Gearing : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 04-06 R1 Mechanical Help
04-06 R1 Mechanical Help Mechinical and Critical Issues for the 04-06 R1
Motorcycle.com Classifieds!
Old 12-29-2007, 05:46 PM   #1
bluestreakrem
AMA Life Member
Bikes: See the list.
Gearing
Can I go to a 48 tooth (+3 over stock) rear sprocket with no fitting issues?
Will the stock chain length work?
Please join the AMA. Who's fighting for YOUR rights to ride?
Current rides:
73 Yamaha RD 350
85 Yamaha RZ 350
79 Yamaha Daytona
82 Honda V45 Sabre
03 BMW K1200 GT
03 Aprilia Tuono Racing
82 Yamaha YZ 250
02 Polaris 500
02 Honda VTX 1800C
06 Yamaha YZF-R1 Anniversary (LE Paint Scheme)
06 Yamaha YZF-R1 Anniversary LE (The Real Deal)
02 Suzuki GSXR 750 Track Day Only Bike
bluestreakrem is offline   Reply With Quote
Old 12-30-2007, 01:01 PM   #2
Scrat2004
Eat my dirt....
Scrat2004's Avatar
Bikes: Time for another R1...
depends, where have you set your alignment/chain adjusters. If you set all the way out then I don't see it taking up the slack, if not, new chain, not fond of adding master links.
BUT, if you going to change sprockets then I always go for a new chain with new sprockets........
Modifications:
Scrat2004 is offline   Reply With Quote
Old 12-30-2007, 01:09 PM   #3
1hander
The Patient
1hander's Avatar
Bikes: 05 R1
yoiur wheel base is going to shorten quite a bit, im -1+2 and i use a longer than stock chain, i like the slightly longer wheel base, its got less tendency to spin the wheel up
www.satxriders.com -----come and say hi
1hander is offline   Reply With Quote
Old 12-31-2007, 06:04 AM   #4
Scrat2004
Eat my dirt....
Scrat2004's Avatar
Ye listen mine was geared 16/48....but that was for track use...topped out at 254km/h with the rev limit bouncing...
If you looking for the same then I would also run the adjuster as far back as possible cause if you think the R1 can wheelie then power sprocket it and you'll have a handful...short shifting to 6th is the norm.
http://www.xs4all.nl/~ator0437/gc/
Check out the link using the 2004 R1, same thing, and you'll see for sure where you are going...works like a charm...
Modifications:
Old 12-31-2007, 08:45 AM   #5
bluestreakrem
AMA Life Member
I only have 2000 miles on the bike. It's all original stuff right now. Current gearing is 17/45. The axel is in the middle of the slot at this time. I was hoping to go up to the 48 and use the OEM length chain. Will the chain be long enough?
Current rides:
73 Yamaha RD 350
85 Yamaha RZ 350
79 Yamaha Daytona
82 Honda V45 Sabre
03 BMW K1200 GT
82 Yamaha YZ 250
02 Polaris 500
02 Honda VTX 1800C
Old 12-31-2007, 04:14 PM   #6
Scrat2004
Eat my dirt....
Scrat2004's Avatar
I doubt it, it might be just to short....if you want to go through with it why not change the front to a 16? That gives you almost the exact same result, 10rpm difference......but you get a longer wheel base which is a good thing....
And, the front sprocket is cheaper..bonus.
Modifications:
Old 12-31-2007, 04:19 PM   #7
weston22s
weston22s's Avatar
Bikes: 2004 CARBON FIBER R1/2003 YZF 450 SMR
i used a 15t front sprocket on my 04 and stock rear
weston22s is offline   Reply With Quote
Old 12-31-2007, 04:29 PM   #8
FishOuttaWater
Registered Adrenaline Junkie
FishOuttaWater's Avatar
Bikes: 04' Silver R1
I'm going to a -1fr/+2rr and I'm curious as to if you HAD TO get a longer chain, or was it personal preference...?
Great link too, thanx Scrat !!! (I didnt know that changing to a 55 series tire from 50 series would bump up the top speed, thought it would just effect the "speedo reading vs. actual speed"...) Top speed w/50 = 265 km/h, w/55 = 274 km/h...!
FishOuttaWater is offline   Reply With Quote
Old 12-31-2007, 05:17 PM   #9
Scrat2004
Eat my dirt....
Scrat2004's Avatar
Ye, I used to play around for tracks use and ended up wasting time and money, this calc gets it done first time...I run stock then take note of revs gear and work that back to what I need for that track...change ratios till I get it and then, go buy the sprockets......works everytime..
If you go down 2teeth up front, how much clearance do you have on the swingarm upfront and hell but you now loading the chain with a tighter turning circle...??...not saying it won't work...
Tyre change...ye but I would not do it...unless you keep in mind that with a higher profile you'll change the handling....but well noticed...
Modifications:
Old 12-31-2007, 05:19 PM   #10
weston22s
weston22s's Avatar
i dunno but mine is a wheelie beast with 15tooth on front its like my 03 was with 1 up on the back
Old 12-31-2007, 05:26 PM   #11
Scrat2004
Eat my dirt....
Scrat2004's Avatar
I know what you mean, with all my mods I had, add the 16/48 conversion to...bouncing off the limiter in 6th was so easy...wheelied 1st to 5th, pulled away in 4th the one day from traffic lights...almost flipped her one day in 5th, hit small bump in the road, hit the throttle and she ALMOST looped on me...
Was fun for a week...
Modifications:
Old 12-31-2007, 06:05 PM   #12
1hander
The Patient
1hander's Avatar
Bikes: 05 R1
i went with a 520 conversion at the same time, but i think it would have just been long enough if i used the original chain, but it would have been real close.
with the 520, i chose to go 1 link longer because 1 link less was 2 short
Old 12-31-2007, 07:02 PM   #13
FishOuttaWater
...with the 520, i chose to go 1 link longer because 1 link less was 2 short.
Huh...? Do you mean "because 1 link less was too short"...? And I'm doing the 520 conv. too, but that doesnt matter when it comes to diameter/# of teeth...
What are other peoples opinions on how many links you need for a -1/+2 sprocket change...? I imagine any more than 2 links (over stock, 116 links) would be too long... 118 links max...?
Old 01-01-2008, 11:46 AM   #14
1hander
The Patient
1hander's Avatar
Bikes: 05 R1
-1+2=118 links total is what im using, and i still have plenty of room for stretch and adjusting, by the time it stretches that far that im out of adjustment, its trash and would needed to have been replaced long before
i chose to go one longer (118) for the slightly longer wheel base. (because i like it that way), with that much gearing---longer wheelbase is a godsend
117 was too short (shorter wheelbase) for my liking, but not to short to fit, will fit fine too
its up to you what you want for wheelbase in that situation
Old 01-01-2008, 04:50 PM   #15
FishOuttaWater
Pretty much exactely what I needed to hear...! Thanx...
Old 01-01-2008, 07:36 PM   #16
1hander
The Patient
1hander's Avatar
Bikes: 05 R1
no prob, just be careful, because at that ratio, its putting down an insane amount of power to the ground and its going to use a bit more fuel,
Old 01-02-2008, 07:08 AM   #17
bluestreakrem
AMA Life Member
It always best to run as large a front sprocket as you can because it keeps drive chain losses and wear rates to their lowest values. Drive losses and wear will be less with a larger sprocket because it has a longer turnining radius than a smaller sprocket. I really don't want to go to such a large reduction as the -1/+2 senario. I feel it would be too much for the street. I feel like I need a 7th gear as it is when crusing on the freeway with OEM gearing of 17/45. I thought going with just the 48 would be a little better for acceleration without increasing cruise RPM too much. As for wheelies........That's what I like to do, so the short wheel base would help and is OK with me. I feel the R1 is very long as it. I just don't want the gearing to be so low that wheelies are unpredictable.
So the general opnion is that the stock OEM chain length will NOT work with 17/48 gearing???????
Current rides:
73 Yamaha RD 350
85 Yamaha RZ 350
79 Yamaha Daytona
82 Honda V45 Sabre
03 BMW K1200 GT
82 Yamaha YZ 250
02 Polaris 500
02 Honda VTX 1800C
Old 06-17-2008, 08:49 AM   #18
r1menace
The Yellow Peril
r1menace's Avatar
Bikes: 05 R1, Forks dropped 5mm, Harris clip ons, Brembo m/c, GB Moto rearsets, -2F/+4R, PCIIIUSB, HM quickshifter, CAT mod Micron race cans, Bridgstone slicks & wets, STM Slipper, HEL lines, WP shock, K-tech fork internals, K&N filter, Starlane Athon GPS
I run -2F and have a combination of standard and +1R on a 520 chain. Top end doesn't concern me all I want is acceleration for the track. IF down one on the front is worth between 2 - 3 on the rear then I'm running the equivelent of +6 on the standard rear and +7 with the 46 tooth. It can be a bit wheely prone out of slow turns but it's worth the hassle of dabbing the rear brake to keep it down. 16/48 should be no problem as that's only +3 over standard.
Youth is wasted on the young
r1menace is offline   Reply With Quote
Gearing HELP..!!! Rauti_R1 Mechanical / Help 1 06-04-2006 08:39 PM
06 gearing? Masia General Motorcycle Discussions 0 06-04-2006 12:31 PM
04/05 R1 Gearing 74bones General Motorcycle Discussions 160 07-19-2005 12:46 PM
04 r1 gearing r1rulz Mechanical / Help 4 04-30-2004 04:58 AM
Gearing '04 R1 yamaguy General Motorcycle Discussions 2 10-03-2003 10:55 AM
