'07 R1 brake assembly on '06 R1 : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 04-06 R1 Mechanical Help
04-06 R1 Mechanical Help Mechinical and Critical Issues for the 04-06 R1
Old 11-04-2007, 07:27 PM   #1
Twincharge7
I was wondering if anyone ever tried to install the brake caliper of '07 R1 onto '06 R1? Any suggestions r welcomed
Twincharge7 is offline   Reply With Quote
Old 12-02-2007, 02:02 PM   #2
2pdfst
G@mem@ster
2pdfst's Avatar
Bikes: R1 all Black
well at least i am not the only one, but i was wondering more about the brake calipers. i would assume the the rotors just need to be the same size and have the same bolt patterns and spacing specs.
2pdfst is offline   Reply With Quote
Old 12-02-2007, 08:27 PM   #3
Twincharge7
I guess we have to go w/ the route of using '07 wheels to match the same bolt patterns and spacing specs.
Old 12-03-2007, 05:00 PM   #4
2pdfst
G@mem@ster
2pdfst's Avatar
Bikes: R1 all Black
no, you just have to go measure the rotors and their holes. why would you wanna go with the rotors and not consider the actual calipers?
Old 12-03-2007, 06:50 PM   #5
Twincharge7
I think you misunderstood me. I want the 6 piston '07 calipers however, '07 disc is 10mm smaller than '06. Yes, you're right regarding that I have to measure the rotors holes. I'm not positively sure that the repair manual has that info. Now, who in this forum has that info?
Old 12-03-2007, 07:14 PM   #6
bender
bender's Avatar
Bikes: 04 R1, 08 CBR 1000RR
It's pretty obvious visually that the center to center dimensions of the bolt holes on both models are different. The 07's are much further apart, but measure to be sure.
bender is offline   Reply With Quote
Old 12-03-2007, 07:21 PM   #7
Jourdan_D
My R1 eats yours
Jourdan_D's Avatar
Bikes: 01 f4i, 02 F4i, 99 R1, 05 600rr, 06 gsxr750, 07 R1
You need 07 wheel bearings, axle and front forks for it to work.
The Gaytors Suck!
Jourdan_D is offline   Reply With Quote
Old 12-03-2007, 07:24 PM   #8
Our1
Local Pavement Ripper
Our1's Avatar
Bikes: Track Ready 06 R1 Bluuuue (Mine) Metallic White '05 R6 (Hers)
The front wheel is the same. So I would think that the rotors would bolt up just fine. However, some things as far as spacing is concerned, is the bolt spacing for the calipers, and the angle that they sit at. Also, would stock brake lines or an aftermarket setup already in place work?
Name:	2006 brake.gif
ID:	315896   Click image for larger version
Name:	2007 brake.gif
ID:	315897   Click image for larger version
ID:	315898   Click image for larger version
Graves s/o-PC3-Graves V Stacks-BMC race-Tune by MC Dyno Tech (Hitman)-Stealth+2-Ohlins Damper-Penske double-Traxxion Dynamics by Suspension Solutions-Goodridge F&R-CRG shorties-Graves fixed rearsets reverse-Vortex & Graves sliders-Greggs mirror blockoff-Greggs stainless barends-CRG mirror-Graves mirror adapter-Greggs flushmounts-Custom LED taillight-Greggs wired LED cut in tail-Libertek relay-Graves fender eliminator-Scorpio alarm-Custom Corbin-solo cowl-Renthal grips-Diablo Corsa 3's
Our1 is offline   Reply With Quote
Old 12-03-2007, 07:30 PM   #9
Twincharge7
thank you thank you :
Old 12-03-2007, 07:40 PM   #10
2pdfst
G@mem@ster
2pdfst's Avatar
Bikes: R1 all Black
tech opinions are very helpful. i had seen a post here where a member swapped out calipers (or so he stated) and i wanted to confirm that statement.
Old 12-03-2007, 07:46 PM   #11
Our1
Our1's Avatar
Axles are the same, but the bearings are different. But the inner and outer diameters would be the same since the wheels and axles are the same. Widths could be different, and All Balls doesn't show a kit yet that I saw online.
I'm thinking for better braking and feel you might be better off with a good set of pads and a Brembo master cylinder. Unless of course you can come across a set of used forks and calipers at a decent price.
Old 12-03-2007, 07:50 PM   #12
Twincharge7
mmhhh...now, I'm not sure with how I'm swapping the bearings in my machesini wheels and on top of that, I have ohlins forks. damn...I always want to have 6 piston calipers!!
Old 12-03-2007, 08:04 PM   #13
2pdfst
G@mem@ster
2pdfst's Avatar
Bikes: R1 all Black
gonna take my bike to the shop and measure as much stuff as possible and not wait on answers, will let you know what i find out.
Old 12-03-2007, 08:32 PM   #14
Our1
Our1's Avatar
yes, keep us updated
2000 front brake reservoir / headlight assembly LathersR Bikes/Parts Wanted 2 09-13-2007 07:29 PM
04-06 New Oil Filters, Brake Lever Assembly speedslave Bikes For Sale 5 03-11-2007 05:02 PM
need right footpeg/brake assembly R1fireman Bikes/Parts Wanted 3 10-03-2005 07:26 AM
Need Right clip on, brake assembly, and throttle cable for '99 R1 MegaPower Bikes/Parts Wanted 8 11-29-2004 03:15 PM
99 R1 rear brake assembly WERA #127 Bikes For Sale 0 04-26-2004 06:34 PM
