Throttle cable install : Yamaha R1 Forum
04-06 R1 Mechanical Help Mechanical and Critical Issues for the 04-06 R1
Old 03-05-2008, 10:11 AM   #1
sloppy
THE SLOPPY ONE
sloppy's Avatar
Bikes: 2005 RAVEN
I have searched and didn't really come up with anything helpful. I am in the process of replacing my throttle cables on an '05. On the motor side, I cqan get the top cable on, the pull side I believe. Now tonight I will attempt to get the bottom cable on, the return?
Are there any tricks/tips to get that bottom one onto the pulley without taking off the pulley? I looked at it real quick, and it doesn't even seem like you can see the hole that the cable attaches into.
Any help would be appreciated, Thanks.
Race baffled stock cans/ BMC race filter/ Gutted cat/ PCIII USB/ Ohlins Damper/ Zero Gravity smoke windscreen/ Greggs custom fairing plugs/ Clear Alternatives tail intergrator/ Windshield and Bar end spikes/ F6R sliders/ Pazzo shorties/ painted rearsets
He who makes a beast of himself, gets rid of the pain of being a man. - Hunter S. Thompson
sloppy is offline   Reply With Quote
Old 03-05-2008, 03:53 PM   #2
sloppy
THE SLOPPY ONE
sloppy's Avatar
Bikes: 2005 RAVEN
OK, I decided to pull the pulley off and got the two cables attached. Are there any tricks to getting the return spring wound twice around the bushing? Someone said wire but I couldn't get that to work. Any ideas? Someone must have some input on this. Thanks.
Old 03-07-2008, 11:48 AM   #3
BSR-1
burnin' up the streets
BSR-1's Avatar
Bikes: 05 Raven #8734 sold, 2011 S1000RR sold, 2013 MV Agusta F4 sold, 2013 RSV4 Factory sold, 2012 MV Agusta F4R
remove the throttle bodies, get the cables set up & then reinstall the t-bodies making sure to route the cables properly to the clip on.
Originally Posted by marcaztls View Post
I just want to stroke it all the time. (For you BSR )
BSR-1 is offline   Reply With Quote
Old 03-07-2008, 12:32 PM   #4
sloppy
THE SLOPPY ONE
sloppy's Avatar
Bikes: 2005 RAVEN
Thanks, I ended up using a piece of wire to pull the return spring. The thing that took forever wa sthat I read on here that you had to wrap the spring around the bushing twice. Well, after an hour of work and the wire breaking and me punching myself in the nose, I realised that there is no possible way to rap the spring twice. It must have only reversed on turn and got caught.
Anyway, it's back on and working just fine.
Old 03-07-2008, 01:37 PM   #5
BSR-1
BSR-1's Avatar
sorry for the slow response, glad it turned out OK!
Old 03-07-2008, 04:49 PM   #6
sloppy
THE SLOPPY ONE
sloppy's Avatar
Bikes: 2005 RAVEN
Thanks man.
Throttle Cable sheryar7861 98-99 R1 Mechanical Help 3 12-09-2007 12:33 AM
Throttle cable install......can anyone help? yamadude Mechanical / Help 15 06-30-2006 07:10 AM
Throttle cable YnOt How To's 0 02-24-2006 11:35 AM
WD-40 on Throttle Cable extrakt0r General Motorcycle Discussions 1 04-08-2004 03:56 PM
throttle cable PDPHeathcliff Mechanical / Help 3 08-23-2002 04:58 PM
