whats better 4 valve of 5 valve : Yamaha R1 Forum
Old 03-09-2008, 12:53 AM   #1
vr6_vince
vr6_vince's Avatar
Bikes: 2005 yamaha R1
dose any one kno if the 5 valve R1 is better then the 4 valve?
vr6_vince is offline   Reply With Quote
Old 03-09-2008, 01:52 AM   #2
NickFPD
Look TITS!!!!!
NickFPD's Avatar
Bikes: FO SALE!!
I would have to say to started this in the wrong place.
NickFPD is offline   Reply With Quote
Old 03-09-2008, 08:56 AM   #3
DanQ
Yamaha blue, in any color.
DanQ's Avatar
Bikes: 91 FZR1000, 04 YZF-R1, 05 V-Max 0098/2000, 04 Warrior, 05 R6
Hopefully a mod will get this moved for you quickly so it can be seen.
Yamaha stuck with the 5 valve design for many years, despite the fact that it took some work to design them well. Other manufacturers experimented with more than 4 valves (which wasn't easy. Yamaha had certain patents, so they couldn't copy the three intake two exhaust design).
They recently decided to go to four valves instead of five. One advantage may be longevity. I know there have been issues with the little tiny intakes lasting.
With the amount of research Yamaha puts into things, I would have to guess that they have found advantages to switching to four valves.
Signature by SpidermanSS. Thanks Shane!
Dan
R1-016 'Venom' Squadron Member
CCS #598
91 FZR 1000
04 YZF-R1
05 YZF-R6 (track bike)
05 Vmax 20th Anniversary 98 of 2000
04 Road Star Warrior
DanQ is offline   Reply With Quote
Old 03-09-2008, 09:45 AM   #4
D 23
Dazzle Dazzle Dazzle
Bikes: 2002 R1
here's a quote I got off the net so take it for whatever it's worth...
The official reason is that this eases meeting emissions (the bike has two in-series cat-cons and an oxygen sensor to meet '08 regs), but emissions are not the reason why Yamaha's MotoGP M1 has had four valves for two-and-a-half seasons. With the new four-valve chamber, compression ratio is up to 12.7:1 and torque is said to have fattened nicely in the midrange. In the past, R1 torque has peaked up above 10,000 rpm, giving a narrower powerband than the competition, whose torque generally peaks at 8500 revs.
D 23 is offline   Reply With Quote
Old 03-09-2008, 04:16 PM   #5
Peg Grinder
One 1 to Rule Them All
Peg Grinder's Avatar
Bikes: '07 Charcoal R1, '69 DS6-C Scrambler, '13 Mitsubishi Evolution.
The original reason Yamaha went to a five valve head was an elegant if simple solution to a difficult engineering problem.
The key to increasing rpm for a given engine size is to reduce the weight of the reciprocating components in the drive train. Anything that moves back and forth in the engine, pistons, connecting rods, and valves. The faster you spin the engine, the faster these parts have to go to keep up. The faster they go the inertia they carry and more stress developed on parts when they accelerate and decelerate.
The problem with valves was the valve springs. Back in the eighties when Yamaha first came out with the 5 valve, manufacturers were limited by metallurgy and expense when making valves for production bikes. When rpm got too high the valves were carrying to much inertia for the springs to provide enough force to keep the valves/shims/buckets in contact with the camshafts. This caused what is known as valve "float" and deformed valves and seats as they crashed together.
In order for the valves to be as efficient as possible they need to cover as large an area as the cylinder head will allow. The bigger they are and the longer they are open the more fuel/air can be drawn into the cylinder, the more power can be made. So rather than 4 big heavy valves, Yamaha went with 5 smaller lighter valves. This resulted in even more area for flow while the valves were open and higher rpm limits and more power for a given engine size.
The problem though is a huge limitation on valve angle, the angle at which the valves are set in the head. In order to only use the standard two overhead camshafts (DOHC) the valve angle had to be widened. This resulted in a pentagonal shaped combustion chamber and put severe limitations on compression. By 2004 they'd reached the limits and just couldn't get any more compression out of the 5 valve heads.
Since the inception of the Genesis engine metallurgy has improved enough for production valves to be much lighter than in the eighties and increased the strength and flexibility of springs. So much so that the current large valves in the R1's 4 valve heads are actually lighter than their smaller 5 valve head predecessors from the nineties. Going back to 4 valves has allowed them a shallower valve angle in turn allowing them to reduce cylinder head dome height and increasing compression.
So, answer...
In the eighties and nineties the 5 valve was better, not so anymore. Too many advantages with the 4 valver.
Hugh??? Wha'???
R1-013 LUCKY 13th SQUADRON
Cigarettes are like squirrels, perfectly harmless until you put one in your mouth and set it on fire.
RIP Glenn "ElvisWarrior" 17 June 2007
RIP Chad "Gawarrior" 25 June 2008
RIP Charlie-Bug 14 April 2012
Peg Grinder is offline   Reply With Quote
Old 03-09-2008, 04:27 PM   #6
DanQ
DanQ's Avatar
So, answer...
Yeah! What he said!
Dan
CCS #598
91 FZR 1000
04 YZF-R1
timing? bent valve? valve tap aggiestckl 02-03 R1 Mechanical Help 0 09-09-2007 02:25 PM
ex up valve r1nick 02-03 R1 Mechanical Help 2 06-17-2007 01:41 PM
ex-up valve ASSASSINR1 Mechanical / Help 8 06-13-2004 03:30 PM
Ex-Up Valve RivarDo Mechanical / Help 15 11-06-2003 01:32 PM
ex-up valve quad Mechanical / Help 13 07-20-2002 01:56 PM
