Corbin Pacific Inc.
McCoyMotorsportsPartsPitStopRiders DiscountOPP RacingMotorcycle.comCycleGear.com
Go Back   R1-Forum.Com > R1 Related Discussion > How To's
Sponsored by: Leo Vince Racing
McCoyMotorsports
Old 11-15-2007, 10:42 PM   #1
Trey
I'm just the FNG.
Trey's Avatar
Bikes: 07 R1 - Charcoal
Garage door opener mod....one of the best yet!!!
So I wanted a garage door opener on my bike. My first, very caveman, design was an opener attached with Velcro to my triple clamp. Well effective, it looked like crap and could be stolen very easily. My new plan was to create an opening system that would be out of sight and could be activated without taking my hands off of the bars. What I came up with is a system hidden under the gas tank that is activated by turning on my high beams. The cool thing about this set up is that it can not be activated unless the bike is running, and no one would know it is there. I figured I could just hook the opener up to the power source on the bike, but that was not the case. The bike puts out 12 volts, and the opener requires 3 volts. I tried taking apart cigarette adapters and hooking them up to the opener with the hopes it would convert the 12 volts to 3 volts with very little work, but it was more of a pain in the ass then it was worth. Turns out most chargers put out varying volts depending on what is being drawn by the device (such as a cell phone). Even the one 3 volt non-adjustable adapter didn?t work (I think it was bad to begin with). So I went to radio shack and got a few parts (under $10) and built my own converter. The main parts needed at radio shack are a 100 ohm resistor, 150 ohm resistor, and an LM317 regulator (also know as a buck converter). Here is the build and most of the install. The system converts 12 volts to 3 volts and has worked flawlessly for the past few months (even through washes).
First the garage door opener. I think most modern remote garage door openers work on 3 volts, but some older ones work on 12 volts (so you could skip the voltage conversion). Take the remote apart like you were changing the battery. Then remove the circuit board from the plastic housing. Take the battery out from the unit (no longer needed). Take note where the battery contacts the board. The top of the battery is the positive and the bottom is the negative. Also take note where the button is that you depress to activate the remote.
Then you will have to wire the opener so that it is always in the activated position. I used a small piece of metal and soldered it (you can see it one the bottom, center of the circuit board). Once this is done, you can put the battery in to make sure you got the right leads. If the door moves, then you got it right. Remove the battery and leave it out forever. Next step is to wire on positive and negative leads to the back side (or front, does not matter) of where the battery used to be.
Take the leads you wired on and touch them to the 3v battery. Same thing, if the garage door moves, your connections are good.
Then fit the circuit board back into the plastic housing so that the wires have a place to come out. I cut the part out of the back where the clip went. That?s it for the remote.
Now to make the 12 volt to 3 volt converter. Here is a poorly drawn diagram.
**Make sure to use heat shrink or electrical tape in appropriate spots (must put heat shrink on before solder connection is made) ** SOLDER ALL CONNECTIONS. Take a long (long enough to get from the gas tank to the headlight) two lead (positive and negative) wire, and wire the positive (12v in) to the far right of the three posts on the LM317 regulator. Next wire the 100 ohm resistor between the center and left posts of the LM317 regulator. Then take the negative wire (12v in) and wire the 150 ohm resistor between it and the far left post on the LM317 regulator. Then, where the negative lead and the 150 ohm resistor connect, wire that to the negative lead on the remote control. Finally, wire the positive lead from the remote to the top tab of the LM317 regulator (opposite the three posts).
Back side.
Then I moved the heat shrink into position and cleaned everything up. This is how it should look when finished.
I tested the unit by touching the two leads to the battery in my motorcycle (make sure you touch positive to positive, and negative to negative). With power applied, the garage door should activate. Once I verified it worked, I placed the converter I made on top of the remote control and taped everything up with electrical tape. The finished product looked like some sort of bomb (don?t call the cops).
I placed the unit under my gas tank near the right side of the frame. Then I ran the two wire lead under the right side fairing to the right side high beam. I removed the high beam connector and opened the flap door, exposing the two leads inside. I carefully used a small screwdriver to free the leads from the housing. I then soldered the leads from the unit I built to the leads of the high beam (the solid black is the negative). You must solder it in a spot to allow the prongs to fit back inside the housing and allow the flap door of the housing to close.
Snapped the housing back in and it?s done.
Now I just flick on my high beam as I approach my house and cruse right into my garage without stopping. Then I momentarily turn the high beams off, then back on again, and the garage door closes. I love it!!!!
Good luck, and hit me up with any questions.
Tyler
Trey is offline   Reply With Quote
Old 11-15-2007, 11:07 PM   #2
FishOuttaWater
Registered Adrenaline Junkie
FishOuttaWater's Avatar
Bikes: 04' Silver R1
Pretty slick... g/j
FishOuttaWater is offline   Reply With Quote
Old 11-15-2007, 11:17 PM   #3
punisher28
I smoked U
punisher28's Avatar
Bikes: 06 Raven
yeah thats pretty cool
|R1-014 Dragon Squadron|#28
Covering: West/SW USA: CA, HI, NV, AZ,
punisher28 is offline   Reply With Quote
Old 11-16-2007, 05:50 AM   #4
HOLLYWOOD33
Never satisfied...
HOLLYWOOD33's Avatar
Bikes: 2008 KTM 690 SMC
Nice write-up...
I bought one from a company called Taiddan about 2 years ago that does the same thing (got it for like $30 shipped)... You pull up to your house, hit the high-beams and bingo... Pull right in!!!
This is a must have IMHO.......
HOLLYWOOD33 is offline   Reply With Quote
Old 11-16-2007, 09:42 AM   #5
Major Squid
New guy
Bikes: gsxr 1k
Very nice
Major Squid is offline   Reply With Quote
Old 11-16-2007, 09:51 AM   #6
lexanidubs09
Getting ready for track!
lexanidubs09's Avatar
Bikes: 07 gixxer 600, 05 R1
i did this mod on my gixxer and love every minute of it!!!
Signature courtesy of myself
|R1-014 Dragon Squadron|Member # 09|
SIGN UP HERE!!!
PM Beave, Grip told me he could suck the vaseline off his rubber in under a minute.
My 2010 Season Sponsors
Junito70-Bodywork
Socal05R1-Hardparts & Gear
Grom111-Grom photography
Bgesch- Everything
DavidSFC- Alcohol & Bunny Food
Pimp - Track
Deja Vu Showgirls- "M"oral support
lexanidubs09 is offline   Reply With Quote
Old 11-16-2007, 10:15 AM   #7
Corbin
Blue Pride
Corbin's Avatar
Bikes: 05 R1
Nicely done. Here's my setup...
Step 1. Pull up to garage.
Step 2. Honk horn.
Step 3 Wife opens garage door from inside.
Step 4 Kiss wife and thank her and tell her she's the best.
Step 5 Go inside and have nooky with said wife.
If you and wife have argued prior to this procedure, omit wife for yourself in these steps.
IF YOU DON'T STAND BEHIND OUR TROOPS, PLEASE FEEL FREE TO STAND IN FRONT OF THEM!
<a href=http://www.red-e.net/luv/CORBIN.jpg target=_blank><font color=#000000>http://www.red-e.net/luv/CORBIN.jpg</font></a>
Corbin is offline   Reply With Quote
Old 11-16-2007, 10:20 AM   #8
motopsyko32
clutch it up!!!
motopsyko32's Avatar
Bikes: ...SOLD...
Step 2. Honk horn.
easier than learning how to be an electrician eh?
motopsyko32 is offline   Reply With Quote
Old 11-16-2007, 10:24 AM   #9
Devil1
So Fast So Clean
Devil1's Avatar
Bikes: R1
Step 2. Honk horn.
Lol good one. I'd do that but the wife rides too
Representing a Buddyluv sig!
R1-013 `Lucky 13th` Squadron
What squadron are you in?
MSF Rider Coach
Godspeed Chad "Gawarrior" Clifton - June 25, 2008
Devil1 is offline   Reply With Quote
Old 11-16-2007, 10:54 AM   #10
Major Squid
New guy
Bikes: gsxr 1k
Step 2. Honk horn.
Good one
Old 11-16-2007, 11:11 AM   #11
nyyzfr1
ill will
nyyzfr1's Avatar
nice! good post. I cant wait to do this
nyyzfr1 is offline   Reply With Quote
Old 11-16-2007, 11:17 AM   #12
SteelR1
HereWEgo STEELERS, HereWEgo!
SteelR1's Avatar
Bikes: Blue 2004 R1, 2000 R1 (Sold), 1997 GSXR 750 (Sold)
Nice write up, I did something similiar to my bike. There was another write up on here a few years ago.
The how-to section ROCKS!!!
SteelR1 is offline   Reply With Quote
Old 11-16-2007, 11:18 AM   #13
Kmac
Moderateur
Kmac's Avatar
Bikes: 1980 Huffy Santa Fe
Step 2. Honk horn.
http://www.r1-forum.com/forums/showp...6&postcount=25
(the pic is missing, but it was a pic of the horn button on an R1)
Kmac is offline   Reply With Quote
Old 11-19-2007, 10:12 AM   #14
Corbin
Blue Pride
Corbin's Avatar
Bikes: 05 R1
Old 11-20-2007, 12:24 PM   #15
LesnTea
Affirmative, Dave.
LesnTea's Avatar
Bikes: '07 RI
Nice pictures, and detailed instructions. I'm going to do this one too. Thanks for sharing!
LesnTea is offline   Reply With Quote
Old 11-20-2007, 12:37 PM   #16
Trey
I'm just the FNG.
Trey's Avatar
No problem. I have stolen lots of good ideas off of here, so it's about time I returned the favor
Old 12-11-2007, 05:41 AM   #17
robbykank
My R1 what?...
robbykank's Avatar
Bikes: 2005 R1 Raven
When you ride with the high beams on, will it have any adverse affect? I'm sure the 3V is nothing to worry about but will the chip and opener have any problems, maybe overheat or something?
Just wanna ride!
robbykank is offline   Reply With Quote
Old 12-11-2007, 12:16 PM   #18
SIr RicCuS
[VET HNTR] Can Haz Teh Win?
SIr RicCuS's Avatar
Bikes: 2007 R1
That is awesome! Can you make one so that it opens when you honk the horn to the beat :beep: :beep-beep-beep-beep: :beep: :beep: !?
Arrow Exhaust with Carbon Cans and Catless Y-Pipe, Power
Commander III, Driven Chain Kit (+2 rear/-1 front), Speedo
Tuner, Gilles VCR Gold Anodized Rearsets, Puig Dark Smoked Double
Bubble Windshield, T-Rex Frame Sliders, T-Rex Spools, Galfer
Stainless Steel Brake Lines, Blaster-X Smoked Tail Light, Driven
D3 Grips with Collars, GYTR Carbon Fiber Tank Pad, GYTR
Carbon Fiber Triple Tree Cover, KR Tuned Bar Ends, Shock Racing
Fender Eliminator, Graves Flush Mounts, CRG Roll-A-Click Levers.
SIr RicCuS is offline   Reply With Quote
Old 12-12-2007, 05:19 PM   #19
Trey
I'm just the FNG.
Trey's Avatar
I rarely ride with the high beams on, but I have not had any problems with it so far. Before I installed it, I left it activated for just over an hour and it did not get hot, in fact I did not notice any change in temperature at all. I'm very confident that the manufacture of the garage door opener designed it to handle the constant 3 volts. I will update you if I have any problems with it in the future.
Tyler
Old 12-25-2007, 06:53 PM   #20
R1-XSVSPD
NESBA Mid Central
Deftly solved; and nice write up. It's damn nice to just pull right into the garage without stopping.
As an option, you could just put the opener under the seat and run a pair of wires to from the opener to a discretely placed push button. Of course you have to solder the wires to the switch inside the opener.
R1-XSVSPD is offline   Reply With Quote
'04 R1 Garage Door Opener Mod, Done!! r1-superstar Appearance & Mods 38 12-31-2007 09:56 AM
My latest home-brew mod: Garage Door Opener! Skanky General Motorcycle Discussions 19 08-21-2004 03:18 PM
04 R1 garage door opener mod help Rooster62181 General Motorcycle Discussions 11 03-31-2004 08:42 PM
garage door opener mod on 04 Rooster62181 General Motorcycle Discussions 0 03-26-2004 05:12 PM
garage door opener mod. KevinH78 General Motorcycle Discussions 6 09-25-2003 12:13 AM
Kawasaki ForumDucati ForumHarley DavidsonYamaha R1BMW S1000RR Forum
Vulcan Forums Ducati MonsterV-Rod Forum Yamaha R6 Kawasaki Z1000
Kawasaki ZX Forum Honda 600RR Harley ForumYZF-R6 ForumSportbike Forum
Kawasaki ZX-10RHonda 1000RRSuzuki SVYamaha FZ8Can Am Spyder
Kawasaki KLR 650Honda RC51Suzuki V-StromStar Motorcycles Aprilia Forum
Kawasaki VersysHonda FurySuzuki GSXR Triumph ForumKTM Forum
Kawasaki EX-500Honda GoldwingGSX-R ForumTriumph 675Victory Forums
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
