vibration at 5000rpm : Yamaha R1 Forum
Motorcycle.com Classifieds!
Old 01-05-2003, 12:43 PM   #1
dingus
Bikes: 2002 R1
Does anyone get a vibration in the stock windscreen at 5000 rpm?
My bike does it in every gear between 4800-5000 rpm. I have checked every bolt in the front end myself and had it looked into at the last service. I am positive it is the windsreen because if I grab it while im rolling the vibration goes away. Any response will help.
dingus is offline   Reply With Quote
Old 01-06-2006, 11:50 PM   #2
eikcam
eikcam's Avatar
Bikes: 2005 R1
I get the same.. Lots of threads on this sort of thing. Learn to live with it I reakon, as now that you know its the windscreen at least its not a serious issue.
eikcam is offline   Reply With Quote
Old 12-26-2006, 07:31 PM   #3
ONEMOFO
My Mofo R1, hell yeh
Bikes: 06 R1 Stolen!!! 07 R1 Raven
I have the same issue but its not the screen, at the exact same rev range i get a viberation, its not mechanical it sounds like a loose plastic ferring, even though i have tightened all that i can, it drives me crazy its also quiet loud if anyone has a soulution to this it would be great as i am very perdantic about my babe.
Body, Mind, Soul, YZF R1
ONEMOFO is offline   Reply With Quote
Old 12-26-2006, 08:06 PM   #4
zwp
I ride around like an idiot.
zwp's Avatar
Bikes: 06 50th R1
Yup. I can vouche for that, as well. It's the only gripe I have about my bike. There is probably not much that you can do about it unless you really want to get crazy with it. When the engine vibrations reach a certain harmonic you get the vibration; it has little to do with the windscreen itself other than the shape which makes it catch that harmonic frequency.
zwp is offline   Reply With Quote
Old 12-26-2006, 08:52 PM   #5
metalwizard
"It was me!!!"
metalwizard's Avatar
Bikes: 2006 R1 (50th anniversery), 85 Rz350
yep, same here, i'm not sure were it comes from but the thing is just louder/rougher/different at those rpm's not bad not a miss just not as smooth as everywere else in the rpm range. i just keep out of that rpm as much as i can.
No matter how hard you push the Envelope It will still be stationary
metalwizard is offline   Reply With Quote
Old 12-26-2006, 09:55 PM   #6
ONEMOFO
Yeh but its in the range that i use constantly if it were up around 12,000 rpm i wouldnt be able to hear it and probably wouldnt know it was there either, but im still adjusting things on my bike so hopefully ill come across it.
Old 12-26-2006, 10:01 PM   #7
PARKER10
WSMC #520
PARKER10's Avatar
Bikes: 2005 Yamaha R1
I don't have any problems with mine The only thing I can think of that comes close is when I had my old bike and after I had somebody work on it, they forgot to put the two bolt in that hold the front fairing bracket to the frame(under the speedo). Thats why nobody works on my bike anymore except me!
PARKER10 is offline   Reply With Quote
Old 12-26-2006, 10:08 PM   #8
R1LOVER
R1LOVER's Avatar
Bikes: 2007 R1 / 05 V-Rod / 08YZ450F
I had the same issue on my 04......... thankfully along with the ticking...... it's gone on the 07.
R1LOVER is offline   Reply With Quote
Old 04-14-2007, 04:34 PM   #9
WhiteSnake74
WhiteSnake74's Avatar
Mine does exactly the same noise at around 5k rpm. It is the windscreen for sure cause when I grab it, the noise goes away. I've also checked the bolts, but the noise is still there.
My question is: Is it normal for this bikes to vibrate that much? My previous 2005 R6 had no vibrations at all. I know they are two completely different engines (and bikes ).
06 YZF-R1 (Sold)
07 Roadstar Midnight Warrior
07 Honda CBR1000RR Repsol
WhiteSnake74 is offline   Reply With Quote
Old 04-14-2007, 06:17 PM   #10
Aussie Pete
Aussie Pete's Avatar
Bikes: Blue '05 R1 - Sold
I've learned to live with it in mine by just staying out of that rev range as much as possible - free and easy mod even the most non-mechanically minded R1 owner can do
Service looked into it and said nothing they can do - just the bike's natural resonance at that rev range
Aussie Pete is offline   Reply With Quote
Old 04-14-2007, 07:10 PM   #11
fearcetwztdbeat
Cheese is 50 cents extra.
Bikes: 2004 R1 Shift Red
replace the windscreen rubber grommets. they get dried and cause the vibration. i had the same problem. switched them for LP windscreen bolts and rubber grommets. when you replace the rubber grommets make not to overtighten the windscreen bolts.
Yamaha seat cowl|ASV levers|Motivation USA frame&clutch sliders|GC bar ends|Bazzaz Z-Fi + Z-AFM|Spiegler brakelines|Scotts damper|17/48 Driven Sprocket combo w/ Speedhealer|07 shock|Corbin seat|Watsen's signals|Clear Alternatives tail light|Titanium windscreen bolts|Sato moto-GP full ti-exh.|Factory Pro v-stacks| Gilles rearsets&chain adjuster|MotoWizard pre-load adjusters|Acumen DG8|Woodcraft case covers|Graves AIS blockoff plates|SME axle protectors|A&R HID's
fearcetwztdbeat is offline   Reply With Quote
