www.r1-forum.com/forums/showthread.php?t=14652) and a link to a cracking site: http://borg20014.tripod.com/service_sectionk.htm
but the link (http://www.r1team.com/acc-yzfr1-768.htm) to derestrict the 04+ appears to be broken.
Anyone know if ALMHEIM solved the problem? Or can anyone direct me to where the instructions are to derestrict the 04+ R1... need more power:-) :-)
TIA
Larosh is offline   Reply With Quote
Old 08-10-2009, 11:09 AM   #33
R1 Gravity
R1 Gravity's Avatar
Bikes: Yamaha R1 06 Model (US)
Hi if you want to de-restrict the french re-stricted bike you have to get access to the ECU and at the wiring end of the ecu you will see a grey wire that is in a loop coming out of the ecu and back in the ecu, cut the looped wire in half it is a ground wire that restricts it then you are all done it will be un-restricted , please don't ask me how many bhp it will be then, but you will sure know the difference.
Yamaha YZF-R1 06 Model (US) un-restricted, Full Titanium Graves Exhaust System, Graves Velocity Stacks, Graves Smog Block Off's, K&N High Flow Air Filter, G-Pack, Speedo healer V4, PCIII Power Commander Just Running The Standard Graves Road Map, -1 front sprocket , In need for a custom Graves map can anybody help ????[IMG]=''http://www.citybikerscrew.org/images/YHRDIB.jpg''[/img]
[url''=http://www.citybikerscrew.com'']http://www.citybikerscrew.com[/url]
R1 Gravity is offline   Reply With Quote
Old 08-10-2009, 11:10 AM   #34
R1 Gravity
R1 Gravity's Avatar
French R1
let me know if this solved the problem
Old 11-19-2010, 06:03 PM   #35
scottsr12001
Bikes: 01 R1
not sure, just picked up 08 R1.. crashed my 01 R1. the 01 had a full yosh exhaust, jetted carbs, very fast.. was told the 08 has a restricter on engine, not sure how to de-restrict
scs
scottsr12001 is offline   Reply With Quote
Old 11-19-2010, 06:08 PM   #36
hoov100
Congratulations for answering a 1 year old thread. The 07+'s are restricted by the ECU.
Join the 1,000,000 strong for arizona immigration law facebook page
hoov100 is offline   Reply With Quote
yamaha yzf r1 1999 de-restrict RAUNVIK 98-99 R1 Mechanical Help 2 07-14-2007 05:02 AM
How to de-restrict a 06 model R1 kalimaro How To's 12 05-28-2007 11:07 PM
How to de-restrict 2002 R1 la-la-la-la-la How To's 2 06-14-2004 01:43 AM
How to de-restrict 02-03 R1`s YamaLude Mechanical / Help 18 01-05-2004 05:08 AM
De-restrict a Cali bike Kyrio Mechanical / Help 10 02-14-2003 09:51 AM
