» Site Navigation |
» Motorcycle Forums
09-04-2007, 03:34 PM
#1
HELP : How to adjust Carbs 2000 R1
First off let me apologize for being a noob. I am having trouble with idle on my r1. Cold start its perfect runs great just a tiny bit over 1k rpm at idle. 5 Mins of riding and my idle sits at 2500. I have tried adjusting the carbs a few times now, but I must be an idiot. To reach the screws, I have the bike off, gas tank flipped up, air box off, and i have to twist the throttle to reach them right. I know I'm retarded, but how can you adjust idel without the bike running? Is there a trick to it I am missing.
PLEASE if anyone could give me a couple pics and a write up on proper stock carb adjustment I'd be forever in your debt.
Thanks in advance,
Desperate Noob
09-05-2007, 05:03 AM
#2
RUSH HOUR RIDERS
Bikes: 2008 Raven R1
There is an idle adjustment knob on the left side that you can reach without having to remove anything.
2008 Raven R1
- MJS Performance carbon fiber race slip ons
- Flashtune reflashed ecu with interface cable
- Dynojet PCIII
- 02 sensor removed
- Leo Vince y-pipe(black ceramic coated)
- Motion Pro Revolver quarter turn throttle
- BMC Race air filter
- EXUP removed
- Graves servo eliminator
- Sharkskinz belly pan
- A&R smog block off plates
- Rizoma Dynamic mirrors
- Puig dark smoke windscreen
- Acumen gear indicator
- Driven 520 sprocket conversion(-1 front)
- Apex adjustable clip-ons
09-05-2007, 06:04 AM
#3
Bikes: 98,1/2. R1
Thanks in advance,
Desperate Noob
you are talking about the synching screws between the carbs! that is not the idle adjuster. do a search it's been discussed here plenty.
09-05-2007, 06:31 AM
#4
R1, "A Superior Addiction"
Bikes: 06 R1
Thanks in advance,
Desperate Noob
As already said, there's a small black knob on the side of the bike located somewhere under the tank. I had an 02 but can't remember exactly where it is. If you turned the screws on the carbs you'll have to take your bike to a professional to re-adjust each individual carb.
09-05-2007, 06:34 AM
#5
Bikes: 98,1/2. R1
you are correct, except the knob is cad/zinc colored.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
